Question about Dell Dimension 4600C PC Desktop
Heat sink well it fell off looking inside one of the loops hold down is missing what now
    Problem Solver:
  • 18 Answers
The heatsink needs to be clamped down to the cpu. if there is a clamp missing i would not use the pc until it is replaced.
Posted on Jul 14, 2009
Stopper no longer stays in up position on my bathroom sink
Solution to the most common design...
If you can pull the stopper completely out of the drain with no resistance, do this.
On the back side of the tailpiece that attaches to the bottom of the bowl, there is a rod coming out of the back side that has a nut holding it in. Unscrew that nut and pull the rod out part of the way. There usually is a loop molded into the plastic on the lower end of the stopper where that rod inserts into. Turn the stopper until that loop is aligned toward the faucet and insert back into the drain but not all the way (keep it held up about 1/4-1/2 inch from completely closed). Reach under the sink and feel for the rod while you are holding the stopper in place and push it back in while you "feel" for the loop. You will know it is inside the loop when you can't pull the stopper out with not resistance. Screw then nut back onto the threads and finger tighten it until it has enough friction to hold itself at any position.
Hope it helps...
Oct 02, 2013 | Price Pfister Plumbing
Chipset heatsink workstation 670
Open your computer and I bet you will find a piece of metal that is a heat-sink just rolling around inside. Probably fell of of the video chip.
Apr 08, 2012 | Dell Precision Workstation 670 PC Desktop
When i start up the xbox it has no video, only sound.
Its possible for you to fix the problem your self.
how ever the fix may not last long .
Ok hear we go
find a video on how to strip the box down to the P.C. board.
pull the board out of the chaise by the small heat sink only
do not disturb the big heat sink at all or you will break the
seal an get 2 reds ( over heating)
Now that you have the main board in your hand
flip it over a carefully very carefully pry off the x clamp
bracket holding down the small heat sink for the G.P.U.
remove the heat sink from the board ,take out the four
studs under the heat sink . clean the gray heat sink off
the top of the two chips with rubbing alcahole ,do the
same with the heat sink then apply some heat sink compound
to the chips place the heat sink back on the chip
get four 10-32 by 3/8 long and EVENLY screw down
the heat sink Not too tightly ( snug not tight) .
Put the unit back together ,leave out the white fan
shroud plug everything back in and leave the fan
hanging out .
Now plug in the power and a/v cable place and hold
the fan over the Large heat sink for C.P.U. and turn on
the power .I should take 4-5 min till the fan gets up
to full then another 3-5 min to over heat Two red light
be ready to unplug the second this happens .
let it cool down for about 15-20 min and you should
have restored your video feed. I cant say how
long it will last .
if you have any questions feel free to email me
Rob
Take some heat sink compound
that you can buy from raido shack
now that that you have the main P.C. board in your hand.
Sep 18, 2009 | Microsoft Xbox 360 Console
I have a Kenmore dishwasher that seems to leave a bit of water inside. Model 3631435598. Is this normal finish mode? Seem the water would get stale. I have no manual can anyone help with either ?
Hi Doc!
You know? If I had to postulate an educated guess, I'd wager that your dishwasher's (DW) drain hose isn't hooked up properly under the sink. When it's not hooked up right, water from the sink will siphon down into the DW making you think that there's a problem with the DW when in reality the problem is elsewhere. Kinda tricky, huh?
Anyway... I put together some photo's that show the incorrect installation and the correct installation of DW drain hoses. Check it out.
The downward sloping hose allows water from the sink to go to the DW.
The "loop" (actually called a "vacuum break") won't allow water to go to your DW.
Here's a schema of the layout...
So the drain hose from the DW always has to loop upwards to keep gravity from weilding its' wicked hand and drawing water down to the inner most depths of your dishwasher.
So, that's the first thing to check, Doc. (<---- that was my Uncle's name, btw. He owned and operated a microwave repair shop back in the late 70's.) If you find the hose under the sink looks like the first pic, just loosen the clamp, pull as much slack from the DW as you can, form a loop like in pic #2, tighten the clamp (to hold it in place) then tie off the hose to a stationary location (like the hot or cold line feeding your faucet)
There ya go! Fixed! Ain't it cool? How easy was that? What about 20 minutes? Maybe less? All you needed was a 5/16" nutdriver and some tape! Too cool.
Don't forget to rate me, OK? My self esteem is counting on you.
Oh! If you find that the drain is properly installed, let me know. We'll go deeper into the solution, OK?
SG
Jun 07, 2009 | Kenmore 15762 Dishwasher
Upgrading the cpu and heat sink and fan
All the factory fitted CPUs are having such heat sinks as previously u were having.
Check on the backside there will be small plastic covers where screws fit these could be removed by screw driver but u can purchase that heat sink or can use previous heatsink as well if it is working.
Feb 26, 2009 | Intel Socket 775 Heat Sink and Fan up to...
Heat sink fell off processor
Go to your local Staple,Radio Shack or Best Buy and get a new heat sink and fan assembly, if you are lucky it will thread through the motherboard so you can reset it onto the processor chip. DO NOT PUT SUPERGLUE ON THE PROCESSOR.
AND DO NOT RUN COMPUTER WITHOUT HEAT SINK AND FAN IN PLACE OR ELSE>
Dec 23, 2008 | Compaq Presario 5000 PC Desktop
K8S-LA mobo heat sink fell off.
That is the 'Northbridge' chip that provides the I/O interfacing for the main chip. The heat sink is normally held on with glue as you surmised, and should be re-done with a thermal conductive glue. The glue (a silver filled epoxy) is available from MCM electronics or from Mouser. Be sure to thoroughly clean the chip and heat sink before re-gluing.
Sep 01, 2008 | ASUS K8S-MX SIS 760GX CHIPSET SERIAL...
Heat sink fan P4VMM2 v 3.2A
Which one of these CPU's are you using?
Jun 17, 2008 | Pioneer ECS P4VMM2 V3.2A P4(478)/FSB...
Heat Sink Fan fell off
Any Pentium 4 fan will do. The pc will not boot without a CPU fan plugged in.
Jun 17, 2008 | EliteGroup P4VMM2 Motherboard
Alert chipset heat sink not detected system halted error message
This is a relatively common problem in the Dimension 4600c. The small, fan-less heatsink for the Northbridge chip (a memory/video-to-cpu communications chip) is held down by a spring, which is anchored by two small wire loops soldered to the motherboard at locations marked "HS2". The spring completes an electrical circuit between the two wire loops. The spring puts a substantial force on the minscule bit of solder holding the loops to the motherboard, and was a poor design.
If a loop breaks off, the circuit is broken, which tells the BIOS that the heatsink fell off. To fix this, you need to 1) secure the heatsink to the chip, and 2) reconnect the circuit between the two "HS2" locations on the motherboard. I have sucessfully used this solution. This solution will not necessarly stand up to a lot of abuse if the Dimension's enclosure is frequently opened and closed to replace other components such as RAM and hard disks.
0) unplug the computer.
1a) Recover the heatsink, spring, and loose wire loop. Discard the spring. Get:
- a fresh tube of thermal paste from Radio Shack or other electronics supply store,
- some epoxy,
- a round toothpick,
- about six inches of insulated 14 to 20 gauge solid copper wire,
- electrical solder, flux, and a soldering iron,
- and a box of cotton swabs.
1b) Using pure alcohol and lots of cotton swabs, clean *all* of the existing thermal paste off of the Northbridge chip and the bottom of the heatsink. When both are dry, apply a dab of paste to the center of the Northbridge chip. Use a round toothpick like a kitchen roller to spread the paste evenly across the small raised center square of the chip.
1c) Apply small daps of mixed epoxy just outside of the four corners of the raised center of the Northbridge chip. Place the heatsink onto the Northbridge chip, centering and squaring it as best you can. Press firmly to make good contact with the thermal paste. Allow epoxy to dry.
2a) Firmly seat one or both detached wire loops into their mounting holes at the "HS2" locations. While pressing down on the loop, apply a small dab of epoxy to one end of the loop to secure it to the motherboard. Allow epoxy to dry.
2b) Strip the ends of the copper wire, and bend the wire so that it can reach around (rather than over) the heatsink to the two wire loops. Solder the ends of the wire to each loop. Knowing how to solder is an exercise left to the reader. "Use head main ting": don't drip solder onto the motherboard.
You can now plug in the computer and restart. The BIOS and/or OS may have saved the error state and return a different message about the heatsink issue. You may need to reboot a couple of times to allow the BIOS to notice that the "HS2" circuit is (hopefully) now complete. When you've sucessfully booted the machine, shut it down and gently close the Dimension's enclosure.
May 21, 2008 | Dell Dimension 4600C PC Desktop
Dell Dimension 4600C PC Desktop Logo
153 people viewed this question
Alun Cox
