Question about Dometic Rooftop RV Air Conditioner
. Fan or Compressor will not come on
I have a portable 10000 btu air cond.The display works and the directional louvers work but thats it . I checked capactior its 40uf I'm reading 39uf.I've checked the fuse on the circuit board and the house panel breaker is not tripping.There is low hum coming from the unit and when I push the buttons on the front of the unit makes little clicks. For cool /fan or fan speed and the temp is displayed.
thanks for the help.
    Champion:
  • 233 Answers
It sounds like you may need a circuit board, the clicks are genrally the relays on the board calling for the components they control, it is possible for the contacts to "burn" open and not provide a path for the electriciaty to the compressor and fan., the capacitor is fine and the tolerances are +or- 10%
Posted on Jul 15, 2009
My kenmore 12000 btu portable air conditioner keeps switching to DH mode out of AC mode
That means that it is dehumidifying. Is the air coming out still cold? I assume you have tried using the mode button to switch it back? Is the air extremely humid? Perhaps it is humid enough that the machine needs to dry the air before safely operating as an AC. The manual is available here:
http://www.sears.com/kenmore-portable-room-air-conditioner/p-04272012000P
Jul 05, 2015 | Kenmore Portable Air Conditioner 10000 BTU...
The compressor in my whirlpool stand up air conditioner is running fine but will only cool for a few mins then the cooling stops and the fan just blows. Any ideas?
If it is a capacitor start and run type, suspect the run capacitor. If not, suspect the start relay stuck or compressor on it's way out
Aug 07, 2012 | Whirlpool Heating & Cooling
Sunbeam portable air condition..all things work..compressor runs..but now cold air sunbeam portable air conditoner mode KY25 ..9,000 btu I have it since 2005..I've used it for one year..it's been...
sometimes storing an AC for long periods of time will allow the coolant that it uses to seep out, leaving you with an AC that seems to work, but won'tr cool any air. If you have a user's manual (or can find one) check to see what type of coolant it uses (if it's freon or something else) and if you can refill it. If you can refill the coolant, that should resolve your problem ... if not, you might be able to take it to a repair shop and have them do it for you. Good luck!
May 29, 2011 | Sunbeam SCA082RPC1 Portable Air...
I've had this maytag 10000 btu slider casement air conditioner for approx 3 years. its installed in a window & has been used possibly 10 times. the fan motor comes on, however there is no cooling...
Check the thermostat, does it open and close (electrically)?
In the past three years, has the unit been cleaned? If the coil is plugged with dust, there may have been serious damage to the comressor.
With the unit unplugged, using a multi-meter, is there continuity between the switch hot tab and the compressor feed?
Is there a run capacitor on the compressor? If so, is it shorted or open?
These will give you a few places to start. If you do not know how to operate a multimeter, you need a contractor. Another option is to check your phone book and look for an local refrigeration school. Often, these schools will do the repairs if you pay for the parts.
Jul 19, 2010 | Maytag 10000 BTU Slider Casement Air...
Condenser Fan not working when the Air Cond is On.
There is a high pressure switch on the high side of the ac system,it most likely is bad.
Apr 06, 2010 | 1996 Mercedes-Benz C-Class
Air cond dash light works, compressor doesn't go on.
AC's have a low freon switch that shuts off the system to protect the compressor in the advent that you have a freon leak have the system checked for a leak
May 28, 2009 | 1996 Toyota Camry
LG 10,000 btu air conditioner
I just bought the LG 10000 btu window model... I am having the same exact problem.. it feels like the air is not even on.. I am having someone look at it on Mon. I have a feeling the whole unit is defective. But it could be the thermostat needs to be replaced. Sucks 300 dollar brand new AC and it doesnt work!! Good luck. I will never buy LG again.
May 24, 2009 | LG Electronic Window Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
130 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
