1993 Geo Metro Logo
P
PAUL bOLAN Posted on Nov 27, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
ON 1993 GEO METROS Is the WIRING THE SAME FOR BOTH TAIL LIGHTS?iN OTHER WORDS ARE THE LEFT AND RIGHT PIGTAILS THE SAME?Thank you Paul
_-__-___-_
Level 3:
  • Geo Master 20,706 Answers
  • Posted on Dec 11, 2015
_-__-___-_
Geo Master
Level 3:
Answers
20706
Questions
Helped
6803877
Points
57965
Same colors you mean?
or is this a physical question (shapes and fit up)
not knowing the job in hand makes answers hard.
the wires are same color. in most cars made.
but not the turn sigs wires,
park same
brake same
backup same
turns colors different.
alldata.com has the drawings, look yet?
I have a 1993 Geo Metro 3 cylinder 1 liter 5
6 posts this one, worse that all.
the word out , what does that mean,?
My 93 Geo Metro 3 cylinder 1 liter 5 speed fluids
6 posts. same out word.
what fluid, gasoline, water, oil , what? from WHERE?
2answers
What are the fuses on a 1993 Geo metro
click metro here
and read
http://www.fixkick.com/
see those 2 forums.
or here
http://www.teamswift.net/index.php
GEO swift?
if you own any GEO, ANY.
be proactive (its old) and buy the books, then ask questions.
http://www.ebay.com/sch/i.html?_odkw=1993+geo+metro+operators+guide&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.X1993+geo+metro+operators+manual&_nkw=1993+geo+metro+operators+manual&_sacat=0
or get an account at alldata.com
or join a real forum and ask there.
or google all week.
those are the DIY choices.
or google like this, google really is your friend....
https://www.google.com/search?q=1993+geo+metro+fuse+box&source=lnms&sa=X&ei=cxrNU7DaDMuTyASOrYCwAQ&ved=0CAcQ_AUoAA&biw=1120&bih=516&dpr=1.71
No headlights on dim only work on bright
old post.(day)
low beams, they are.
both low beam lamps.dead but are PARK/tail dead too?. (a key fact needed here to save time finding cause)
there are more that one cause.
but fuses are first, some cars have 2 fuse.
one for highs and lows.
or for left and right.
they do that so at least some lights work and not all go out at once, on a dark rainy night on a country road (or cliff road)
GEO, the car brand GEO is sold mostly in USA and Canada
if in CANADA the law says its DRL lamps.
in canada they have a Drylight Running lamps and laws and have a unique controller for that (DRL module) and can fail and mess up lamps. so GOT DRL>?
on this car the fues box shows, left and right HL
the next question is does it run a relay.
answer,
DRL, the DRL module runs low beams totally so that be first.
and its DRL relay.
non DLR metro, works like this
im reading the online schematics for you, and so could you.
the no-DRL is brutally simple.
the fuse runs the lamps direct, means lamps hot all the time.
the park and head light switch, grounds the low beam wire feed.
no relays , magic , DRL just a simple switch, in the combo switch.
for you or others seaching Metro head lamps.
here is the schemo.
red/wht wire must be 0v on low beams if not switch bad.
if g200 is good, but g200 is used in highs so can NOT BE BAD.
as you can see the switch grounds the HL lines below.
to make the lamps GLOW,
23880969-flsdwf0rx41rbdaez4cmhnol-2-0.jpg good luck to metros
My tail lights are out, but my brake lights work all fuses are good don't get it
Check the bulbs because they have two lights in one bulb. One for both.
1995 geo metro tail lights won't come on
You need to check to see if you are getting power to the tail lights and if you are not getting power check for a blown fuse. If you are getting power check for a blown bulb or bad socket. Now if you are not getting brake lights and you are calling that tail lights then the issue maybe in the brake pedal switch so make sure its actual tail lights out and not brake lights.
1helpful
I just had a clutch replaced in a 1993 Geo Metro, but I can't get it to start. The battery has been charged and the clutch switch has been checked. Could there be something not plugged in that needs to be,...
Theres a very strong possibility that something wasn't replugged back in, first thing i would check being the clutch was replaced is the starter make sure all related wiring going to the starter has been reconnected and clean, a wire left disconnected from your starter will most likely be the problem your currently experiencing....
I need wiring diagram for tail lights of 1995 geo metro
need your email so i could send you pdf file
Geo metro dies
Your catalytic convertor is stopped up, common problem on Geo's! Will burn an exhaust valve if you keep driving it!
1993 Geo Prizm 1.6L Won't start and has no spark at the spark plugs. Distributor coil seems fine. Got one from junkyard and got same reading from both through meter. Lights come on and windshield wipers...
Hello!
Can you see if the rotor in distributor is turning whilst engine is cranked? or if the Cam is turning by looking through the oil filler while someone turns the key.
If they aren't turning/revolving then you may unfortunately be suffering a timing chain/belt failure.
Sorry to bear bad tidings if this is the problem.
Paul 'W'
Top Geo Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Geo Expert? Answer questions, earn points and help others
