Check the filters. Flow Indicator: Turn Indicator cap counter-clockwise, remove rotor, next remove filter. Clean the filter and replace items in reverse order. Additionally, now is a good time to clean the Lint Filter on the tank cap. These filters are recommended to be cleaned after each use. Hope that helps, if not Bissell Consumer Care can be reached at 1-800-237-7691.
SOURCE: Bissell power shoot carpet cleaner
It sounds like the heater may be plugged. This is a problem for an experienced technician. The heater is located in the handle and they are prone to plugging at the tubing connections. The heater is heating soap and water solution and this can cause the soap to coagulate and plug the lines. It must be addressed carefully to avoid damaging the heater.
SOURCE: same issue...need replacement wand for fantom lightning
I have the power head, wand & hose, exrra belt, 4 heps filters ans a spare main vacuum motor for Fantom Lightning. My main motor burned out. Found a used motor on Ebay. Went to change it and part of wiring was burned, so I decided not to rosk reairs with bad wiring. Power head was not attached at the time, so it is fine. I'll sell all together for a decent price, it you're interested
SOURCE: Bissell 8930 Pro-Heat wont dispense
The water solenoid that controls the flow of water to the floor nozzles is prone to and known for failure. Replace it. Less than $12.00 part.
SOURCE: The Water will not spray out(it just dribbles) of the shampooer
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
ewrtwy
SOURCE: won"t dispense water
heatman101
ytoi
