Question about Maytag Washing Machines
Maytag A806 washing machine leaking from the center,under the tub
My 36 year old machine leaks from the center, under the tub when we wash a ''normal'' or ''large'' load. It doesn't leak when washing a ''small'' or ''medium'' load. It leaks when the water is draining from the machine. Could it be the mounting stem and boot seal that I need to replace? What do I need to take apart to get to it and how do I replace it?
    New Friend:
The tub seal is bad.
I had the same issue on another model.
You can attempt to repair this yourself. I suggest that you do a search on Youtube to see if this is a job you want to take on. It took me 2 hours to change mine. The seal kit and tools are sold online.
Good luck.
Posted on Sep 28, 2017
Jimster
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
  • 96 Answers
SOURCE: washer leaking water on floor
Need to check drain pump and its hose connections. If its not from the drum seal then that's usually where the leaks occur.
Posted on Mar 31, 2008
SOURCE: My top load whirpool washing machine leaks during spin cycle.
it only does it on the small load? does the water drain out before it goes into spin?
Posted on Nov 14, 2008
SOURCE: water leaking under washing machine
Had service technician come out to inspect. Problem determined to be the bearing and seal/belt. Estimated cost $350.00. It cost $450 when new....Went out and purchased a Speed Queen. Hope to have better luck.
Posted on Dec 31, 2008
  • 262 Answers
SOURCE: tub seal repair
If you are talking about the front door boot seal it is not a fun thing to do but to replace the boot you have to remove the front cover by using a putty knife on each side once you have removed the pretty cover you need to remove the front door and the door boot from the door then the front panel 5/16" screws usually the cover usually wont come off all the way so you have to work around it it will come off but you have to finagle around under the top cover to get the screws.once you doo all this you have to pull the old boot from the tub. now going back with it is the fun part the boot locks on to the tub with a locking lip and if it dont lock it will come off while putting spring back on.Once you have the boot locked with the lips you have to put the wire spring into a groove and then put on the spring you you are able to get this far you are doing fine.after putting spring on pull alittle on the boot to make sure it is secure.If it is put front panel back on ,secure boot on the lip to the door and put on pretty cover then leak check.BUT GET READY TO SAY SOME UN GODLY WORD THIS IS NOT A EASY TASK AND IF YOU HAVE NEVER DONE THIS BEFORE PLAN ON A DARN NEAR WHOLE DAY JOB GOOD LUCK and let me know how it goes
Posted on Jan 08, 2009
We have a Maytag top-loader model A482 which is probably 25 years old. I found water on the floor under the machine when the last load finished washing. What's the first place to look for the leak? I'm...
The most common thing that will cause a leak is the tub seal. If the tub seal is leaking water will be comming from the center of the tub where the transmission meets the tub. This page will show how to replace the seal. http://appliance-repair-it.com/Maytag-tub-seal.html
There is also an air-gap that will often leak. If this is the case the water will be comming from the left hand side at the top. The air-gap is in line with the water inlet. This page will tell more http://www.appliance-repair-it.com/Maytag-washer-leaking.html
If they are not the problem you will have to look for a leaking hose or something to that nature.
Sep 28, 2010 | Maytag Washing Machines
I have a maytag Atlantis washer - 7 years old, it
I have a Maytag Atlantis top load washer which leaks in the rear right hand corner under the discharge hose, how do I take the machine apart to get to the problem.
Feb 04, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer top loading leaks water seems to be coming from the tub itself 7 years old thank you mija
does unit leak constant or only when spinning ther are 2 screws done low on front panel fill unit with water and watch center shaft there is a seal below basket
inside washer changing seal is a little difficult have also had this style of washer leak when starting spin cycle if water has not drained out fast enough
http://www.repairclinic.com/Washing-Machine-Top-Load-Maytag-Style-Appliance-Diagram
this page has a break down of normal maytag top load machine part at center is called boot and seal have also had thi type unit leak where bolts go through tub
good luck ron
Dec 12, 2009 | Cameras
Leaking maytag
it could be the pump but there is a seal in the tube where the transmissin goes through the tub that seal has a common problem of leaking but if it 10 years old i would replace the machine
Jun 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Machine is usually very noisy ( like it was out of balance, but isnt) 90 percent time very noisy in the final expell of water, also some oil on the floor under center of machine ? this is a top load...
oil on the floor means your gear box is leaking
if it has been leaking. if it has been leaking for a while, it may have done major damage,and would be cheeper to replace the machine second hand than to fix.
if noise is happening while you are pumping , it may have a bra under wire or small coin in the water pump.
if it is sounding like it is out of balance it may have a support or spring broken or unhooked
as the tub is usually suspended by springs
May 05, 2009 | Maytag MAT12CSD Top-Load Coin Operated...
Oil leak from bottom of maytag neptune tl - about 4 years old
sounds like seal leak in tub water is leaking onto drive unit and washing over it bring and oil it can with it couls be big bucks some parts may be under warranty call service but be sure to get estimate first
Nov 27, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Performa PAV2300 washer leaks
Hi hindsr
I dont know for sure what it is but i would guess that the tub is going off balance during the spin just befor the rinse and the tub is not centered. so what happens is watter hits the top of the tub and runs down the back (inside) and thats where the water is comming from.
brent
Sep 22, 2008 | Maytag Performa PAV2200
Tub leaking from center of tub under the aggitater
This type of leak indicates a failed tub seal and bearing. Replacing is time consuming, can be difficult and requires special tools to disassemble.
Jun 15, 2008 | Maytag Washing Machines
Legacy leaked on floor and subsequently ruined gararge ceiling. I put a wash in yesterday, filled it shut it off and left it soaking. I returned home from my errands three hours later to an 3/4 empty SS...
Its most likely the tub seal at the bottom, check and see if the area inside is wet in the middle. You will need to remove the outer panels to do this. It doesn't sound like anything else if the water was left to sit so a replacement of the seals around the center shaft should fix this problem. Let me know if you have any questions about doing this and I would be happy to help.
Jun 04, 2008 | Maytag Legacy Series Top Load Washer
Maytag Washing Machine Problem
yes it does sound like a bad timer
Nov 25, 2007 | Washing Machines
Washing Machines Logo
256 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
