Question about Toshiba e-Studio65 Copier
MJ-1007 Finisher - CB1
Sometimes, at power on, the copier shows a call for service error - CB1. The trays on the finisher go down but they don't come back up. The problem clears after powering off and on a few times. I have changed the finisher PCB but it didn't seem to make much difference.
  • jwr51 Nov 19, 2007
    Thank you. I also changed the Stapler PCB but the problem is still there. Is it likely to be a mechanical problem?
    Thank you. When it fails I can hear a noise that sounds like worn out gears - turning but not meshing. You have given me some good leads here.
    An user who is expert in 3 categories / brands.
  • Toshiba Master
  • 1,362 Answers
Check the stapler unit, it is most likely the problem
Posted on Nov 19, 2007
  • CheckitRight
    CheckitRight Nov 19, 2007
    Yes, can it staple? it may be the stapler itself. Sometimes the stapler has a problem where it doesnt fully make the motion to staple.
    also there is a sequence it goes trough at power up, the bins go up there is a gate that goes up and down the stapler goes back and forth to home position and the bins go back up.
    There is a small black gear that goes bad and slips or cracks this gear or i beleive a clutch moves a gate back and forth, if it does not move the gate out of the way then it goes into the code.
    Good luck.
CANON ir 3530 finisher error
canon ir 3530 shows finisher error (displays spanner)
Nov 10, 2012 | Canon gpr-16 ir 3530 blk...
My aficio 2035e shows sc 329 and sc 322. what does this mean?
  1. Remove paper from all output trays. Depending upon the options fitted to your device, the output trays are:
  2. Locate the gray cables that are connected between finisher and main unit. Check that they are secure, and that the cables are in good condition.
  3. Switch off the device at the red power switch.
Dec 16, 2010 | Office Equipment & Supplies
C1183 error the trays desent and rise normaly put the stapeling unit coms at the front? this must be in center? thanks if anyone can help bart
Error code C1183 means finishing option elevator drive malfunction. It appears due to tray lift motor failure on the finisher. To trouble shoot the issue turn off the power and open the elevator section to check the elevator motor. Wait for 2-3 minutes and check if the issue is resolved. If this doesn't work then check the alignment of front and rear rollers of the finisher. Also make sure that the finisher exit guide rollers are fine & the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. Sometimes this error may appear due to a broken lower gear by the pin slot. Hope this helps...
Oct 09, 2010 | Konica Minolta Office Equipment & Supplies
Toshiba estudio 45 error cc9
CC9 indicates Upper stack tray lift motor is abnormal on finisher MJ-1011. U need to check the wiring and sensors.
Oct 19, 2009 | Toshiba e-Studio163 Copier
Helloo about toshiba e studio45 i have error code CB1 , this machine is a secound hand and when it desplay the service error it shows the contact number for the maintenance i need to remove it too but i...
this is a finisher error code.
turn off power then grasp the lower tray of finisher on both sides and shift up as far as it will go. turn power back on and see if that works. worse case disconnect the finisher from top rear of machine-at least the copier should still work and copies will go into middle.
Oct 04, 2009 | Office Equipment & Supplies
COBAO error on NEC IT3520/KM Dialta 2010
Was there a trash can or box of paper underneath the finisher part that moves up down. the code is failure of the up and down motor for the finisher. Normal happens when the trays that move down they hit something. or the mootr has failed. Open/close the door to the finisher, power off both power switches including the one on the rear left side and the one on the front panel. wait ten seconds then turn them on again. Also check to make sure there is not something binding the tray system
Jul 02, 2009 | Konica Minolta DiALTA Di200 Copier
Toshiba e studio 232 screen shows
is the finisher tray atach and connector plug in? it's possible that the connector was unplugged while the machine was on and an memory error apeared! if so, unplug the copier from power source, plug in the finisher, and plug in the power corde . if it won't work you shall check also if all doors of finisher are closed and if wasn't broken one of the sensors!
Nov 03, 2008 | Toshiba e-Studio 232 Black and White...
Aficio 1035 ps
Finisher 1 tray lift motor error.
It should be looked at by a technician to see if the sensor or motor needs to be replaced.
If you want to use the machine for now and bypass the error. Turn the power off on the copier. locate the finisher cable in the back of the machine. Pinch and release the cable and turn the power back on.
Jul 11, 2008 | Ricoh Aficio 1035 Copier
Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Jun 07, 2008 | Minolta bizhub 200 All-In-One Printer
Keep getting error code E07-27
E07-27 is a problem with the finisher tray lift motor. Make sure that a trash can is not under the tray. Have also seen screws work there way loose causing the tray to bind. If neither is your problem, you will have to call a service provider. Temporarily you can turn the power off, separate the finisher from the machine, unplug the connector, and turn power back on. You will not have a finisher but you can make copies until it is serviced.
Jan 30, 2008 | Panasonic Workio DP-4530 Copier
Toshiba e-Studio65 Copier Logo
124 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
