Question about Smart Pool Inc Dolphin Diagnostic Automatic Pool Cleaner Ne250
Can't turn the unit on.
After only 2 months (with a new unit), the power supply does not turn on. The red light does not come on. Please advise.
    President:
  • Smart Master
  • 1,378 Answers
Does your power supply have the fuse on the back of it? If so, check the fuse. If not, send it in for warranty service using our dolphin service form at www.arrowpools.net.
Posted on Jul 17, 2009
Why dose my red led light stay but tv will not turn on?
You either have a faulty main board or faulty power supply or power supply capacitors. If you are considering taking the set to a shop, I would advise against doing so. With the price of 32" dropping like a rock, it would be cost effective to purchase new. You could recycle the set or toss it on your local Craigslist as a parts unit and someone will buy it for sure.
Jun 08, 2014 | Samsung LN32C540 32 in. LCD TV
I had the problem of the flashing red light repaired by the local dealer here in Cyprus. However, after three months a similar problem occurred, except this time it is a flashing blue light. Has anyone...
the unit should have had the new power supply unit fitted, however in cyprus I don't know if that was available. I believe in the uk that after the repair there could be up to a two year guarentee, however don't quote me on that. If I were in your position, I would go onto the b and w web site, advise them of the red light flashing (again) and ask them how the best way to resolve the issue. If the main board or the amplifier have gone falty, they can cause the issue with the red light, however if the replacement power board was not the 'upgraded type' then the problem will come back.
contact b and w, (I would make them aware that you know that they have problems with the original power supply boards.)
hope this is of use.
Jan 17, 2011 | B&W Bowers and Wilkins Zeppelin iPod Music...
Three red lights flashing
Three red lights flashing means that there is a hardware fault.
Check your power supply light 1. Turn on your Xbox 360 console. 2. Take a look at the light on the power supply.
The power supply light is located on the end of the rectangular box in the middle of your power cord. If your power supply light is green
Solution 1: Check your power supply cables
Unplug and reconnect your power supply. Here’s how:
Disconnect the power cord from the back of your console. Unplug the power cord from the wall outlet and from the power supply unit
Reconnect the power cord to the console. Then plug the power cord back into the wall outlet and the power supply unit.
Make sure that all three power supply connections are firmly secured.
Turn on your console.
Before you perform solution 2, I would suggest you to go through following links.
http://support.xbox.com/support/en/us/nxe/kb.aspx?ID=907534&lcid=1033&category=hardware
and
Following link is an interactive troubleshooting link.
http://support.xbox.com/support/en/us/xbox360/hardware/console/troubleshootingconsoleproblems/flashinglights.aspx
Solution 2: Submit a console repair request
Your console needs to be repaired. There are no additional troubleshooting steps. To begin the online repair process, click one of the following links: I am a U.S. customerI am a customer outside the U.S.
This solution is absolutely FREE, so please rate and give positive feedback.
Thank :)
May 09, 2010 | Microsoft Xbox 360 Console
PS3 shuts off right as its turned on
Hi, this is heat related and, this issue may have damaged your power supply board. if the red lights continue to flash after you have unplugged this unit for 5 minutes, this will confirm power board failure and, you will need to replace this circuit board.
You can purchase a replacement power supply unit at this link below and i also advise to purchase a cooling adapter for your system as well. this will prevent this form happening again in the future.
CLICK HERE TO PURCHASE A NEW POWER SUPPLY FOR YOUR PS3.
CLICK HERE TO PURCHASE YOUR MEGA POWER MINI COOLING SYSTEM FOR YOUR PS3
May 23, 2009 | Sony PlayStation 3 40GB System
FLASHING RED LIGHT ON 360
Make sure that the power supply is cool loadTOCNode(2, 'whattotry'); The red light may indicate that the power supply is too hot or it has already overheated. If that is the case, you should let the power supply cool for several hours in a well-ventilated space. Turn off the Xbox 360 console and don't turn it back on while the power supply is cooling. This will allow the power supply sufficient time to cool. As soon as the power supply has cooled off, the power supply light will change from red to orange, and you can turn the console back on.
If the power supply light is still red after you have let the power supply unit cool in a well-ventilated space, the power supply unit may require replacement. You can contact Xbox Customer Support at http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to replace the power supply.
Make sure that the power supply is plugged in correctlyFor further details go to this link
http://support.microsoft.com/kb/906101/
Jan 03, 2009 | Microsoft Xbox 360 Console
Problems trying to get my ps2 to fully work.
Your power supply is not giving enough power to the unit. Get a new power supply and you will be fine.
Good Luck
Please rate FixYa!
Dec 19, 2008 | Sony PlayStation 2 (PS2) Console
Lrm 519
Had same problem. My fix was to repair power supply.
On power supply board replace capictors C18 & C36.
2200mf 10v rated 105C
Dec 25, 2007 | LG Electronics LRM-519 Digital Media...
Xbox360
Is the it the power supply red light?
The red light may indicate that the power supply is too hot or is overheated. Therefore, you should let the power supply cool for several hours in a well-ventilated space. During this time, you should not try to turn the console back on to allow the power supply sufficient time to cool. As soon as the power supply has cooled off, the power supply light will change from red to orange, and you can turn the console back on.
Also make sure the power msupply is plugged in correctly.
You could also purchase a new power cord.
Good luck
Mick
Nov 04, 2007 | Video Game Consoles & Games
Smart Pool Inc Dolphin Diagnostic Automatic Pool Cleaner Ne250 Logo
441 people viewed this question
Top Smart Pool & Spa Experts
Thomas Perkins
Thomas Perkins
Robco Water
Robco Water
Bill Boyd
Are you a Smart Pool and Spa Expert? Answer questions, earn points and help others
