Question about Philips SHM3300 Headset
My speakers are built into my monitor how do I disable it to get my headset to work?
    Problem Solver:
  • 18 Answers
Try controll panel / sounds and audio devices.
Posted on Jul 14, 2009
How do I get volume on my Dell 2414H Monitor?
I believe this monitor does not have a built-in speaker. If you have the optional hang-on speaker, it must connect to the laptop's speaker/headphone port (speaker's green connector cable/plug). You cannot use the external speaker and the headphone at the same time unless you are using a Y connector cable.
This monitor has a VGA and a DVI-D ports for video input. Neither supports sound.
I hope this helps. Dell 24 Monitor P2414H
Oct 29, 2015 | Dell Computers & Internet
When i connect my headset, the sound come from both headset and speakers and my mic is not working
When you insert the headphone jack into the "audio-output" jack,
which should be GREEN coloured, it should mechanically disable the built-in speakers. If that does not happen, you're connecting it to the wrong socket.
Be sure to insert the microphone's jack into the PINK socket, which is the "microphone-input" socket.
Sep 27, 2010 | Computers & Internet
Can someone tell me step by step, where is the microphone located on the Hanspree 20" flat panel LCD monitor? I can't find any info in the manual on this. I go on to Skype and my speakers work but not the...
Hannspree says they don't offer a 19" LCD with a built-in microphone. If there is one, I can't suggest you use it as noone would be able to understand you well.Their built-in speakers,also, are notorious for low power and poor, tinny sound. the addition of a USB or audio card compatible type headset is recommended for most voice applications, including Skype. Tigerdirect.com, overstock.com or walmart.com all have inexpensive headsets and stand alone mikes. Hope this helps some:)
Aug 20, 2010 | Hannspree 19" Widescreen LCD Flat Panel...
Built in speaker does not work but headset is work hp pavilion dv6000. thank you
The speaker of your computer has a problem not the sound card device because when you're using headset its work. Try to use the external speaker when they are functioning, automatically you need to replace your built-in speaker to fix that problem.
May 30, 2010 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Need to turn off internal audio on flat screen to use headset
When you plug in a headset or mic into the bottom or the side of the monitor, this should automaticly disable the internal speakers on the monitor.
May 26, 2009 | Acer AL1717 17" LCD Monitor
No sound from headset plugged into monitor
From the manual I found, this model does NOT support ANY audio connections.
http://www.p4c.philips.com/files/1/170b1a/170b1a_dfu_aen.pdf
170B Product Features
- 17" color LCD monitor with excellent display performance.
- Dual input-accepts both DVI Digital and VGA Analog input.
- Advanced AUTO adjustment automatically optimizes picture quality.
- Wide viewing angle technology.
- 7.1 (181mm) small footpring with full detachable cables.
- USB Bay for upgrade to USB Hub.
- Optional protective cover to prevent LCD panel damage.
- Standard VESA mounting holes and optional tilt/swivel Wall Mount Kit.
But if yours does have these ports, I would suggest they are not for a headset, but for connection to the _PC_. I would suggest your model monitor has built in speakers, and the green port is the INPUT from the PC Speaker output. The pink goes back to the PC from the MIC which is built into the screen.
Apr 21, 2009 | Computers & Internet
No sound from inbuilt speakers
this may be a second post since it appears that fixya didn't take the first one:
you should have a speaker cable in addtion to the monitor cable (big thick cable) coming from the monitor. the speaker cable (much thinner with similar plug as free standing speakers) needs to be plugged into the sound output jack on the back of your computer (jack is possibly colored green).
Mar 30, 2009 | Computers & Internet
WHERE DO I HOOK UP A HEADSET AND MIC AT ON THIS MONITOR?
Your monitor may not have an audio connection built in.
You'll have to use the speaker and mic jacks on the computer if there are none on the monitor.
Mar 12, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
Want to turn off logitech headset and turn on monitor speakers
I know this works on Windows XP:
Settings -> Control Panel -> Sounds and Audio Devices -> Audio Tab
Select your normal input/output from the dropdown list (not the one that says Logiteck USB headset)
Important step - Close the program you were trying to change the audio for, and open it again. It should work. If not, leave it for a minute and try again.
Feb 21, 2009 | Logitech ClearChat Pro USB Headset
Headset and inbuilt speaker works at same time
Can you not just disable the built-in speakers in control panel while you're chatting on the mic?
-Aaron
Jul 30, 2008 | Acer Aspire 3680 Laptop
Philips SHM3300 Headset Logo
179 people viewed this question
Top Philips Radio Communications Experts
Computer Repairing
Computer Repairing
wwlvictoria
wwlvictoria
kiranbodapothula
Are you a Philips Radio Communication Expert? Answer questions, earn points and help others
