Question about Kenmore 3.2 cu. ft. Top Load Washer
Lets water in nothing else - Kenmore 3.2 cu. ft. Top Load Washer
  • 92 Answers
Check motor bushes,?
Posted on Jul 15, 2009
Why will my machine not let in hot water?
Boy! That Machine sure told you Off! LOL...I hope you are OK and you did not get burn! Yes there is a separate (and Less expensive) Hot Water Inlet valve. BEFORE changing it Or any part on a washing machine be sure that A) Power is disconnected. and B) the water source is shut off. You may have to "bleed" out the Pressurized water by removing the filter or screen. Check your owners manual for the location.
Jul 26, 2014 | LG Washing Machines
Kenmore front loader washer powers on but lets no water in
If the door lock is engaging, then there could be a few things causing the problem. These things are as follows:
1) The water valve is bad - you can check this by seeing if when you turn the machine on if power, 115vac is being applied to it. If so the valve is bad, if not read forward.
2) There is a part called the pressure switch, it controls the amount of water that flows into the machine. Its connected to the drum by a 1/4" tubing. You'll need to check to make sure that nothing is obstructing the tube.
3) Take the bottom of the machine off, called the kick plate. Inside there is a tech sheet with diagnostic walk through's that will carry you the rest of the way
Jun 17, 2012 | Kenmore HE2 Plus 3.6 cu. ft. Super...
When i turn on the machine the "!" flash fast constantly and the "drop"light turn on; i turn the nob for the hot water but nothing comes out no water or steam...nothing works..i can hear the engine runnin...
It is telling to purge the air in the water line. Make sure there is no filter in the water tank and turn on the knob. The pump should **** the water and let it out from the steam arm.Hope it works.
Oct 11, 2010 | Saeco Odea Giro Plus Coffee Maker
Gaggia Titanium. Fault suggests ventilation required. Followed manual instructions, nothing happens. Tried rinsing, nothing happens. Tried hot water nothing happens? Have taken out and cleaned all pbvious...
Do you hear the pump working but no water flows?
You should select hot water (the third button from the right) and the display should say "hot water" at the same time it is saying VENTILATE --- open the steam valve all the way and the pump should start and you should see water from the steam wand.
If you don't hear the pump at all, then that is a different problem.
If you do hear the pump but still don't get any water with the steam valve open, then you need to prime the pump by using a turkey baster or the accordian pump that came with the Titanium to pump water into the valve where water from the tank goes. Remove the tank and use the turkey baster to pump water into that valve while the pump is running and the steam valve is open all the way with HOT WATER selected. the second water starts to come out the steam valve you want to stop the pump (turn the power off or turn the steam knob shut) and put the water tank back on and make sure there is plenty of water in the tank - then start the pump again by opening the steam valve all the way and let it pump water out the steam wand for a few minutes.
Oct 05, 2010 | Gaggia Titanium Espresso Machine
Dispenses water for drinking but not to make ice in ice machine
Your model refrigerator uses an electronic Ice Maker. You can test the Ice Maker by filling with tap water and let freeze sometimes they already have ice inside and shrinking because of defrost. If you can fill the trays with tap water and it freezes and dumps but does not refill with water the problem will be the water control valve. If ice maker does nothing and on then the Ice Maker is the problem. Try that first and let me know what you find, Sea Breeze
Feb 18, 2010 | GE GSS25JFM Side by Side Refrigerator
My whirlpool american fridge freezers water dispenser is continually dripping what can I do to resolve this problem
Replace the water inlet valve , the piece that the wall water line connects to on the refrig .. Something like a grain of sand , piece of dirt etc , is caught in the rubber bellows , not letting the valve close completely . This will cause a scratch , which will collect anything else that comes thru , so cleaning it out will not work . ( it won't remove the scratch ) .
Sep 06, 2009 | Whirlpool Freezers
I have Kenmore frostless 25 with an ice and water dispenser in the door. It does not makes ice, but the water dispenser works fine. I could hear the ice maker switch bar moves up and down in the ice...
Most times it's the water control valve on the rear of refrigerator and near the floor. And you can test the ice maker by filling with water. Let it freeze and if it dumps the ice and does not refill then the water control valve. If the water freezes and nothing happens the the ice maker is the problem. If you had your model number I could tell you part numbers. Anyway try that and let me know your findings. Kenmore uses a model number like 312.54689 for example found on front near floor and behind the fresh food section door. Let me know, Thanks Sea Breeze
Aug 20, 2009 | Kenmore Refrigerators
Hobart glasswasher: it fills but then nothing
Did you solve your problem?It takes 8 minutes to fill.I'm a hobart tech,let me know.
Apr 11, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
I have an old Kenmore 26 side by side that dispenses water and ice. At one point it stopped producing ice and dispensing water. I changed the inline filter and it worked perfectly. Happened again shortly...
It sounds like you need to replace your water inlet valve , it is a dual valve for ice and water in the door and they go out often , the solenoid is not opening anymore , it is located where you hook up the water line.
Let me know if you have any other questions.
Phil
Apr 10, 2009 | Whirlpool GD2SHGX Refrigerator
Hotpoint aquarius wf210 g washes but stops at rinse
that is a possabilty, make sure you have water going to cold valves put test bulb on the wires going to valves it should light] close Ire. that means you have current going to valves] get back to me if you can\t sort it
Nov 03, 2007 | Hotpoint Aquarius WD640 Front Load...
Open Questions:
See all Kenmore 3.2 cu. ft. Top Load Washer Questions
Kenmore 3.2 cu. ft. Top Load Washer Logo
50 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
