Question about Baby Gear
Hi, i have marshmallow smeared on my car seat and i havent touched it as i would like to know the right way of cleaning it.could you please help me. robyn
I know how to fix it!!! all you need is a pair of tongs boiling water a towel and a possitive attitude! just boil the towel PLEASE USE THE TONGS to put the really hot towel on the seat over the fluff let it sit for a sec to let it warm up. then just scrub it off with said towel. :3
Posted on Aug 04, 2009
How do I exit ODIN MODE from my SAMSUNG GALAXY J1 mobile
Once you are in the main recovery mode menu please press "Reboot to bootloader" to enter into "Download Mode".
So now you know how to enter into download mode/Odin mode on your Galaxy Marshmallow Smartphone, but how to exit the from download mode, for that please continue reading.
How To Enter and Exit Download Mode In Android Marshmallow Galaxy...
Jun 10, 2017 | Samsung Cell Phones
What does the seat belt light look like in a vauxhall zafira sport 2007 model look like
Shown here. A person sideways being attacked by a giant marshmallow.
http://www.drivingtesttips.biz/vauxhall-zafira-dashboard-engine-warning-lights.html
Mar 16, 2016 | Seat Cars & Trucks
Smudged horizontal lines
Try cleaning your rollers, it worked for me. I hope this helps.
Feb 13, 2013 | Canon Pixma MX410 All-In-One Printer
Ive pushed button and straps on my maxi cosy cabrio car seat will not loosen, help??
Hi
When you press the silver / grey button at the front of the carseat you should pull both harness straps at the same time and it should loosen the harness. If this is not happening the carseat needs to be inspected. Please contact your retailer with proof of purchase if it is under 12 months old. Alternatively please let us know what country you're in and we can put you in touch with the correct customer care team to assist.
Jul 06, 2012 | Maxi-Cosi CabrioFix (Black Reflection)...
Smear on right side of paper entire length of paper all colors
Follow the below instructions to clean the printer through the control panel:
  1. Press MENU to enter the MENUS .
  2. Press (Down arrow) to highlight CONFIGURE DEVICE .
  3. Press (Select) to select CONFIGURE DEVICE .
  4. Press (Down arrow) to highlight PRINT QUALITY .
  5. Press (Select) to select PRINT QUALITY .
  6. Press (Down arrow) to highlight CREATE CLEANING PAGE .
  7. Press (Select) to select CREATE CLEANING PAGE . A page with a pattern prints from the printer.
  8. Remove all paper from Tray 1.
  9. Remove the cleaning page and load it face-down in Tray 1. NOTE: If not still in the MENUS , navigate to PRINT QUALITY using the above instructions.
  10. At the printer control panel, press (Down arrow) to highlight PROCESS CLEANING PAGE . This option will only be visible in the menu when a cleaning page has been printed.
  11. Press (Select) to select PROCESS CLEANING PAGE . The printer control panel displays the message Cleaning... . The cleaning process takes a few minutes.
let me know ....
If I could be of further assistance . If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 26, 2010 | HP Color LaserJet 3500 Printer
Lexmark x4270- Can't find manual. Shows error 1203. How can I correct this. Thanks
Hi
Error 1203 occurs due to smearing of ink on the carriage bottom where the cartridge head touches the carriage bottom. Please turn off your printer and unplug it.
Clean the bottom of carriage with a damp cloth and clean any dried ink. Make sure that you use the printer after 5-10 mins or until the carriage area dries up completely.
If the 1203 message is still present on the operator panel, you need to insert one cartridge at a time to determine which cartridge is producing the failure.
Now try and check whether you are still getting an error. I hope that you are using orignal Lexmark ink. If not then please use genuine inks only.
Daniel Scott
Jun 10, 2010 | Lexmark X4270 All-In-One InkJet Printer
Hi.seat ibiza 1.2 3 cylinder 2002 when touching the throttle at about 40mph car is jerking, i have changed coil packs and plugs, can you help please? also cleaned egr valve and checked pipes.
there is a problem with the timing chain tensioner on these models, which causes poor driveability, normally the engine management lamp would be illuminated too
Jun 09, 2010 | 2002 Volkswagen Jetta TDI
Cannon Pixma MP830 - smearing on front when printing
If you have taken it apart that far then you are way ahead of the game. My suggestion would be to clean the head or anything the ink touches in a vinegar/water solution. The vinegar dissolves any dried ink whereas the soap may actually gum things up. If that doesn't work or improve things I would say that your print head has a seal problem. The replacement print heads are worth more than a new printer so you can probably figure out whats cheaper to do.
Aug 21, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Brake wear warning light on
Hi I am vortash .. check that the sensor lead is not damaged at the brake calliper and check that the brake pads havent worn down again ?,, If they have I would suspect that you have a stiff calipper cylinder that keeps pressure on the pads against the Disc or drum and it needs freeing off and smearing of copperite grease you may check this by driving a few miles then feel the back wheels if they are warm then the pads are rubbing ..( be careful that can get hot enough to take your skin off if you touch them , you should be able to smell the linings also if it is this problem .. hope this helps regards Vortash
Jul 21, 2009 | 1998 Volkswagen Golf
Printer blurs the print on right side, has blank verticle stripes
You can download a pdf manual from the Canon site if you wish, but you will also be able to access their searchable troubleshooting support which may be of more help in clearing up the smeared printing.
Please go to the Canon site for your printer by clicking here
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 07, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Baby Gear Logo
202 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
