Question about Cannon 10476G Dual Fuel (Electric and Gas) Kitchen Range
Ive got a calor B700 cooker any ideas where i will fine the pipe that i need so i can conect gas to thank u
2 Suggested Answers
  • 2557 Answers
SOURCE: calor gas and cookers
Hi you will need to check the pressure on the reg and it sound s like the burner neededs cleaning the air ports a blocked but if it is sooting get agas fitter to look at this problem don't use the oven untill this fixed .
Posted on Jan 19, 2010
I have a caloric oven, prestige series. Don't know model. it is about 15 years old. last year the oven wouldn't heat and smelled gas. That was repaired. Now, oven ignitor comes on but oven...
The ignitor is bad again,if it (ignitor) comes on but no flame/heat its the ignotor again, what would make the ignotor go bad so fast (usually last 10-15 years) is a problem with the oven burner, so now BOTH the ignitor and burner would need to be replaced,if it is 15 years old the ignitor is readily avaliable but the burner may not be
Gene
Aug 04, 2011 | Ovens
I have Terim Duel Fuel range cooker which at the moment can only be used by bottle gas/calor gas and not mains gas. Is there anyway it can be adapted to be used for mains gas?
you have to change the jets to the "mains" gas, usually these are found inside the back cover of the oven, sometimes it is only a wrench adjustment on the gas valves theselves.. look in your manual on how to do this, and if you don't have the manual, you will need to order it from the terim company
Mar 11, 2011 | Ovens
I want to install a richmond 1000df range cooker on a peninsula kitchen unit. there is a gas pipe which comes from under the floorboards to the location. Is this going to be possible? ive heard you need to...
You must , by law be a registered Gas Safe Engineer to connect this cooker to the gas point , they will also chain it for you. You can find a Gas Safe engineer at www.GasSafeRegister.co.uk then , enter your postcode in the required box and you will be given a list of Gas Safe engineers in your area or ring freephone 0800 408 5500 to get this information .
Apr 06, 2010 | Stoves 1000DFDL Dual Fuel (Electric and...
Need to know if my cooker is a bayonet fitting
the bayonet fitting is on the end of the gas pipe that plugs into the gas main. look at the back of your cooker follow the black pipe you will see a brass end that fit to the solid gas pipe if you have a ring on the end of you flexible pipe that you can push in slightly and turn to disconnect you have a bayonet. its not the cooker that is a bayonet but the flexy pipe that is connected to your cooker. you can add one if one not fitted
Feb 02, 2010 | Belling Solitaire G755 Gas Kitchen Range
I have a Caloric Heritage Series gas stove in which the oven will not light but the broiler does work. This stove has a analog clock and we have no idea what the model is. Please help us. Thank you,...
We replaced the igniter which I bought from the appliance repair service. We now have a working oven.
Thankyou for responding to my email.
Cheryli
Dec 29, 2009 | Ovens
Calor gas and cookers
You need a C.O.R.G.I. (soon to be re-named "gas safe" in april) engineer qualified for LPG to sort this.
Jan 04, 2009 | Cannon 10476G Dual Fuel (Electric and Gas)...
Low flame
the best way is to get a gas fitter to check the millibars coming through the pipe. it should be 20 miliibars at the meter or more and not less than 19millibars at the cooker. if its less it needs bigger pipe. simple test to do. if its wrong at the meter the gas supplier must turn it up.
Dec 04, 2008 | Rangemaster 110 (Gas) Kitchen Range
Low Gas Pressure on Smeg Range cooker
there should be a regulator on back of the stove where the gas line connects.you will see a plug that unscrews,remove this plug and run the unit.if this solves your problem clean the plug really good and put back on.
Dec 25, 2007 | Kitchen Ranges
Soot is forming on my gas fire. it is fuelled by lpg. ive tried using calor gas instead of a cheap gas but its still the same . help` its driving me potty !!!!!!!!!!!!!!!
the range is not converted or converted proberly to lp gas. they are sold to be used with natural gas and needs to be converted to handle lp
Oct 26, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Open Questions:
Cannon 10476G Dual Fuel (Electric and Gas) Kitchen Range Logo
98 people viewed this question
Top Cannon Kitchen Ranges Experts
Paul Carew
reyaazm
Level 1 Expert
Tom Chichester
Are you a Cannon Kitchen Range Expert? Answer questions, earn points and help others
