Question about Zyxel (91-004-361002) Wireless Router
Losing connection to wireless router everytime rebooting
I have verizon fios and am using Zyxel as the wireless adapter. Everytime I restart my pc, I have to type in the WEP ID. Is there a feature I can enable to allow me to be automatically connected once I reboot my desktop? this is a pain to have to do every morning.
Thank you,
Adi Oz
  • 1,272 Answers
It seems that you have windows XP on this computer. Follow the steps below;
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight thee SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Jul 14, 2009
Can't get on line with my Linksys wireless router
you can daisy chain ..but you will need an eithernet run from the fios router to the linksys...
Jun 25, 2010 | Linksys Wireless-G WRT54G Router
Zyxel model G-220 v2 usb wireless adapter won't connect
If you are trying to connect a computer wireless card to a wireless router then follow my instruction on how to configure the wireless router and the wireless card in the computer - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 14, 2009 | Zyxel Computers & Internet
I have a new zyxel router connected to my computer by ethernet cable. I have windows xp. Everytime i start up I have to disable the wireless connection switch off the computer then restart it and enable...
Why do you require a wireless connection on the computer, when it is already connected to the router through ethernet cable? Disable the wireless connection permanently & try.
Jul 26, 2009 | Zyxel (91-004-361002) Wireless Router
Lose router signal everytime i restart my laptop
This seems to be an issue with the router itself. As the laptop is able to connect to other networks easily, the trouble seems to be with the router.
Try updating the firmware on the router. Also, change the wireless channel on the router and check if that helps. If the issue persists then I believe you will have to get the router replaced.
Jun 21, 2009 | Zyxel (91-004-361002) Wireless Router
ZyXEL NMP-1100W wireless network goes down
WEP or WPA encryption code Wifi checked?
Modem or router going in to reset possibly.
Possibly 2nd device present with same key.
Apr 18, 2009 | Zyxel NMP1100W WIRELESS MUSIC BOX
Inspiron 6400 wirless connection
HI
If the browser shows working offline and wireless is connected fine then it could be an issue where work offline is checked in the browser.
In internet explorer 6 its found on File in the menu, if work offline is already checked, check it again to remove the check mark and then try, if its internet explorer 7 its found on tools, the same steps and in firefox under file,
Also try this step as well, if its internet explorer go to tools-internet options-and in internet options-go to connections tab-there is dial up and networking box-remove the dial up connections from the box-and check the one never dial a connection
also check the firewalls and antivirus programs, post your results.
thank you
rakesh
Jan 11, 2009 | Dell Inspiron 6400 Notebook
I have Verizon Fios install in my home. I use to have Comcast. This is the situation, before the Fios my linksys wireless router was connected directly to a modem. Now my linksys wireless router is...
Your IP address for you linksys router needs to be changed.  More than likely there using the same IP address such as 192.168.0.1.
You have to convert your linksys router to a switch and change the IP address range it uses to on that doesn't conflict with the Verizon router.
10.150.1.1 should work.
Oct 08, 2008 | Computers & Internet
The battle: Acer Vs. Verizon FiOS
Verizon needs to apply a firmware update for the Atheros wireless adapter in your notebook. I work for Acer and I end up having to tell people this all day long. If you take this to a wireless router that is not from verizon you will have no problems with your connection. Maybe if enough Fios customers complain they will provide a firmware update for this.
Mar 06, 2008 | Computers & Internet
Zyxel (91-004-361002) Wireless Router Logo
1,132 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
