Question about Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7
Hayward vari flo valve
I need to change the spider gasket in a hayward vari flo valve. The gasket won't come out. I assume it's glued. The valve is only 2 years old.How do I remove it and what adhesive do I use on the new one?
    President:
  • Hayward Master
  • 1,378 Answers
It will not be glued, it is just stuck in there good. You will need to scrape, pull, twist or otherwise convince it to come out as best you can and then clean the area well before installing the new one.
Posted on Jul 17, 2009
Replace spider seal in Hayward Vari-flo, do I just put new seal in or do I glue it in? Tks
no you do not glue it in. use a proper lube on both sides of the new spider gasket
Sep 16, 2013 | Hayward SAND FILTER, PRO SERIES
Hayward vari flo valve on filter also comeing out waste at same time
Yes, it is the "spider" gasket inside the valve that has gone bad. It needs to be changed out. They are not expensive. Go to YouTube and enter "change spider gasket" there are several videos. Good luck with it!
May 11, 2013 | Pool & Spa
Noisy Hayward Vari-Flo Valve Model 710xr50
I HAVE TO ADD MY TWO CENTS! THANK YOU TO THIS WEBPAGE- I had air and gurgling coming from my Hayward Variflo - I sealed all the leaks, and had crystal clear sight glass on my pump, but it still gurgled- I never in a million years suspected too much OUT flow- and it is the easiest thing to test- just cover one of the outputs to restrict the flow back to the pool, and listen- my noise died right down.
THANKS GROUP
Sep 16, 2012 | Pool & Spa
Vari flo handle not working properly
Which model year VariFlo?
  • Some model years do not take a spider gasket as there is spider gasket type bead molded into the diverter/key hub assembly.
  • Spider Gasket, raised bump should face up & gasket should be glued down down to prevent it moving.
  • Spring & nylon washers could also be bad.
Sep 11, 2012 | Hayward SAND FILTER, PRO SERIES
I have a brand new Hayward RS 2sp pump, new DE6020 filter and a new Hayward Vari-flo Valve / 6 positions. When I run the pump at low speed no water goes thru the waste line. When I run it at High speed,...
The spider gasket inside the 6-position valve is probably leaking. Take the model number of the valve to a local pool store and they can order a replacement. You will also need a special sealant to install the new gasket.
Nov 07, 2017 | Hayward SAND FILTER, PRO SERIES
Spider gasket problem
You are shutting off the pump prior to moving the valve handle, yes? If so, is the groove clean of any of the old gasket material? If both are yes, consider replacing the valve.
Oct 15, 2009 | Hayward SAND FILTER, PRO SERIES
If the spider gasket in the vari-flo valve is no good, you will usually notice one of two problems.
1. Water leaking out backwash port while filter is operating.
2. Valve positions are really difficult to change.
The way to check this is if you are able to move one or two of the "spokes" in the gasket freely(out of the track it sits in) once the top of the valve is removed.
If so you need to replace. The gasket is usually held in with a silicone sealant. Once you remove the old gasket. You will need to scrape any remaining rubber from the track it sits in. I've found that a brass brush from a pluming supply store or home depot along with a flat head screwdriver is usually enough to do the removal.
I always used Permatex Blue RTV sealant on all valve jobs. It can be found at any auto parts store or sometimes Walmart. Follow the instructions for curing. Once cured the gasket is good as new.
Jul 14, 2009 | Hayward SAND FILTER, PRO SERIES
Problem with vari-flo multipoer 1.5 and Hayward DE fiilter
You need a rebuild kit for the valve and possible a sand change. Sand should be changed ever 3 - 5 years or so depending on overall pool conditions.
The gasket inside the valve is out of place and therefore allowing water to leak out the waste port. Use a gokit to replace all the gasket/orings and you should stop the leak.
If the flow is still bad, inspect the sand and change it if necessary.
Jun 26, 2009 | Hayward SAND FILTER, PRO SERIES
Control Valve handle wont stay in position
The valve should be about $100. We sell it for 90 something. You can rebuild them with gaskets and the spring. There should be a model number on yours, care to post it? Something like SP711, SP714, etc.
www.arrowmotor.net
May 29, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7 Logo
979 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
