Question about Whirlpool Washing Machines
Water spills all over the floor
I have a Whirlpool AWM6120, the water fills, washes the clothes and when it ejects the water it goes to the floor, it doesnt go down out of the machine it goes to the floor and causes the lights to go out.
  • 315 Answers
Replacing Parts Second, Replace Leaky Internal Hoses
If the supply hoses aren’t leaking, open the cabinet and inspect the internal components. Belt-drive machines typically have a rear access panel that unscrews. Access direct-drive machines by removing the two screws on the outside of the control panel and flipping up the lid. Then pry up the cabinet clips and pull off the entire cabinet. With the cabinet open, restart the fill cycle to check for internal leaks. Look for additional clues like rust and calcium deposits. Most often you’ll find the leaks in the spots we show inFigure A.
Hoses tend to leak around a worn-out spring clamp. First try to remove the spring clamp with an adjustable pliers. If you can’t get it, you’ll need a special $15 hose clamp pliers available from your local parts supplier. Replace the old spring clamp with a new worm-drive clamp. If the hose itself is cracked and leaking, remove it and take it to the appliance parts supplier for a replacement.
CAUTION: Unplug the machine before performing any repairs.
Buying Parts
Water spills all over the floor - 20030901_washing_machine_leaks_page003img004.jpg
Washing machine parts are available at appliance parts distributors. (Look in the Yellow Pages under “Appliance Parts.”) Try to find a parts supplier with a well-informed staff, ideally ex–repair technicians, who can provide diagrams and help diagnose any problems specific to your brand of machine. A great Internet source is www.searspartsdirect.com. Enter your model number to access exploded-view diagrams and a thorough parts list for easy on-line ordering.
You’ll need the brand and model number for proper part identification. Model numbers are usually stamped on a small metal plate located under the tub lid or on the side or back of the machine. Copy down all the plate information and take it along to the parts distributor.
Third, Replace a Leaky Pump
Fourth, Replace Worn-Out Tub Fittings
The most challenging repair is fixing a leaking tub fitting, whether it’s the air dome seal ($5), the center post gasket ($8) or the tub seals ($15 to $20). Before proceeding, make sure that telltale drips are coming from around the tub. The details of this repair vary by brand and model. The details we show are for most Whirlpool and Kenmore belt drives. Study a schematic drawing or consult a parts specialist if your machine is different from what we show.
You’ll need a special $15 spanner wrench to remove the tub and replace the tub fittings on this type of machine. It’s available at your local appliance parts supplier. You can open the top of many machines by releasing the spring catches. However, on others you have to unscrew several screws and lift off the entire cabinet. Look in your owner’s manual or at a parts diagram. (See the manufacturer’s Web site or one of the sites listed in “Buying Parts.”) You’ll have to unscrew the water inlet and the tub snubber before unclipping the ring. Fastening systems for these vary by brand, as do attachment methods for the agitator and inner tub.
There are four tub seals that secure the outer tub to the cabinet, each consisting of a bolt with a rubber and metal washer. Rust often develops around one of the tub seals, causing a tub leak. A new tub seal kit will come with four new bolts and oversized rubber and metal washers that will seal small leaks. But if the tub is completely rusted through around the bolt, it’s time to buy a new washing machine. Replace all four tub seals.
If the leaking occurs only when the machine is agitating, a bad center post gasket (“doughnut”) is the culprit. Remove the outer tub to replace the center post gasket. While you’re at it, replace the air dome seal as well. Reassemble the washing machine and run a test cycle.
Posted on Jul 14, 2009
  • mithun dey
    mithun dey Jul 14, 2009
    Make sure the water on the floor isn’t the result of a plugged floor drain. It happens!
    There are two types of washing machines: belt drive and direct drive.
    If you open up the cabinet and don’t find any belts, then you’ve got a direct-drive machine. Repairs are similar for both machines, but generally easier on the direct-drive unit.
    The following photos are from a belt-drive washing machine. If you have a direct drive, refer to your owner’s manual or diagrams (see “Buying Parts") for brand-specific details.
    Common Leak Locations
    First, Replace Leaky Supply Hoses
    The first step is to locate the source of the leak. Empty the washing machine, move it away from the wall and start the fill cycle. Look for drips around the water supply hose connection at the back of the machine while it fills with water. Shut off the water and replace any old, heavily corroded or rusted hoses with new ones. If the hoses are in good shape, replace the internal washers only. Special no-burst hoses ($10), regular hoses ($6) and new hose washers ($2 per 10-pack) are available at home centers and hardware stores.
    Turn off the water main or shutoff valve and unscrew the supply hoses from the back of the machine with an adjustable pliers. Pry out the old hose washers with a flat-blade screwdriver. Install new gaskets in both hoses and reconnect the supply lines.
  • mithun dey
    Hello, you need to start from "Make sure the water on the floor isn’t the result of a plugged floor drain. It happens! There are two types of washing machines: belt drive and direct drive."
Whirlpool AWM6120 - small ping pong size ball found in black drain part????
The ball is supposed to be there. It should be in the drain hose at the bottom of the drum. It is part of the eco system of the washer. In the service manual its called an "eco lock"
Oct 13, 2012 | Whirlpool AWM6120 Front Load Washer
After washing -washer slowly fills with water and runs out the door--not every time it is used. First noticed clothes still wet needing to run spin cycle--then washer leaked on floor over week end and...
I would suspect the water inlet control valve may be malfunctioning- not closing (its default no power position).
Quick temporary fix, although tiresome, turn whichever tap, hot or cold, off when washing finished. You've probably already thought of that!
In the meantime I would suggest a service call is required ;-0(
John C
Mar 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
After each cicle of washing its coming on the floor some water like 50 ml
Whirlpool AWM6120
There are several items which may contribute to your issue at hand.
A plastic gasket seals the front to back portion right above the location where deprey gets caught when in wash cycle. When this builds up with trash and gunk not caught by the filter, it will cause water to leak out and eventually onto the floor. You may also have a build up in the drainage hose backup and release for dirty water. Check this area thoroughly!! You can also see exactly where the water is dripping so that we can identify what is the root cause of the water leak. Nothing sounds major so replacing the unit is not a good idea and would be expensive.
Jan 12, 2011 | Whirlpool AWM6120 Front Load Washer
Can you wash in cold water only
Yes , you can look into the program and find an easy economical quick wash which will has a fast wash with cold water, rinse and short drying cycle.
The normal/regular wash uses the heater as with warm water the dirt comes off well and is sterilised wheras in cold wash the average dirt might go off but not as clean as in a hot wash.
So you can use the programs as required for the clothes in question.
Aug 21, 2010 | Whirlpool AWM6120 Front Load Washer
Wash machine is filling with water when the washer is off.
You probably need to replace the water inlet solenoid valves which may be stuck open. Turn off one hose at a time to find out if both or just one is causing the problem.
Sep 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer is filling with water when it is off. it only drips, but two days in a row it was filled up above the bottom of the door openeing and spilled on the floor,
This problem is either attributed to a defective water inlet valve, or defective pressure switch. An easy way to determine which one may be causing the problem is to unplug the washer, but leave the water taps on. If the washer continues to fill, you have a defective water inlet valve. If the water stops, I would recommend changing your pressure switch.
Post back and let me know if you require further assistance. I hope this helps you.
Sep 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Tank fills when not in use
So sorry to hear of your trouble. It sounds like your water-inlet valve is defective:
A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
May 21, 2009 | Kenmore Elite 45986 Front Load Washer
Washing cycle starts and takes hours even for short cycle.
Try checking for good water supply.
Pull out detergent tray and check for good water supply during filling.
if poor filling-
Try checking the hoses.
Turn taps off, disconnect from machine, place hose end in sink, turn tap on and check for good water flow.
if the hose has a red indicator in the side of the hose (end which is fitted to the tap) - Red indicator is a failed hose.(for models with Water Stop hose type "B")
Oct 05, 2008 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
424 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
