Question about Hydrofarm 2 Ft Green Thumb Grow Light System Model Gtv2
Ticking noise, not working
Ballast wont fire up, light doesnt come on, and makes ticking noise..
  • 634 Answers
2 things are the bulbs good? if yes disassemble the light and remove ballast look at power loads and find equal on at home depot Loews or light store
Posted on Jul 17, 2009
Truck wont start, interior lights flash
Check your battery terminals , are they clean and tight ? Next try to jump start your car. It may be that you have a bad battery.
Dec 05, 2013 | 2000 Mercury Mountaineer
My ballast making a humming noise but will not light up my 600w hps bulb?? small bit of purple light in the bulb when turned on but not lighting up?? tried a 400w bulb in hood with the 6oow ballast and...
NANOLUX BALLAST 400W-1000W
NANOLUX HPS and MH electronic ballasts can be light up
E-MAIL :cly@sznumber.com
Skype:sznumberballast
May 18, 2013 | Sunlight Supply 400 Watt Hps Sunsystem I...
Motorcycle wont start. It turns over ok but wont start. Usually when i turn the ignition key on there is a ticking sound for a few seconds but now it doesnt do that. is that the fuel pump that makes that...
Depending on the bike of course. The Yamaha V-Stars for example have a fuel pump that make a ticking noise from their pumps. Usually they start ticking fast and slows down to a stop when pressure is built up. Rule of thumb.....if it makes noise it is working. What yamaha is this and what year is it?
Aug 06, 2011 | Yamaha Road Star Motorcycles
It wont turn on anymore. it fires then instantly shuts off, doesnt even flash screen. standby lights still flash and its trying to turn on, just cant get on. you can hear the on sound and then the tv...
Depending on the age of your tv, if you hear a rapid clicking, it seems like your ballast is starting to turn on your tv but it's not able to. (1) Check your lamp, (2) reset the lamp timer, (3) make sure the cover panel is all the way. the positioning sensor might not be detecting the cover all the way in.
Personally I think you're experiencing a ballast problem.
Apr 20, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
1997 mountaineer has electricity but wont start, no ticking
You have a bad starter if all your connections are good and your battery is measuring 12.7 volts and above with engine off.
Jan 17, 2010 | 2001 Mercury Mountaineer
I turn tv on...green light comes on but i get no picture or audio....then light indicator blinks red
Hello!
Lamp or ballast(if lamp has been replaced) is bad.
Explanation: green comes on: system works, waiting for light to shine into light engine: no light is coming out of lamp, system shuts down, then you see red! how to determine: pull the lamp out of the unit's compartment. Inspect lamp: bloated stem? shuttered? reflector is not shiny? Chuck it!
Lamp looks good or just been replaced: try ballast. Close lamp compartment without lamp itself. Make sure, door is shut, as well. Turn unit on and listen close to lamp compartment: good ballast will make a buzzing noise, then stop. You've got "red'! No buzzing: ballast quit. Needs major repair! Lamp must be good, for sure, to get to the last part of diagnostics. Conclusion: more, than 2000 hours of usage: replace lamp first!
Good luck,
Alex.
Jul 29, 2009 | Panasonic PT-D5600U DLP Projector
Panasonic TV pt-50lc13 bulb replacement
Take the bulb out, there should be a access panel in the front, power the set on,(be sure to have the lamp door closed) if you hear a rapid ticking noise from the set, the Ballast is trying to fire the lamp, this is a good indication that the set is functional but the lamp needs to be replaced. If not, the ballast is not getting the voltage needed to start the lamp.
Sep 09, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Problem 2
The feint ticking noise usually indicates a dead hard drive.
The heads are flicking back and forth at random and make the ticking noise you hear.
The drive can still be detected because the physical hard drive and the controller board on it are in reality 2 seperate components working together. So the controller board is also trying to access the hard drive without luck.
If you have not dropped the unit or knocked it over etc, then chances are the controller board is what has died and therfore you still cannot access the drive. You may get lucky in finding a new controller board to replace a failed one and that will also get your data back.
May 14, 2008 | Acomdata 250GB External Firewire HD 250 GB...
Hydrofarm 2 Ft Green Thumb Grow Light System Model Gtv2 Logo
248 people viewed this question
Top Hydrofarm Garden Experts
Craig Butler
Craig Butler
Colin Stickland
Colin Stickland
Ed Hauk
Ed Hauk
Level 1 Expert
Are you a Hydrofarm Garden Expert? Answer questions, earn points and help others
