Question about Garden
Husqvarna 325HE4 blades do not move
Borrowed a Husqvarna 325HE4 to try out before buying one. It worked fine first day but now the blades do not move when the engine is started. Tried using WD40 on blades but does not solve problem. Throttle control lever does not engage nor does engine revs increase after starting.Worried as the machine is not mine!!Tks EICondona
trippssmengi
  • 76 Answers
SOURCE: Long reach hedge trimmer
Try loosening the bolts up on the blades just enough to allow the washers to move freely a little, spray the blades down (but don't soak them ) with WD40 to lubricate the blades, that should solve it. If that doesn't do it then you may need to pull the gear housing cover off to see if something is jammed.
Posted on Jan 14, 2009
  • 45 Answers
SOURCE: Ryobi Model 65020 gas tiller dies when engaging the throttle
sounds like you need to adjust the carburator
Posted on Apr 29, 2009
  • 57 Answers
SOURCE: Starts but won't speed up enough to run
If this is a 2 cycle engine the problem could be that the exhaust is clogged. Most 2 cycle engines have a spark arrestor on the muffler which clogs. could also be the exhaust port from the engine. remove the muffler and check it out.
Posted on May 15, 2009
panilling9
  • 284 Answers
SOURCE: Mower petrol engine runs much too fast
check your governer and spring to make sure it isnt in a bind or being hindered by something
make sure it moves freely
Posted on May 26, 2009
  • 10865 Answers
SOURCE: i have a 18.5 hp 42
When you move the lever and engage the blades you are also engaging the belt that drives the blades and sits on top of the mowing deck. Chances are that belt either came off one or more rollers, or broke. The only way to check it out is to get down and look on the top of the mowing deck. Get back and let me know what you find.
Posted on Jun 08, 2009
Husqvarna Proflex 21 just stopped engaging the blades after bump over brick. Was working fine, on starting the next cut the engine goes well, lever works but no mower blades turn when lever lowered. T
Sounds like you have broken a shear pin in the drive pulley.
Shear pins are made to break if you hit something. Other wise it would cost a lot of money to repair the damage.
Jan 24, 2015 | Husqvarna Garden
Why is my Husqvarna x series hedge trimmer 325HE4 NOT REVVING UP TO FULL POWER.?
There are 2 adjustment screws on the carburetor. Both have to be adjusted to get full power.
Aug 21, 2014 | Garden
Engaging the blade kills the motor how to fix
jack up the mower and see if the blades will turn by hand freely. If hot you could have something stuck in there or a seized bearing.
Jul 16, 2014 | Husqvarna Garden
WHY WILL MY BLADE NOT WORK ON MY HUSQVARNA RIDE MOWER AFTER HITTING METAL BAR
Sounds like the large nut on top of the spindle may have loosened up or the splines on the pulley are chewed up. Turn the blade and try to hold the pulley on top. If the blade turns and the pulley doesnt, its one of the two things I just described.
Jun 29, 2014 | Husqvarna Garden
I have a Husqvarna GT 2548 with a 25 hp Kohler eng. Engine idles fine and drives fine until I engage blades , then it bogs down. It is really bad if I am moving up an incline. I checked the blades and...
The governor regulates the engine speed and when a load is applied that would slow the engine it is the governor's job to open the throttle to maintain the speed. It also limits the maximum engine speed to a safe level. As a user of the machine you should have formed an idea about whether the governor is working correctly.
If the governor linkage moves freely against the spring(s) and the maximum revs of the engine are about right no adjustment should be attempted and the fault probably lies elsewhere, most likely fuel starvation though bad ignition or valve timing, tight valve clearances or partially blocked exhaust can affect power output.
A back-to-basics approach is usually the best if the problem has built gradually but if it happened suddenly I suggest you begin by thoroughly cleaning the carb.
Aug 05, 2017 | Husqvarna Garden
I am using a borrowed Husqvarna model 51 chainsaw (aprrox 18") and having a problem with the chain seizing up. It worked fine for 30 minutes or more, and then the chain suddenly had much more...
Sounds like the bar is to tight.There should be a cover and 2 studs,loosen the nuts and then look for an adjusting screw at the back of the bar and back it off.The chain should have about 1/8 slack when pulled from the bottom of the bar.A tight chain will heat the bar and turn it blue close to the chain guide.A new bar will be required. Thank you for using FixYa .
May 11, 2011 | Husqvarna Chain Saw Models 51, 55
Why have the blades stopped moving on my new 325he4
More thank likely a gearbox issue, if the engine still runs fine.
Jan 30, 2011 | Husqvarna Garden
Husqvarna riding mower. Wont start.
check your switch for your blades take it off(shut it off)
Sep 05, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Garden Logo
222 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
