Garden Logo
R
Rob Tyloch Posted on Nov 29, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
One day after blowing i had to refill gas and the blower stopped and hasnt started since.
I have changed the plug, gas and even put on a new ignition coil still no go
  • Rob Tyloch
    Rob Tyloch Nov 29, 2015
    yea i should of put that i checked all that too oh and its a Roybi RB42 backpack blower
Rod Doney
Level 3:
  • Master 588 Answers
  • Posted on Nov 29, 2015
Rod Doney
Master
Level 3:
Answers
588
Questions
Helped
179372
Points
1953
One thing you can check is the vent filter to the tank. It allows air in but no fuel out. It prevents vacuum lock. It is a hose attached o the tank. By the way, des the bubble primer work? If not that may be the problem as well.
  • Rob Tyloch
    should od added those checked too oh by the way its a Roybi RB42 backpack blower
  • Rod Doney
    Rod Doney Nov 29, 2015
    Hmm. If its got gas and spark, compression,its gonna take some looking.
My husqvarna 125b blower wont start
I'm sorry to hear that your Husqvarna 125B blower isn't starting. Here are a few things you can try to troubleshoot the issue:
  1. Check the fuel level in the tank. If the tank is empty, fill it with the correct fuel mixture (50:1 ratio of gasoline to oil). If the fuel is stale (more than 30 days old), drain the tank and refill it with fresh fuel.
  2. Check the spark plug. Make sure the spark plug is clean and properly gapped. If the spark plug is dirty or damaged, replace it.
  3. Check the air filter. A dirty air filter can restrict the flow of air, causing the engine to run poorly or not start at all. Clean or replace the air filter as needed.
  4. Check the carburetor. If the carburetor is dirty or clogged, it can prevent the engine from starting. Clean the carburetor or have a professional service it.
  5. Check the ignition system. If the ignition system is not functioning properly, the engine may not start. Check the ignition coil, ignition switch, and any other related components to make sure they are working correctly.
If you have tried these steps and the engine still won't start, it may be necessary to take the blower to a professional for further diagnosis and repair.
Why can't it be started?
You have a fuel flow issue if the plug is dry. Put the choke on and pull it numerous times to try to flood it and see if it floods. If it doesn't than you have a blockage somewhere between the fuel tank and carburetor
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Jan 16, 2016 • Garden
After i changed the ignition switch in my 1983 cadillac now the horn wont stop blowing
did you removed the steering you might have grounded the wire for the horn , it works on a ground system i would check the wire again and make sure it's now shorted
1helpful
Want start
chech small gas filter in tank, take it out , blow through it, if you canr blow through it replace it
2helpful
2answers
Briggs & stratton engine stops working - died and won't start
It sounds like it is time for a new ignition module. Get the model, type and code off the blower housing and go to www.precisionope.com. There you can look up the ignition module under OEM parts.
Jan 03, 2010 • Garden
1helpful
I have a Weedeater FL1500. I just changed the
Once it heats up either the spark plug or the ignition module is breaking causing them not to work. I would first check on the price of the ignition module, Then decide it is to expensive to repair and send it to the scrap man.
Good Day.
Ran great sat. but would not start sun. same gas changed plug air filter gas soaked with it off still not running tried putting gas in spark plug hole still not running this is a craftmans 2 cycle leaf...
Were you running a fuel mixture of 40:1(3.2 oz of 2 cycle oil to 1 gal of gas), that you mixed up before you started using it again. The unit may have had to much use on Saturday and may be burned up. Try to have a compression test done on the engine, needs to be at least 100 psi to run. If that proves to be good then you can start looking at Fresh gas mixture, a new spark plug, Carburetor rebuild or an ignition module.
HTH
Good Day.
Oct 26, 2009 • Garden
1helpful
Unable to start my 155BT blower. Have changed
Is the new spark plug wet? If not, the machine is not getting fuel (fuel filter, carb, etc.) If the plug is wet, you may not be getting spark (bad ignition module, short in switch/harness, bad plug (yes it does happen with even new plugs)), or flooding due to incorrect starting procedure or clogged airfilter. Stale fuel can also cause an engine not to start as it lacks volatility. If in doubt, take it to your local dealer.
Top Garden Experts
Jay Finke
Jay Finke
john h
