Question about Maytag MDE9316 Dryer
Need idler pulley wheel - with arm. mod# p
Need idler pulley wheel - with arm. mod# p mde9316ayw - ser#1374698wf thanks Frank
  • 525 Answers
K1500 idler arm
There is an idler arm and a pitman arm.
The Pitman connects the steering box to the steering linkage by/through a ball joint. The idler arm should be on the other side by the passenger wheel.
Aug 07, 2013 | Cars & Trucks
I have a 2000 gmc Jimmy . I'm going to change the
Locate the idler pulley to the left of the crankshaft pulley. The idler pulley bolts to the idler arm. The idler pulley is replaced with the arm because they are sold as one unit.
  • 2 Place a 3/8-inch ratchet driver into the square hole on the face of the idler pulley and pull up on the handle. This releases tension on the Sonoma's serpentine belt. Pull the belt off the idler pulley, lower and remove the ratchet handle.
  • 3 Remove the two bolts that secure the idler arm to the engine block using a socket and ratchet, and discard the old idler arm.
  • 4 Place the new idler arm against the engine block and secure it using the socket and ratchet.
  • 5 Put the ratchet driver into the square hole on the new idler pulley, pull up on the handle and place the serpentine belt over the pulley.
  • 6 Lower and remove the ratchet handle.
  • Oct 15, 2011 | 2000 GMC Jimmy
    WALK BEHIND SELF PROPELLED MODLE NO. CC997ES.THE DRIVE CONTROL IS SET AT #1. IT TRAVELS TOO FAST. WHEN I RELEASE THE DRIVE LEVER, SOMETIMES IT CONTINUES TO MOVE FORWARD.\r\nDIFFICULT TO BACK UP, REAR...
    I have the same issue. Just tore into it and found the return spring on the transmission idler pulley is broken. Without the spring the idler pulley arm keeps the belt engaged and wheels turning. The spring is attached to the idler arm just below the belt pulley. Looks like the trans has to come out to get to the spring. I just found the P/N for the spring. MTD 932-0849A (replaces 732-0849A) Extension Spring. Your price: $2.62
    Jun 27, 2011 | Sears Saws
    I am wanting to replace a drum bearing, and I've gotten the dryer top panel and front panel off, but I don't see how to release the drum belt (which is okay) so I can get the drum out. How to do...
    On the bottom left side next to the motor you will see a small plastic wheel (idler pulley) which the belt is wrapped around. The wheel is attached to a L-shaped piece of metal which is known as an idler spring arm which is made out of spring steel.
    Move the arm one way or the other and you will notice the belt tension getting looser. Push the arm further that way until you can get the belt off the pulley an motor. Use caution as the spring arm has torque on it and could snap back.
    Once the belt is off the motor and idler pulley you can then pull the drum out. You will need to lift the drum up slightly since the back sits on drum wheels(the groove on the back of the drum). Take the drum and belt out together.
    Once you have made the repairs, install the drum in reverse order.
    Note: Before removing the belt, make a diagram of how the belt goes around the motor and pulley for future reference.
    Hope this helps you out.
    Nov 16, 2010 | GE Profile DPSB513GBCC / DPSB513GBWW Gas...
    My 2005 Chevy Equinox violently shakes when going 60mgh and over from the steering wheel and whole car you can feel it in every seat .
    Most likely a front end problem such as idler arm or even balencing of the tires, ball joints, bent rim...ETC
    Nov 02, 2010 | 2005 Chevrolet Equinox
    How to replace iddle arm and pitman arm on a 1986 g20 van
    jack up and support van passenger side first with wheels straight remove wheel unbolt idler arm from center link and using a fork designed for removing front end parts some auto stores let u borrow / loan u fork remove idler arm unbolt (2) from frame replace and bolt in new one replace wheel other side wheels straight jack and remove wheel mark pitman at steer box so u can transfer mark to new pitman unbolt and us fork to remove pitman from center link us pulley to remove pitman transfer marks to new arm align up replace bolt up replace wheel done
    Oct 30, 2009 | 1986 Chevrolet G20
    Whirlpool estate model teds780jqo how do i get the tension in the arm when changing the belt does the spring arm go above or below the pully on the motor
    Hi. The idler pulley assembly locks into two slots in front of the motor. The belt will loop through the idler pulley and the on the motor. Push the belt under the idler wheel and thread it between the wheel and the idler bracket.I hope this helps you. Please let me know if I can assistyou further.
    Vic
    Jun 13, 2009 | Whirlpool LER4634J Electric Dryer
    Replace idler arm pulley
    An idler arm is a steering component found on vehicles without rack and pinion steering. Your referring to an idler pulley. To replace: remove the belt, remove the bolt from the center of the pulley, replace the pulley and reinstall the belt.
    Apr 11, 2009 | 1999 Dodge Intrepid
    Idler pulley arm
    there is a certain way that the belt is supposed to loop around the tensioner and motor. this picture might help.b00f604.jpg
    Jul 19, 2008 | GE DBSR453EBWW Electric Dryer
    Dryers Logo
    203 people viewed this question
    Top Maytag Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a Maytag Dryer Expert? Answer questions, earn points and help others
