Question about Compaq Presario 700 470024-192 Notebook
Dvd blank burning file problem
I USED COMPAQ PRESARIO C700,RECENTLY WHEN I BURN THE DATA TO DVD BLANK ALL THE DISK BURN PROCESS FAIL AFTER FINISH. DURING BURNING INSTEAD OF SHOWING "BURN PROCESS RUNNING" IT SAYS WRITING SHORT LEAD OUT AND AFTER FINISHING THE DISK DOES N'T WORK
Files are lost or misplaced but not so
Posted on Sep 01, 2009
  • 53 Answers
Please uninstall software and reinstall it agai.
Posted on Jul 14, 2009
Create boot disk
Insert a blank diskette into the floppy drive. Click start click on computer you should see all of you drives.
Right-click on Drive A. You will see the option to format the drive.
Click on Format. Depending on your operating system, you will see an option that reads either "Create a system disk" or "Create a MS Dos system disk." Click the box next to this option.
Click the "Start" button to begin formatting the disk.
When completed, you will have a bootable floppy disk.
For CD Rom or DVD disks
Open the software that you use to burn or write files to the CD-rom or DVD drive.
Click on "Make a Data CD or DVD." Insert a blank CD-R or DVD-R disk into the drive.
Look for the option to "Make this disk bootable." You may have to scroll over the various icons displayed to find this option. Click on the option.
Burn the CD or DVD as usual. Once completed, this disk can be used to boot your computer.
hope this helps
Aug 22, 2012 | Seagate Computers & Internet
Tip
Ways to burn Discs with Finder and Disk Utility in Mac (versions OS X 10.4 -...
Without purchasing new disc burning software, there are actually 3 ways to burn CDs & DVDs in your Mac OS X system (Mac OS X 10.3-10.6)
There are methods using Finder and Disk Utility.
Both are easy to do and when set up to use will have you burning music, video, data, and image files (ISO) to CDs or DVDs in no time at all.
BURNING DISKS WITH FINDER
1.) Create a Burn folder and burn a CD/DVD
* The easiest way to burn a disc with Finder is to create a Burn folder with Finder. Here's how you do that:
* Click on any blank space on your desktop and in an instant, Finder will appear on the Apple menu bar next to the Apple menu icon.
• Click on File and select from the drop down menu
* This distinctive folder will now appear on your Desktop
* Now insert a blank CD or DVD and in moments, you will see this window pop up:
• Just click the OK button.
* In a few more moments
on your desktop, you will see this Untitled DVD (or "CD: for CD-ROM Disks) icon:
• Now you can either drag and drop files into the folder, or just double-click the folder and also drag and drop files into the open Burn Folder window
* If you notice, each file you drag (or copy and paste) into the Burn Folder window will have a small curved arrow at the bottom left corner of the file.
That is merely a designation that the file is a image of the actual file and ready to be burned to the CD or DVD you use.
* Notice the Burn button (highlighted in the red box). This is the button you will press, to commence the burn (or copying) of the data you have placed in the burn folder to be copied to disk.
• Click the Burn button, name your disk and that is all it takes. When the process is complete, you will now see a formerly Untitled Disk icon on your desktop replaced with a "Your_new_disc_name" DVD.
(Additional Note: If you wish, you can also simply bypass creating a Burn folder, insert a blank CD or DVD and simply drag and drop or copy and paste files into the open window of the Untitled CD as well.)
BURNING A DISC WITH DISK UTILITY
There are actually two ways to burn data to an DVD or CD with Disk Utility:
1.) Burn a disk in Disk Utility
* Simply open Disk Utility by either clicking anywhere on a blank space on your Desktop window and Finder will appear near your Apple menu, select Go >Utilities and that will take you to the Utilities Folder which is the default location of the Disk Utility application.
* Or you can click the Finder icon on your Dock, open a new Finder window, click on "Applications" listed in the side window and select the Utilities folder
* Either way, you will land here.
• Insert your CD or DVD.
* Once you open Disk Utility, you will see this main window
* Now all you need to do is click the "Burn" button located on the Disk Utility toolbar.
* For an example, I am striving to burn a copy of my Quicken .dmg file to CD.
* Once I have selected the file, then I click the Burn button located at the bottom right corner of the Finder window.
* Follow the onscreen instructions to start the burn process.
2. Creating a multi-session disk using Disk Utility:
Now it is known, that one cannot burn more than once with a single CD-R disc, but it can be done as provide from the knowledge base of Apple support:
  • In the Finder, create a folder for the session and drag the items you want to burn into the folder.
  • In Disk Utility, choose File > New > "Disk Image fromFolder." Then select the folder you created in the dialog and clickOpen.
  • Type a name for the image, choose a disk format, and click Save. Mac OS Extended allows burning the disc more than once. Formats such as ISO allow burning the disc only once.
  • When the disk image is complete, select it in the Disk Utility list and choose images > Burn or click Burn in the toolbar.
  • Insert a blank CD in the optical drive.
  • Select the "Leave disc appendable" checkbox. If you don't see this option, click the triangle in the top-right corner.
  • Click Burn.
What is really nice about this CD/DVD burn feature of DIsk Utility, is that now you can come back later and add more files to the same CD without having to waste all the space on a new CD-R.
This especially useful, if the image file you are need to burn is small in capacity. Just pop the previously burned CD in your drive and add that file or files until that CD is filled to capacity- that is all it takes.
So there you have it, a quick tip on how to use Finder and Disk Utility to burn any data to your CD and DVDs.
Thanks for viewing my Mac OS X tip from FixYa Support. Stay tuned for more tips for how to make the most of your Mac OS X systems!
Regards,
-Mactechtrainer
on Feb 23, 2010 | Computers & Internet
Windows vista is unable to format DVD+R and with a other burner program I get the following error: 19:17:00, File(cl_DVDData.cpp), Line(193) -> Begin burning process Current drive: <G:...
have had this problem myself and wasted many discs you need a new burner but there is a work around to this problem
just leave the disc open so that more data can be added and no more problems
Jan 05, 2011 | LG GP08NU20 DVD±RW Burner
Its says write error when I go to burn a avi file onto a dvd disc
Is the AVI file less than 4.7 GB in size?
Does the "write error" happen more than once?
Did it happen only with one "blank" disk?
Can you select some other file, and successfully write it to a disk?
How many seconds after clicking "start burn process" does it take before you get the error-message?
After getting the "write-error", look at the disk.
Does it appear that anything has been burned onto the disk?
If you put the disk into some other DVD-reader, is it still reported as 'blank" ?
Jun 12, 2010 | Computers & Internet
Need help with Compaq Presario v2000 drivers
Your DVD drive is missing the Burning Program not the driver. I found an update for your windvd software for windows 7 but you probably have to have the full program installed to run the update. Hope this helps.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=432985&prodNameId=500746&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ob-26952-1
Jan 10, 2010 | HP Compaq Presario V2000 Notebook
Can I write 2.6 gb on a blank dvd-r 4.7 gb disk ?
There is a good chance you are doing a test burn. before burning there will be options to run a test before doing the actual burn.
Jun 16, 2009 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
Toshiba sd-r2002 - won't recognize blank CD when trying to write files to a CD
right click on the drive.... go to properties... under tab recording, remove tick "enable CD recording on this drive" and press apply... after that tick "enable CD recording on this drive" and press OK.
It should work.
Jun 01, 2009 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
Help
We directly cannot copy a file from hard drive to DVD, we need a DVD writer to burn it on the DVD disk. Hard drive is a removeable device and we can read and write data as we need but DVD is a non-removeable disk and we can only write it for once, the process of writing or copying file to the DVD through a DVD-writer is called burning.
There are many different kinds of DVD’s, and knowing what kind you would like to copy is important before making the decision to burn. The process used to burn DVD’s usually depends on the kind of DVD but three common types are used the most when burning. They are: Burning Data DVD’s, Storing Multimedia Files on a DVD, and burning Commercial DVD’s. We’ll take a look at these three methods below.
Burning Data to DVD’s
The easiest way to burn DVD’s is by copying everyday normal data. This includes ordinary files like documents, spreadsheets, and database files and is the easiest method because no special decryption software or regionally specific encoding is needed. Any computer with a DVD drive will easily play these burned DVD’s.
It is a good idea to download some of the multiple free DVD burning programs available to test them out. You may also want to check out commercial DVD burning software available for purchase. Most newly purchased computers already come with a DVD burner and burning software installed and ready to use. All you have to do is start the DVD burning software, make sure to select DATA DVD as the type of DVD to be burned, then follow the prompts. A full length DVD contains around 4.7GB of data and can be burned in around 20 minutes with an average DVD burner. Higher speed DVD burners will be able to burn your data much more quickly.
Burning Multimedia Files to DVD’s
While the process of burning audio and video (multimedia) files to a DVD is basically the same as burning data DVD’s, multimedia DVD’s require additional thought before copying. This is because you will most likely want to add some extra features when burning a precious wedding video or converting old VHS tapes to a friendlier and longer lasting format.
The DVD authoring tools available today make burning multimedia DVD’s with a professional touch a breeze. Convenient features like Chapters (to skip to a specific section of longer videos), Menu pages (perfect for a wedding video), and Titles (to index multiple TV shows or videos already stored on your computer) gives everyone the ability to burn polished DVD’s easily. Subtitles that you create yourself can even be added by some DVD burning software and Digital Rights Management (DRM) may also be available. DRM allows you to create commercial grade videos that are tough for others to easily copy to another DVD.
Burning Commercial DVD’s
Burning copies of commercial DVD’s is one of the primary uses of DVD burners and is enjoyed by many people who own them. While it may not be illegal to burn copyrighted material for your own use, in most areas of the world it is illegal to make copies of commercial DVD’s to sell or give away to others. You can still burn copyrighted material, including commercial DVD’s, if the burned copy is for personal use. Some uses may include creating a DVD archive or backup, or having an extra copy available for use in the computer or car’s DVD player.
A commercial DVD can be copied by many tools, but decoding software specifically designed to remove (”crack”) digital rights management will be needed in addition to a regular DVD burner and DVD burning software. Besides copying the commercial DVD’s data and decoding any digital rights management, it is also important to note that most of the time you will need to shrink the file first.
The majority of commercial DVD’s hold between 7 and 8.4GB worth of data and are known as dual layer DVD’s. A normal blank DVD will hold 4.7GB of data, which means the larger amount of data on a commercial DVD needs to be compressed before it will fit on a blank DVD. After a commercial DVD has been cracked and the files compressed, ordinary DVD burning software can be used to burn the new DVD. Simply start your favorite DVD burning program then follow the prompts.
Since the process of copying commercial DVD’s can seem daunting to someone doing it for the first time, several companies have developed suites of DVD copying programs that simplify the process. These software tools will usually crack and decode the DVD, compress the files small enough to fit on a blank DVD, and can even add extra features before burning everything onto a normal DVD.
Now that you know how to burn DVD’s, you’re well on your way to burning your first one. Start by checking out free DVD burning programs as mentioned earlier, or just download one and jump right in. Remember to bookmark this article as reference should you run into any problems.
Have fun and happy DVD burning!
Best Regards
May 25, 2009 | Bling Software 123 Copy DVD Gold 09
Why my [sony cd rw dvd rom] will not detect a blank dvd disk
If you have the sony CD RW DVD ROM then you can't burn the data in a blank DVD.
Because your Configuration is :
Read : CD / DVD
Write : CD
This means you have a combo drive. But to burn a DVD you should have DVD RW.
Mar 09, 2009 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
Problem wit my DVD writer
NO OS stated
NO PC stated.
NO job stated, just BURN something, vague.....
fail.
to burn a DVD takes skills
what is on said DVD, it can name 100 different vast things,
why not start with the missing story
what is it you wish to make? tell the helper what you are trying to do, a goal, like make my TV SOny DVD player play movies, using DVD movie format. (or bogus copies)
a real DVD movie.
a dvd with MP4 files. videos or 100 other types.
a dvd with data. (like docx files, xls, or ppt files? or?)
a dvd with songs, MP3 or 30 other types.
A dvd with software programs. like a copy of windows 7 install?
what?
Jun 11, 2017 | HP DVD 740VI 16X16 Dual Layer LightScribe...
Compaq Presario 700 470024-192 Notebook Logo
74 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
