Question about Fujitsu 24R1 Air Conditioner
I have a ast24rsg-w after 3 minutes the circut breaker blows
I have a ast24rsg-w it turns on,then after 3 minutes it blows the circut breaker when the compressor should cut in ,can anyone out ther who knows what causes this let me know ,please...thank you Rod
    Champion:
  • 233 Answers
This sounds like the compressor has shorted to ground, must be verified by ohm check
Posted on Jul 15, 2009
Compressor air condition wont turn on circut breaker goes out
open panel on outside will probably find something burned
Sep 08, 2014 | Heating & Cooling
14 in. saw with leeson motor
To start with what size circut are you trying to run the saw on? What ever the amperage is on the saw will draw almost 3 Xs the amperage rating of the saw on start up. If the circut is a 20 amp the breaker should hold long enough to start the saw. Also the saw should be the only thing running on the circut at the time. A 1-1/2 hp motor is a good size one aproximately 15.2 amps If you circut breaker is twenty amps and you still pop the breaker you may want to convert the motor to run on 220 volts as that will drop the load to approx. 7.6 amps Youcan run the saw on a 20 amp. 220 volt circut with no problem unless there is a problem with the motor. If the outlet is the only outlet on the circut it is an easy change to convert the circut.
Mar 02, 2013 | Target Portable Masonry Saw PS1411S...
I have a kenmore a/c it blows cold air but it keeps blowing the circut braker It just started doing that about a week ago never did that before
Something has change huh? Is this the only appliance on this circut? If so then I would be looking as a couple of things. But let me ask you this first. when you turn the unit on does it blow the breaker when the compressor comes on? How long does it run before it tripps the breaker? are the indoor fan and out door fan operating the way they have in the past ? meaning does it sound the same as it had? It may well be something minor/ Let me know Jon
Aug 07, 2011 | Heating & Cooling
Hatco c-9 booster heater won't heat, 1 amp fuse keeps blowing
that is in the control cicut the contactor might be bad and taking out cntrl fuse.unhook contactor control voltage by unplugging from contactor tape off the two wires put new fuse in turn on power if fuse does not blow replace contactor.if it does blow you will have to isolate the next thing in the control circut maybe the light.you can buy resetable 1amp circut breakers at grainger for test purposes.sometimes on people I know I will wire in those breakers for them no more buying fuses.
Apr 11, 2011 | Hatco Corporation Compact Electric Booster...
Circut breaker blows sometimes when heater fist
u probably have a lot on that breaker and on startup units always pull a lot more amps cause starting up is like when u start off in a car u have to push the pedal more to get up to speed once u get there u barely have to push the pedal at all so this is gonna be a problem look on the info plate and see what the amps are or it may say f.l.a. (full load amps)
Feb 25, 2010 | Heating & Cooling
Hobart Ultra Arc 350 3-phase blows breaker in fuse panel
if you have a airgas dealer they carry hobart parts im not sure why you are blowing circut brackers unless they arenot big enough
Aug 17, 2009 | Welding Tools
My dehumidifier keeps blowing the circuit breaker. It has never done this before - 3 years.
As the unit gets older the motor will cause more load on the circut, also after years of use the breaker will trip easier. Replace the breaker and you may get more use out of the unit but most likely you will have to replace the unit.
Jul 14, 2009 | Ebac HD880 Dehumidifier
Fujitsu a/c ast24rsg-w blows fuse after 3 mins as comp starts up
It sound like you have a direct short in the compressor ,Usually it means you have a bad compressor,but sometimes it could be a loose wire or bad outdoor motor. Ive installed about 10 of these units and still have yet to have a bad compressor.It could also be a bad circuit board in the outdoor unit.I wish I could narrow it down better but thats my best guess!Thanks ---Nate
Jul 14, 2009 | Fujitsu 24R1 Air Conditioner
Oven igniter blows circut breaker
The ignitor is likely shorting out. Hope this helps!
Feb 16, 2009 | GE Spectra JGBP30 Gas Kitchen Range
Fujitsu 24R1 Air Conditioner Logo
136 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
