Question about Hayward EC-40 DE Pool Filter with pump
Earth blowing in pool filter has no holes in it
  • 128 Answers
Inspect the manifold. There is probably a crack.
Posted on Aug 23, 2009
What would cause earth to blow into pool after pumping down pressure
DE filters are a picky item. if you have too much media, it will blow off. make sure to follow the instructions when doing a bump or replacement of media.
Jul 07, 2014 | Jacuzzi Avalanche 60 Sq. Ft. D.E. Filter...
I have an Hayward Pro Series S244T filter and I have had problems with sand blowing back into pool - the filter is only 2 years old
When sand returns to the pool, there is a hole in either the media or the sieve that is supposed to keep the sand in the filter.
All of the sand must come out of the filter, the sieve at the bottom (outlet of the filter) must be removed and any broken segments must be replaced.
The sand is then returned.
Gary
Apr 27, 2011 | Hayward SAND FILTER, PRO SERIES
De blowby entering pool replaced both gaskets in variflow as well as checked filter grids
If you have DE blowing back into the pool with this pool filter, there is really only a couple things that it could be. Either there is a hole in the grid fabrics or the o ring needs to be replaced. If you have checked the grids and don't see anything, it could be a hole that is not visible. You are probably going to have to replace the grid material.
May 29, 2010 | Hayward EC-40 DE Pool Filter with pump
Filter shoots diatomaceous earth and dirt,back into pool whenever pool is vac'd????
One of two things, maybe both. Either the spider gasket is bad, or you have some rips and holes in one or more of the grids. Sounds more like grids than gasket.
Jan 24, 2010 | Pentair FILTER TANK BOTTOM, 48 SQFT
We have an an Infinity DE filter. It's blowing DE back into the pool. We've replaced the filters.
Most likely the "fingers" inside the filter housing are worn out and causing the DE to blow out the return line to the pool.
Jun 12, 2009 | Hayward EC-40 DE Pool Filter with pump
D.e. earth pool filter returning dirt to pool
The flow tubes inside the filter canister are torn and letting dirt pass. The repair is simple and can be done by someone with a few hand tools. Download the manual for the filter here:www.haywardnet.com/products/Manuals/pdfs/manual9.pdf
You'll only need to replace the ones that are ripped, and the cost runs about $3 - $5 each. Search around on Google for a supplier or try a local pool dealer.
Jun 08, 2009 | Hayward EC-40 DE Pool Filter with pump
Water will not fill in pool pump
main filter blocked (try backwashing) or if using "earth" filter system - wash filters - change earth.
Jun 03, 2009 | Hayward 3/4hp Super Pump Inground Pool...
There's sand in my pool!
I have had this issue with several clients and before worrying, you might have had sand being drawn back into pool lines during winterization. this happens when you blow out lines, plug holes, but keeping it pressurized. if it keeps happening check draw fins on bottom of filter.
Mar 01, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward EC-40 DE Pool Filter  with pump Logo
138 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
