Windows wont load
Computer starts to load, then instead of starting up, reboots. Tried starting in safe mode, does the same thing. Any idea's how to get to a restore point?. BTW no idea what happened. I was at work and wife said the 4 yrold and 19 mo old where pushing buttons. Yippie!
  • 1,272 Answers
Run the recovery CD.
It should help.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Jul 14, 2009
My hp tx2 tablet pc turns into safe mode and running so slow
Follow these guidelines:
1. Turn a power-off computer on or reboot a running computer.
2. Quick press the F8 key on keyboard before Windows starts, after hearing a beep sound you will be taken to Windows Advanced Options Menu instead of the normal loading page. If it doesn't work on the first try, just reboot and try again. And Select normal loading option.
Fix windows internal errors and corrupt registry to avoid such types of errors in future. I would suggest to use system utility tool Reginout.
Jan 17, 2013 | HP TouchSmart tx2-1270us Tablet PC
Sylvania netbook synet07526 - - - cant remember my password. how can i reset the system? have tried holding down the reset button multiple seconds but the reboot does nothing but come to the password...
Resetting password & user name on Windows: b>*Start your computer
*Keep pressing "F8" as the computer starts.
*This will enter the computer in Safe Mode.
*(When the window "Advanced Boot Options" opens, choose "SafeMode" with arrow key and confirmby pressing the Enter key, then computer enters Safe Mode.
*Once you are in the Safe mode Click "Administrator" on the Windowslogin screen.
*Take note that you have set the Administrator password before, you need toinput the changed password instead of leaving "Password" field blank.
*Then click Start > Control Panel > User Accounts > Select the accountthat is locked and change the password.
**Restart computer and login into the account you just created using your newpassword.
Sep 24, 2011 | Sylvania G-Netbook
Wont get past Microsoft Windows XP loading screen on Acer Aspire1
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 17, 2010 | Acer Aspire One AOA150-1126 Notebook
Unit wont start, gray screen then goes to a screen with options on how to start unit and then goes blank
Answer:To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key.
Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message as the computer is booting. If this occurs instead of pressing and holding the "F8 key" tap the "F8 key" continuously until you get the startup menu.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows.
Will running the Last Known Good Configuration delete anything?
No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Jan 27, 2010 | NEC Versa VX Notebook
Can't get computer out of safe mode
From Windows Safe Mode click Start / Shutdown and restart the computer. This should start the computer automatically back into Normal Mode.
Note: Many users believe that they are still in Safe Mode because the colors or video may not look correct. Unless in the corners of the screen it says "Safe Mode", you are not in Safe Mode.
If you are rebooting the computer and it is rebooting back into Safe Mode (it does say "Safe Mode" in each of the corners), it is likely another problem exists with Windows preventing it from loading into Normal Windows.
If this does not work try: http://www.computerhope.com/basic.htm
Dec 30, 2009 | Compaq Presario Notebook
XP wont load in safe mode
MAY BE DUE TO LOT OF VIRUSES. DISMOUNT YOUR HARDDISK FROM YOUR SYSTEM AND SCAN IT FOR VIRUSES IN ANOTHER SYSTEM WHICH HAS THE LATEST UPDATE OF A POWERFULL ANTIVIRUS SUCH AS KASPERSKY....
Sep 23, 2009 | Microsoft Windows XP Professional With...
COMPUTER GOES TO COPYRIGHT PAGE NOT WINDOWS
Push F8 before the splash screen loads - start pushing it the moment you start your computer. You should get a screen that allows you to start in safe mode. Once you've started in safe mode, try rebooting and see if you computer comes up normally.
Apr 04, 2009 | Compaq Digital PC 3100 PC Desktop
I have an acer travelmate 252LC_DT which whenever I start doesn't load the operating system and just displays a blank screen. Prior to this the Micro-antivirus 2009 virus was located on the laptop and I...
ok my friend as you said the operating system is not loading any more so that means we are having some corrupt files that makes the windows to fail while trying to boot up.
and since you cannot even log in to the computer even in safe mode that means you have only two options.
first is to try a repair (most of the computers use F12 key to get to the repair counsel).
second reinstalling windows.
so try the first one if it doesn't work then reinstalling windows will be the last thing to do.
if you need and further help please let me know
cheers
Sep 18, 2008 | Computers & Internet
My computer is rebooting over an over ....dont have time to do anything....now i open my computer on safe ....mode what should i do??? i have window xp
If your computer fully loads Windows, than starts a restard process you are looking at having an annoying virus. Since there are several different viruses that can cause this problem, if this is the reason for the restarting, you would be best off loading Windows in safe mode (using the F8 key before Windows starts to load will give you a menu with options like SAFE MODE) and than trying to scan it for viruses.
If your computer doesn't actually load Windows, but restarts after the Windows loading screen, you could have a corrupt driver causing Windows to restart. If your computer were slow, you would see the error message, faster computers go through the error screen too fast. The best way to determine this would be to start in SAFE MODE and see if the same problem exists.
Let me know what happens after you start in SAFE MODE. 6 Pts Rate Answer
Jul 09, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
