Question about Hotpoint Dryers
Safety Trip Hotpoint Aquarius CTD00 Is there a safety trip on this machine as the heater element has stopped maybe over heated. Can someone please inform me where the trip is located. Many thanks
  • 28 Answers
On the heater there will be a cut-off switch with a small hole where you can stick a needle in until you hear a 'click'.
Posted on Jul 27, 2009
Hotpoint wd420 shows error code f13 after replacing heater element for dryer.
Change electronic board it is what will cause this problem if you checked all ducts an fan and still heats board is bad
Oct 28, 2014 | Hotpoint Ariston Aquarius WD420 Front Load...
Our Hotpoint ctd00 keeps tripping the fusebox, we
Disconnect the heater thermostats by poulling a wire off each stat, and then try it, if it still trips, then could be faulty motor.
The stats are located at the rear of the dryer, behind removeable cover.
Mar 25, 2010 | Hotpoint Dryers
Aquarius ctd00 no heat, but heater element appears ok
Generally speaking, it is usually the thermostat/s that are the cause of the problem.
These are located on the top above the heater, or behind the heater element
Some models also have a relay that controls the heater, and these can fail.
this is to be found at the top of the dryer behind the console panel.
Mar 07, 2010 | Hotpoint Dryers
My hotpoint ctd00has stopped heating up how do i
You will find the thermostats located at the rear of dryer.
Remove cover, and you will see them adjacent to the heater element, change them both, even if only 1 is faulty.
Please rate my solution.
Thankyou.
Feb 01, 2010 | Hotpoint Dryers
Hotpoint dryer CTD00
Remove the lint filter at the front bottom left of dryer, and run water through it to clean all the fluff out. Clean the other filter, and make sure the air vents air clear.
Before you replace the bottom filter reach inside the opening and remove any build up of fluff and gunge that you can ,get a plastic bag tie or similar and feel for and poke clear a small hole that is located there.
I f it still does not work, then the element and or stats are probably faulty.
Plz rate my solution.
Thanks.
Jan 03, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius CTD00 dryer
how many fuses are there in a hotpoint tumble dryer CTD00 aquarius I know one is in the plug is there another one if so where is it?
Aug 18, 2008 | Dryers
Dryer cutting main power off after acouple of seconds
your heating element is the most likely cause of this. will need replacing
Nov 18, 2007 | Hotpoint TDC32 Electric Dryer
Aquarius 6kg wma52 blows main power breaker
yes check for a heater element down to earth or at least a wire on the element off and touching the case, but i am confident its a heater element, rate me when you fix it, work with safety unplug when working on machines
Sep 16, 2007 | Hotpoint Aquarius WMA52 Front Load Washer
Dryers Logo
199 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
