1993 Lincoln Mark VIII Logo
Shirley Lucas Posted on Nov 28, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The left door handle broke. replaced it. when i reconnectec the battery, the radio speakers static. ichecked it today. the speakers are static, whine, syrens sound all aroud the speakers
Kaye Day
Level 3:
  • Master 744 Answers
  • Posted on Nov 28, 2015
 Kaye Day
Master
Level 3:
Answers
744
Questions
Helped
223180
Points
13385
Sounds like a grounding problem. Any wires or speaker wires in contact with metal when you replaced door handle?
What are the colors of my speaker wires in dashboard for 1997 Mercury mountaineer
Radio Battery Constant 12v+ Wire: Light Green
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Amp Trigger Wire: Blue
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): Dark Green/Orange
Right Front Speaker Negative Wire (-): White/Light Green
Car Audio Rear Speakers Location: Rear Doors
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Loud speaker static when the car is off. It drained that battery. I tried pulling the radio fuse but it was still making the noise. I had to disconnect the battery to get it to stop. Any ideas?
I GUESS that the speakers are driven by an after market amplifier. An amplifier needs to be connected to a power source that is only on when the radio is on, through a relay.
So I GUESS that:
  1. The wiring is incorrect. Or
  2. If is has a relay, the relay is stuck.
1helpful
2answers
Loud speaker static from 2002 Mitsubishi Eclipse when the car is off. It drained that battery. I tried pulling the radio fuse but it was still making the noise. I had to disconnect the battery to g
The fuse might be built into the cable to the lighterand/or radio. It's called "fusable link", this type of fuse looks like a cable. Or another type of fusable link might be in the fuse box under the hood near the firewall.
2002 Chevy Tracker ZR2 (small suv) outside, left, drivers door handle broke
You should have someone experienced with you to do this type of job, due to the complex series of tasks involved
No sound from speakers in 2000 GMC Yukon? Whats going on?
Instructions:
1 Disconnect the trucks negative battery cable.
  • 2 Unhook the clip for the door's manual window crank with a hooked tool behind the handle (or rub a rag behind the handle), or for a power window, pry off the window switch assembly from the door handle with a trim stick and disconnect its electrical connector.
  • 3 Pry off all small panels and bezels on or near the door with the trim stick, including the triangular panel on the mirror mount and the bezel surrounding the door handle.
  • 4 Unscrew and remove all of the mounting screws for the door's inner trim panel then pull the panel out to detach the clips. Disconnect all remaining electrical connectors on the door panel.
  • 5 Peel off the plastic water deflector sheet from the door.
  • 6 Press down on the speaker's upper mounting tab while grasping the speaker, then tilt the speaker out of the door frame and lift it off the tabs on the bottom. Disconnect the speaker's electrical connector.
  • Connect the replacement speaker to the electrical connector.
  • 8 Secure the speaker to the lower tabs and pivot it into the mounting hole, clipping it in place with the door's mounting tab.
  • 9 Press the plastic shield back into place on the door.
  • 10 Reconnect the trim panel onto the door, connecting all needed electrical connectors and engaging all its clips, then apply its mounting screws. Reconnect all smaller panels and bezels to the panel.
  • 11 Reinstall the window crank or control switch with its clip or electrical connector.
  • 12 Reconnect the black battery cable onto the negative terminal.
  • HID KITS.
  • 1helpful
    Front driver door has no power, I have checked the fuses but no controls will work
    This is a manufactures bulletin
    SUBJECT:
    Inoperative Right Front Door Switches OVERVIEW:
    This bulletin involves replacing the right door interior handle. The loss of ALL functions may occur when attempting to control them from any of the switches located on the right door due to electrostatic discharge through the right door interior handle. The right door interior handle must be replaced to protect the switch module from static electricity. The new handle is more resistant to electrostatic discharge. MODELS:
    2004 - 2008 (CS) Pacifica SYMPTOM/CONDITION:
    The vehicle operator may experience a permanent loss in ability to actuate ALL of the following functions from the right door switches: ^ Power door locks. ^ Right power mirror. ^ Right power seat adjustments. ^ Right power window control. ^ Right heated mirrors. ^ Memory functions associated with the listed systems on right side (if applicable). ^ Loss of communication with the right door switch module to Scan Tool: DIAGNOSIS:
    Perform a "Hard Reset of the right door switch module. This may be accomplished by removing all power (including memory keep alive power) from the right door switch module by unplugging the module power connector. Alternatively, vehicle power may be interrupted by removing the negative battery terminal when the ignition switch is in the OFF position. If after performing the hard reset functions of the right door switches return perform the Repair Procedure.
    PARTS REQUIRED:
    REPAIR PROCEDURE:
    1. Disconnect the negative battery cable. 2. Remove the right door trim paneldak408_80.gif
    3. Remove the door tweeter speaker. Refer to the service information in TechCONNECT. Refer to 8 - Electrical > Audio > Speaker > Removal (Fig 1). 4. Remove the power seat switch. Refer to the service information in TechCONNECT. Refer to 8 - Electrical > Power Seats > right Seat Switch > Removal. 5. Replace the right door interior handle, p/n 05170261AA, as described on Mopar Instruction Sheet K6855628 included in the handle kit. 6. Install the power seat switch. 7. Install the door tweeter speaker. 8. Install the right door trim panel. 9. Connect the negative battery cable.
    2002 4x4 tacoma replaced radio now door chime and stereo doesnt work
    2002 Toyota Tacoma Car Stereo Wiring Diagram
    Car Radio Battery Constant 12v+ Wire: Blue/Yellow
    Car Radio Accessory Switched 12v+ Wire: Gray
    Car Radio Ground Wire: Brown
    Car Radio Illumination Wire: Green
    Car Stereo Dimmer Wire: N/A
    Car Stereo Antenna Trigger Wire: N/A
    Car Stereo Amp Trigger Wire: N/A
    Car Stereo Amplifier Location: N/A
    Car Audio Front Speakers Size: 6 1/2′
    Left Front Speaker Positive Wire (+): Pink
    Left Front Speaker Negative Wire (-): Purple
    Right Front Speaker Positive Wire (+): Green
    Right Front Speaker Negative Wire (-): Blue
    Car Audio Rear Speakers Size: 6 1/2′
    Car Audio Rear Speakers Location: Rear Corners
    Left Rear Speaker Positive Wire (+): Black
    Left Rear Speaker Negative Wire (-): Yellow
    Right Rear Speaker Positive Wire (+): Red
    Right Rear Speaker Negative Wire (-): White
    Recheck your wire connections, good luck.
    Thank you for using Fixya
    2helpful
    I am putting in a cd player and i don't understand why it won't get power. i hooked it up staight to battery and it works just don't know which wire is power from the fuse block
    1995 Jeep Grand Cherokee Car Stereo Radio Wiring Diagram
    Radio Constant 12V+ Wire: Red/White
    Radio Switched 12V+ Wire: Red/Gray
    Radio Illumination Wire: Blue/Red
    Radio Dimmer Wire: Orange
    Radio Power Antenna Trigger Wire: Green/Red
    Radio Amplifier Turn On Trigger Wire: N/A
    Left Front Speaker Wire (+): Green
    Left Front Speaker Wire (-): Brown/Red
    Right Front Speaker Wire (+): Purple/Yellow
    Right Front Speaker Wire (-): Blue
    Left Rear Speaker Wire (+): Brown/Yellow
    Left Rear Speaker Wire (-): Brown/Light Blue
    Right Rear Speaker Wire (+): Blue/White
    Right Rear Speaker Wire (-): Blue/Pink
    When opening door with car off static comes from radio speakers, and left front speaker doesn't work
    Check the speaker wiring in that door and the rubber tunnel going between the door and post. likely the wire is chaffed and grounding Noise will show up in all speakers when that happens.
    2answers
    I am looking for a diagram or picture as to how to get to the speakers to replace them on a 97 villager??
    Section 15-03: Speakers 1997 Villager Workshop Manual DESCRIPTION AND OPERATION Radio Speakers All vehicle sound systems are equipped with radio speakers (18808) located at all four corners of the vehicle. The radio speakers are mounted in the RH front door (20124) and LH front door (20125), as well as behind the quarter trim panels (31012) in the rear of the vehicle. The Ford Super Sound Audio System has the addition of a subwoofer mounted in the RH quarter trim panel.
    Radio Speakers, Front Door Removal
    1. Remove the front door trim panel (23942). Refer to Section 01-05 .
    Trim Panel(s), Door Front
    Removal
    1. Disconnect the battery ground cable (14301) if equipped with power locks or power windows.
    2. svv~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use care when removing the front door inside handle escutcheon (22620). Failure to do so can result in damage to the component.
      Carefully pry off the front door inside handle escutcheon by inserting a standard 1/4 inch screwdriver between the top rear portion of the front door inside handle escutcheon and the front door trim panel (23942).
    3. Remove the three cover caps and front door trim panel screws.
    1. Remove the one front door trim panel capped screw from the door pull handle.
    2. If equipped with power windows, remove the door pull handle. Disconnect the electrical connectors.
    3. Slide a flat-bladed tool behind each of the retainers and twist the tool to disengage the front door trim panel from the front door (20124).
    4. Remove the front door trim panel.
    Door Electrical Connections
    Removal and Installation
    Refer to Section 01-11 for Power Window, Section 01-09 for Power Mirror, or Section 01-14B for Power Locks. Watershield
    Removal
    1. Remove the Front Door Trim Panel . Refer to the removal procedure in this section.
    1. Remove the front door watershield by carefully detaching it from the adhesive.
    1. Remove the four front door radio speaker screws.
    Top Lincoln Experts
    ZJ Limited
    ZJ Limited
    Thomas Perkins
    Thomas Perkins
    Are you a Lincoln Expert? Answer questions, earn points and help others
