Question about HP LaserJet 4 plus Printer
Error code reads no toner cartridge
Error code reads "14 no toner cart"
5 Suggested Answers
checkitright
  • 1362 Answers
SOURCE: '14 no toner cart' problem to be solve
It has a chip on the toner cartridge, chip is bad. replace
Sometimes the sensor in the machine goes bad. replace
Posted on Aug 08, 2008
  • 11 Answers
SOURCE: error code 14 "no tuner cart"
14 NO EP CART Message
The printer detects the presence of the Toner Cartridge and the
level of toner present in the cartridge through the condition of the
ANTIN signal. The ANTIN signal becomes part of the serial data
stream used to communicate with the DC Controller (see Figure
7-5 for cartridge components). Troubleshoot the 14 NO EP CART
(or INSTALL TONER CARTRIDGE) message as follows:
1 reseat the Toner Cartridge. Try a new or known good Toner
Cartridge.
2 Check the High Voltage Contacts for damage. If the contacts
are dirty or damaged, clean the contacts after the repair.
3 Replace the High Voltage Power Supply.
4 Check and reseat the HVPS cable.
5 Replace the DC Controller
Posted on May 21, 2009
  • 105 Answers
SOURCE: After installing a new toner cartridge in my HP
1. Reseat the cartridge. Try a new or know good cartridge. If OK, stop.
2. Check the Hi Volt contacts on the cartridge for damage. If the contacts are dirty or damaged, clean the contacts after the repair.(This is especially important if the cartridge is recycled.) If OK, stop.
Before going further, evaluate the cost effectiveness.
3. Replace the Hi Volt Power Supply. If OK, stop.
4. Check and reseat the HVPS cable
5. Replace th DC controler
Posted on Nov 24, 2009
  • 20 Answers
SOURCE: 14 no toner cart
when top door , and check for the sensor switch
Posted on Jun 17, 2010
Change toner cart and error f2-00
well this is normally toner bottle gear is tight or micro electronic card is defected which you can see on toner cartridge but if them ok check socket where this micro card pin goes if connections r fine and u replace developer did calibration but still same prolem then u need to check the board if u have tested main board where toner connector goes jus swap hope fully will be ok let me know
Feb 22, 2014 | Sharp AR-M700N Copier
F2-40 error code on mx3110n
black toner supply trouble, try a different toner cart, remember to shake the cart before installing. power the machine on and off, if the code is gone then it was the cart if it doesn't clear your service tech needs to see the machine.
Jan 13, 2014 | Sharp "MX-3110N Color Copier, Printer,...
Just purchased a used HP LaserJet 4 Plus -- when turned on and installed it is showing 14 no EP CART -- we do not use cartridges so need to reset to default settings. Tried Power On and holding online but...
Ensure that the Toner Cartridge is installed correctly (fully
seated into the printer). Try a new Toner Cartridge. If the
problem continues, try this
1 Reseat the Toner Cartridge. Try a new or known good Toner
Cartridge.
5 Replace the DC Controller.
Jul 05, 2011 | Office Equipment & Supplies
After installing a new toner cartridge in my HP Laserjet 4Plus, I have an error code 14 no toner cart and cannot print.
Oct 07, 2009 | HP LaserJet 4 plus Printer
At times i get a message 14 no toner cart and then i am unable to make prints
No Toner then it prints again..
This could be lower toner, a generic toner cartridge will sometimes produce this, or dirty contacts where the cartridge lays in machine.
Look at the toner cartridge, where you see shiny silver or bronze, clean excess toner off, also in machine where toner cartridge lays, clean all excess toner out.
Oct 03, 2009 | HP LaserJet 4 plus Printer
Error code 14 "no tuner cart"
Cartridge.
May 06, 2009 | HP LaserJet 4 plus Printer
Error F 2 (Blinking mode) appears in Display of Sharp AR5316,
Hello sir; F2 have a sub code, press print key to read the sub code, if the sub code is 04,then it means wrong cartridge,wrong country, you can try to reset it;
1, press "#", "interrupt", "c", "interrupt" keys.
2, enter 14 press start.
3, if it work, don't forget give me a good rating.
Feb 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
False reading of toner cart status
Sounds to me like you actually have the wrong part number. There are more than one cartridge for the Xerox printers, They have different chips on them. One is for billable accounts, one or more than one for accounts that pay for prints. There also was as i remember a spring type clip they left off some cartridges.
So with what you have tried and the old cartridges work fine, strongly suspect bad carridges.
Dec 01, 2008 | Xerox Phaser 7300DN Laser Printer
Jul 24, 2008 | HP LaserJet 4 plus Printer
Toner light continues to flash and copier won't print
Hi, your problem won't be scanner related, if it were it would a separate error code. I have never bothered with reman cartridges, purely for this problem, the money saved is not enough if you have problems. I would try a genuine toner cart (probably cheaper then calling an engineer out).
Let me know how you get on.
Regards
Andy
Jan 28, 2008 | Sharp AR-207 Copier
HP LaserJet 4 plus Printer Logo
122 people viewed this question
Seeker5211
Seeker5211
