Question about RCA HD52W59 HDTV Projection Television
Rca hd52w59 hdtv what do i need to get hd i have a 24pin adpator that comes out to hdmi but i get 3 pictures
SOURCE:
  • 208 Answers
SOURCE: HDTV picture problems
Does the picture just get dark or does the picture go out completely? Does it do this with both the cable and the DVD? Is the audio affected?
Posted on Feb 12, 2008
SOURCE: RCA HDTV (HD52W59) and Playstation (PS3) Screen Size Issue...
First of all the adapters always give headaches with these TV's for some reason. Try changing to 16:9 instead of Cinerama. I do this by using the direction buttons on the remote left and right change this. Hope this info helps.
Posted on Jun 19, 2008
SOURCE: My RCA HD52W59 HDTV wont power on.
power supply switch is bad
Posted on Mar 25, 2009
  • 1030 Answers
SOURCE: rca hd52w59 making a high pitch buzzing sound
is this just a whine since you describe no problem with the picture it dosent jump or change color or flicker. there may be an easy fix this sounds like some coils oscillating and i tell you what can be done you can take some silcon and put on these coils to dampen then vibrations. now ther may be other problems but without looking this is my first gues ...where are these coils? ll037 on the power supply deflection board
Posted on Jun 17, 2009
Slinteriors
  • 8617 Answers
SOURCE: RCA 52 in HDTV red, green and blue colors not alligned - concave
That repair only repairs the issue of the convergence option missing from the on screen menu. If thats what your problem is then the ITC222A convergence option missing repair kit at the following link should repair the issue. The kit contains the fl231, DL231, CL230 and the CD with detailed instructions.
http://www.tvrepairworld.com/
Posted on Jul 17, 2009
I have an RCA HD52W59. When I came home today, it tries to cycle 3 times and shuts off. There is no picture and no sound
Thats usually related to the CP150, CP120 and CP114 capacitors needing replacement. You can get the RCA repair kit by that same name from www.tvrepairworld.com the kit has instructions also.
Apr 19, 2011 | RCA HD52W59 HDTV Projection Television
I have an RCA Scenium HD DLP 50" TV Rear
What is the Model Number that is printed on back of TV?
You say TV is DLP ,but you are posting Model# HD52W59 that is for Projection that has 3 Tubes Red/Green/Blue Tubes.
If TV is DLP then problem will be the Color Wheel
If it is Projection then it has a coil on the deflection board that either needs to be replaced or
resolder ciol and take a Glue gun and glue over the top of coil. Coil LL037 on the right handside of the FBT flyback transfomer.
Jan 13, 2011 | RCA HD52W59 HDTV Projection Television
IS IT JUST THE BULBS/LAMP
Please contact RCA "Head Office" in your area, ask for a referral to an Authorised Service Center. This is VERY important. Ask for a "Quote" before proceeding with any repair.
Apr 01, 2010 | RCA HD52W59 HDTV Projection Television
Will a hd dvr work wirh rca hdtv projection tv
yes a hd dvr will work with any hdtv just know that you will need a hdmi cable for the best available picture, and also projection hdtvs are not as clear as plasma or lcd
Mar 15, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W59 HDTV Television--the picture 3-d images colots red blue and green, been working great till this after noon any help please
When you presss menu and then select settings is the auto convergence and convergence options still there or have they disappeared/ Let me know and I will assist you with the problem.
Dec 17, 2009 | RCA HD52W59 HDTV Projection Television
I have a RCA HD52W59 HDTV that won't cut on
Capacitors in power supply if it trys to come on with a green light then goes off and attempts to try again maybe 3 times total before it is off completely
Oct 13, 2009 | RCA HD52W59 HDTV Projection Television
Rca hd52w59 chirping sound and light 3 times no picture
chirping sound is a short of some kind, could be the flyack or horizontal output, could also be a bad picture tube or power supply capacitors, you really need a tv repairman to troubleshoot this.
Sep 17, 2009 | RCA R52WM24 52" HDTV Projection Television
I have an RCA hd52w59. I just replaced fl231,
find your 'service' page, usually you have to hold the input button and the power button together for a couple sec. a new menu should appear Look for the factory restore choice and choose it.
Apr 22, 2009 | RCA HD52W59 HDTV Projection Television
Jun 16, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
57 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
