Question about GE Televison & Video
I have GE model 27GT618 made 1996. No power to
I have GE model 27GT618 made 1996. No power to TV. Have switch outlets, jiggled cord, nothing. Tried power from the TV as well as remote but nothing happens.
  • telexman Jul 14, 2009
    Awaiting tech arrival but solution he quoted was about same as given here.
  • GE Master
  • 19,396 Answers
If there is no power at all , then it is either the PSU (transformer) or the power cord.
What a technician does is the following:
Unplug power cord.
Disassemble TV.
Visually inspect Power Board, looking for blown or leaking capacitors or burnt areas.
Inspect power cord contacts looking for broken solder joints.
Plug back TV and read volts at power cord contacts , or read continuity (Ohms) on power cord to test power cord integrity.
Test volts out on PSU board.
Replace PSU board or power cord.
Parts for this set are not longer in stock, and can be ordered from Sellers like Vance Baldwin or Partstore, or requested directly from manufacturer.
If the problem is a PSU capacitor, the capacitor alone can be replaced by a local technician, saving money on the power board replacement.
Posted on Jul 14, 2009
My LG55LE5500 suddenly stopped working this morning. Last night, we switched it off in proper working condition. This morning, when we switched in ON, only the initial LG logo screen comes and stays there...
Check whether the product is turned on. I Try another channel. The problem may be with the broadcast. I Is the power cord inserted into wall power outlet? I Check your antenna direction and/or location. I Test the wall power outlet, plug another product's power cord into the outlet where the product's power cord was plugged in. From the LG manual kolbrun
Sep 18, 2013 | LG 55LE5500 55 in. HDTV LED
Hi I have a GE model GSC3500ROOWW witch without any previous issue won't power up at all I checked all the normal causes the breaker is good tried different outlets and still nothing this model is a...
I once had a portable ge dishwasher that burned up at the spade connectors attaching the power cord to the internals on the unit. Might be a good place to start
Aug 25, 2013 | Dishwashers
My TV won't turn on. It was fine this afternoon and when I tried to put in on tonight, nothing.
The key here is does the red power light come on? If not follow power cord inside to the fuse that is directly in line with the cord.
If other let me know.
Apr 23, 2012 | Hitachi 51F510 51" Rear Projection...
I have a GE D52GW12 rear projection tv. It seems to just loose power and turn off at random times. I already tried different outlets to get it working again.I can get it back working if I wiggle the power...
The tv a/c power cord have internal damages short on the head of the a/c plug itself.This work job is pretty simple if u can do a basic soldering jobs and have tools like a soldering iron and a roll of solders.Look around in ur house for a table portable lamp u don't used anymore unsolders and take that portable lamp a/c power cord.It have very simular design and make of a power a/c cord.Take the tv aparts simplely just unsolder the old tv power a/c cord and replace it with a portable table lamp a/c power cord.Those stars srews on the tv are called Allan wrench screws,must a have a set of Allan wrench screws drivers to use take out this screws out of the tv.Some ealier DLP tvs set made by GE are using these Allan wrench screws,tries to make it much more difficult to take the tv aparts as GE they're trying not to allow tvs owner to take the tv aparts.Or have any friend to help u can do it,have a soldering iron,a rolls of solders,have basic soldering skills.A Allen wrench screws drivers set u can buy it anywhere in a hardware store.
Sep 03, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
Have a GE model JVm1650bh05 Microwave. I put in
Check the fuse in the bottom of the oven ... near where the power cord enters.
Oct 19, 2009 | GE JVM1630 Microwave Oven
The toaster does not heat and it's only 6 mos. old.
1. check outlet where you plug in your toaster with lamp or vacuum.
jiggle plug of lamp or vacuum while plugged in to check for bad outlet.
if lamp or vacuum do not work, check breaker panel/fuse box for tripped breaker/blown fuse.
if breaker/fuse okay, replace outlet.
if lamp or vacuum work okay, go to next step
2. plug toaster back into outlet, jiggle plug, then jiggle cord at plug, then jiggle cord at toaster.
this checks for intermittent power cord.
if cord okay, check that the toaster lever or toast basket are not blocked from going completely down.
might be a bit of bread, muffin, bagel that blocks the basket.
if all okay, you need other solutions.....
Jul 09, 2009 | Back to Basics Kitchen Appliances - Others
Emerson LCD 32" TV....Model # LC320EM82....Power problem, powers up and powers right back off almost instantly....i have tried to google a solution and so many people are having the same solution but...
Okay!First i need to isolate your electrical outlet is working. Use another Video/Audio component(ex. dvd player) and plug the power cord into the TV outlet,be sure it has nothing to do with the outlet.
If the outlet is working properly,Unplug the TV power cord and wait for 1 minute before you plug it back in the outlet.Turn on the TV MANUALLY without the remote control and see if the power stays on,if not,sorry,you need it to be repair.Don't waste more time on it. If you only purchase it for few months with a reputation retailer,there is no reason NOT to call them up,cause it should be still under warranty?
solutiondoct
Nov 10, 2008 | Televison & Video
I have no power on my dishwasher. I ran an extension cord to another outlet that I know has power and still nothing. I don have any led lights or anything. Can you help. GE model # GHDA960K03BB. Thank...
Few components may cause power failure to your Dishwasher.
1. Disconnect your power plug from the socket outlet.
2. Trace the cord to where it connected to your dishwasher.
3. Tight those connectors firmly .
4. Plug back your dishwasher power cord .Start your dishwasher.
If nothing happen, check if control board came with fuse or bimetal. check the continuity of the fuse., You may also check your latch assembly.If no power still change the console or the control board.
Jul 26, 2008 | GE Dishwashers
Protron 42
on the back of the TV where the power cord plugs into the back of the tv there is a small black on/off switch- it's not as obvious as you would think.... but that was turned off. Not sure how that happened since the back of the Tv was never touched when it went dead- but I unplugged the cord from the back of the tv and from the outlet and reset that switch and it worked.
Jul 10, 2008 | Protron PLTV-4250 42 in. LCD Television
TV just died...
Hi there!
The fuse may have blown. If so and you know how to check for a faulty fuse inside a TV, it may be worth a shot. Please unplug before opening and replace fuse with same value. If it blows again, you have to have it seen to by a repair technician. Good Luck, Regards, JUS004
Mar 24, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
121 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
