Question about Fellowes Powershred 520 Shredder
Shear pins broke that make the gears shred, where can i find replacement parts?
  • 328 Answers
You should be able to find pins in a good hardware store. I have found them at Ace.
Posted on Jul 22, 2009
My yardmachine snow blower 8hp auger won't turn. I replaced the cable and belt but it still won't turn. What else could be wrong?
Check the auger shear pins replace if necessary with correct parts(not regular bolts).
If auger and the impeller are not turning your cable is out of adjustment.
If only the auger doesn't turn, and the shear pins are ok then the brass/bronze gear has shredded which is why proper shear pins must be used. Donyboy73 on youtube show how to replace that gear on an older but similar MTD affiliated blower.
Feb 16, 2013 | Yard Machines 24" 208cc Two Stage Snow...
Kickstart aint working.... how do i fix this?
sounds like u sheared he role pin on the ger ortiming chain has broke and wrapped around the gears had a 500xr that broke the chain like i said
Dec 16, 2012 | Pit Bike 125cc 4 Stroke Dirt Bike
I have a poulan 850 that runs great. Gears engage and gos forward and back but wile tilling it made a click and the tines no longer engage. It's been suggested that it's a shear or breakaway pin....
Yes, there is a gear and pinion that drive the tines. Either a pin has sheared or teeth have broke off the gears. Either way its internal. You will need to completely disassemble the unit. Before you disassemble the unit locate and record the model and serial number from the chassis and the model, type, and code of the motor, you will need these numbers to purchase replacement parts. Remove the motor, tines, wheels, all shields, handles, etc. Until you are left with just the gearcase. Then you will need to split the gearcase. Lay it on its side on blocks so that it is stable and level. Remove all the fasteners and remove the top side. Take your time it will be hard to seperate the halfs to start with. Once the cases are split you will be able to identify the failed part and replace them. Good luck
Sep 09, 2012 | Garden
The shear pins on the rake keep breaking on a 853 NEW HOLLAND ROUND BALER. What is ?
Do you mean the driveline protection shear pin (pickup, roll the bale and wrap it) or the overfill protection shear pin?
For the driveline shear pin, check the type of pickup that you have. Make sure that you have the correct shear pin for the pickup (wide or regular). Also check the year of your baler, there are substitute shear bolts available that do not work on a range of the 853 baler. New Holland has a parts list for the baler on their site. Start at http://partstore.agriculture.newholland.com/us/ and use the Look up parts by equipment on the left of the page or see your manual. Next check the air bag pressure. (Make sure that you are in the operating range with a regular pressure gauge. It's possible for the gauge on the baler to read low.) If the pressure is out of the operating range, the roller bars can hit other parts of the baler and cause the shear pin to break.
If your baler uses net wrap, make sure that the wrap isn't caught in the unit. (If the knife doesn't cut the net wrap, it will get caught in the tailgate and the rest of the baler. If it tears in use, it may wrap around the pickup and cause the shear pin to break.) This may apply to twine as well but I do not have experience with it happening with the twine tied 853 baler.)
For the rest of the checks, you will have to remove any bale that is in the baler. If it is large enough it may roll out even if it isn't wrapped when the tailgate is up (try driving up hill). Otherwise, you need to pull, cut or pry the bale out. Standing on the kicker can help the bale roll out if sufficient weight is added. We've found that a spare bale spear works well. Removing the hay in small sections can also work.
What is the moisture of the bale? If the bale is too wet, it will be too heavy and shear the pin before the bale chamber is full.
Next check all of the roller bars in the unit. If any are bent significantly, that one can hit another part of the baler and break the shear pin. It's possible to straighten some of the bars out depending on the damage. If the bar is S-shaped or severely bent, replace it. (Your New Holland parts store may have someone who will demonstrate the technique for bar straightening. It involves hammering the bar straight when it is securely held in a vise. If you can hold the bar safely, I've also seen a bucket on a front-loader straighten the bars.) If a rock gets past the windrow guard, the bars can get bent.
Check that the chains are centered and that none of the gears are shifted to narrow or wider paths in a spot. (There are bars that can be adjusted between two sets of gears near the top front of the baler. Loosen the four bolts and push the parts closer or pull them farther apart.) Check that none of the bearings for the apron motion are frozen or damaged. Replace or repair anything that is damaged.
Do not make the bales too large or uneven. (If you have a Bale Command unit on the baler, it is easier to control the even formation of the bale.)
For the overfill protection, make sure to reset the unit after replacing the shear pin. It can be tough to pull the trip arm fully back. Make sure that nothing is in the tailgate. If your baler has a kicker, make sure that that the two springs on the sides are undamaged and holding the kicker level.
I hope this helps.
(my 853 baler with the wide pickup uses Driveline shear pin 46520 and Overfill shear pin 46047. I'm not sure of the year of the unit. When we got shear pins with a different number, we broke 3 or 4 in a row before realizing that we'd gotten the wrong ones; they were noticably thinner than the required ones. Roller bars are what I call the bars between the chains and we've replaced/straightened many of them.)
Aug 09, 2011 | Computers & Internet
I have a snow blower which will start up but it won't move forward in the snow nor will it push the snow. Not sure what is wrong. I can manually move the blade around that pushes the snow.
If you start the machine and the axles spin but the augers do not it is because the shear pins are broke. If you look closely you will see the the augers have shear bolts and nuts or shear pins. If you jam a piece of ice or a stick in the augers while they are spinning the bolts will shear so you do not damage the expensive augers or the worm drive gears. If the axle spins with the augers you may have torn up the front worm gear in the front of the auger intake. If you spin the small auger and the large auger moves but when you start and engage the auger nothing happens you will have to remove the under cover and inspect the drive belt pulleys for jammed or broken parts or more commonly broken drive belts.
Jan 28, 2011 | Mtd 22" Yard Machine Push Mower
Somthing broke
Hm, definitely something broke inside the tranny or drive gear as the gear belt still to tight when you rode it out. Better cheeck your tranny parts.....
Apr 16, 2010 | 2001 Victory V 92 C Deluxe
Replaced shear pins on right side standing at the controls, auger still does not turn?
does the 2nd stage auger turn? if the shear pin broke you may have ripped your belt part also. Take the belt cover off and inspect the belt assembly.
Dec 16, 2009 | Sport & Outdoor - Others
Auger turning slow. Auger turns initially but auger stops turning when it hits the snow. Shear pins look ok, belt looks ok. Shear pins look intact. Could they be broken inside where I can't see.
sure sounds like a shear pin, usually one end will be missing if it is broke. They are simple to replace but get one that is rated for your machine to avoid damage. Can you turn it freely without the engine running?? if so, it's the shear pin
Dec 14, 2009 | Ariens Garden
One side of my ARIENS ST928 SNOW BLOWER doesn't work
most likely you have a broken shear pin. Look on the side that works, there should be a bolt or pin through it. The side that is not working is probably broke off. Find the hole in the auger and line it up with the inner shaft and replace with proper shear pin/bolt. Shear bolts can be obtained from most outdoor power equipment shops. I do not suggest replacing with standard bolt as it can cause damage to you gear box it auger gets jammed.
Dec 18, 2008 | Ariens Garden
Makes noise but won't shred
Had the same prob with a Schneider shredder. The roll pin that secures the nylon driven wheel to the blades shaft was sheared. Easy fix in a way but original pin was a metric size.
Jul 13, 2008 | Tech Solution TS-2550 Shredder
Fellowes Powershred 520 Shredder Logo
81 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
