Question about Refrigerators
Whirlpool fridge freezer works fine but fridge is getting warm ...bottom mount freezer, any ideas
  • 473 Answers
Re: whirlpool fridge
3 things can cause this:
1) Inoperable fan in the freezer.
2) Defrost problem (frost build up on back panel in the freezer)
3) Damper inoperable (vent in the fridge section)
Look for these symptoms and let me know what you find.
Posted on Nov 17, 2007
0 characters
3 Points
Fridge is always getting warm
just wondering have you moved in those five years and if so have the lines of the compressor be damage?? it sounds like that the compressor is losing its charge. please let me know. also make sure that you have removed all the lent and dust around the compressor.
Jun 15, 2009 | Whirlpool GB2SHDXP Bottom Freezer...
Refrigerator will not get cold, but freezer works
Make sure your fan is working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked (usually with ice).With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open untill all traces of ice are gone this will free up any clogged tubes. Good luck.
Len West
Feb 27, 2009 | Amana ABB1927DE Bottom Freezer...
Whirpool fridge is warm, freezer is working
Check the back wall of the freezer compartment for ice buildup. Sounds like you have a defrost issue.
Feb 22, 2009 | Whirlpool GB2SHDXP Bottom Freezer...
My amana bottom freezer won't cool both the fridge and freezer are warm
I just had the same problem with the same fridge. When I removed the inside panel in the freezer, I found that the cooling/circulation fan had fallen due to the mounting screws having rusted off. I removed the fan housing to get the screw ends out from the back side and remounted the fan with new screws. The fridge and freezer both work fine now and I'm assuming it will for many more years until it happens again.
Nov 04, 2008 | Amana ABB1927DE Bottom Freezer...
Sears Kenmore bottom freezer/refrig #68142model
just called in a sears technician 150 dollar bill that was an easy fix. he says my bottom freezer kenmore fridge with warm fridge problem was due to the pathway being blocked by ice and garbage which is common with these fridges. he took off cover from the fridge bottom and poured boiling water down to the freezer. try that before you replace any parts or call in a tech. next time im getting a top freezer because the blower is on the top not in the middle with the bottom freezers and thus more problem prone.
Jul 20, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Sub zero freezer too warm
I believe the freezer has to get down to 7 degrees or lower for icemaker to harvest. Clean your condenser and blow it out. If that doe not fix it you will need service for sealed system
Apr 15, 2008 | Sub-Zero 700TCLH Bottom Freezer...
Bottom mount freezer not getting cold enough
You have a failed component or components in your automatic defrost system. This is why you have excessive frost inside the freezer along the back wall. The timer could be stuck in run mode. The defrost thermostat (bi-metal) could be defective or the defrost heater could be open or shorted.
Sep 18, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
236 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
