Question about Exercise & Fitness
Hi we have a Jazfit T50A with a fault code EO will not work anymore and locked in top speed before total failure
3 Suggested Answers
  • 131 Answers
SOURCE: WHIRLPOOL RF385PXG
If a new temp sensor doesn't fix an F3, you have a loose connection, or the electronic control is bad.
Posted on Mar 10, 2008
protek480
  • 1714 Answers
SOURCE: Kenmore Model 665 95781000 Stove Displays a EO-F3
F3 - E0 Oven temperature sensor (RTD) opened (upper oven, if double oven) Replace Oven temperature sensor (RTD)
Posted on Sep 26, 2009
2006 ford crown vic abs code b1596
B1596 ABS Module Service Continuous Codes NOTE: If other DTCs are present, REPAIR them before installing a new component.
TURN the ignition switch to the OFF position and wait at least 30 seconds. Turn the ignition switch to the ON position. REPEAT the ABS self-test. If any DTCs are retrieved, REFER to the Anti-Lock Brake System (ABS) Module Diagnostic Code (DTC) Index. If no DTCs are retrieved, CARRY OUT a drive test above 15 km/h (9 mph), then REFER to the symptom chart.
Anti-Lock Brake System (ABS) Module Diagnostic Trouble Code (DTC) Index DTCs DTC Caused By Description Action B1342 ABS Module ECU is Defective INSTALL a new ABS module. REFER to Anti-Lock Brake System (ABS) Module in this section. B1484 ABS Module Brake Pedal Input Open Circuit Go To Pinpoint Test D . B1596 ABS Module Service Continuous Codes NOTE: If other DTCs are present, REPAIR them before installing a new component.
TURN the ignition switch to the OFF position and wait at least 30 seconds. Turn the ignition switch to the ON position. REPEAT the ABS self-test. If any DTCs are retrieved, REFER to the Anti-Lock Brake System (ABS) Module Diagnostic Code (DTC) Index. If no DTCs are retrieved, CARRY OUT a drive test above 15 km/h (9 mph), then REFER to the symptom chart. B1676 ABS Module Battery Voltage Out of Range Go To Pinpoint Test E . C1145 ABS Module Speed Wheel Sensor RF Input Circuit Failure Go To Pinpoint Test B . C1155 ABS Module Speed Wheel Sensor LF Input Circuit Failure Go To Pinpoint Test B . C1165 ABS Module Speed Wheel Sensor RR Input Circuit Failure Go To Pinpoint Test B . C1175 ABS Module Speed Wheel Sensor LR Input Circuit Failure Go To Pinpoint Test B . C1222 ABS Module Speed Wheel Mismatch Make sure the tires are the same size and correctly inflated. INSPECT the wheel speed sensor rings. CLEAR the DTC. TEST drive the vehicle. REPEAT the self-test. C1266 ABS Module ABS Valve Power Relay Circuit Failure Go To Pinpoint Test K . C1296 ABS Module Wheel Speed LF Signal Fault Go To Pinpoint Test C . C1297 ABS Module Wheel Speed RF Signal Fault Go To Pinpoint Test C . C1298 ABS Module Wheel Speed RR Signal Fault Go To Pinpoint Test C . C1299 ABS Module Wheel Speed LR Signal Fault Go To Pinpoint Test C . C1300 ABS Module ABS Hydraulic Pump Motor Circuit Failure Go To Pinpoint Test A . C1805 ABS Module Mismatched PCM and ABS Modules Do Not Match CHECK the part numbers. INSTALL the correct module. C2775 ABS Module TC ON/OFF Switch Stuck Failure Go To Pinpoint Test H . U0073 CAN Bus Control Module Communication Bus Off REFER to Section 418-00 . U1900 CAN Bus CAN communication Bus Fault - Receive error REFER to Section 418-00 . U2023 CAN Bus Fault received from External Node REFER to Section 418-00 .
Jan 14, 2013 | 2006 Ford Crown Victoria
Tip
Komatsu Fault Codes
E02 PC-the EPC system;
E03, Swing parking brake system;
E10, the engine controller power failure, the engine control drive system circuit malfunction (this engine stall;
E11, the engine control system failure (decrease of output power, in order to protect the engine);
E14, the feedback system abnormalities;
E15, engine sensors (temperature, fuel pressure, oil pressure) fault;
EOE, a network failure.
The fault code: the 989L00 the engine controller lock warning (mode 1).
989M00, the engine controller to lock warning (mode 2).
989N00, the engine controller to lock warning (mode 3).
AA10NX air filter clogging.
AB00KE charging voltage is too low.
B @ BAZG, low oil pressure.
B @ BAZK, the oil level is too low.
B @ BCNS, engine coolant overheating.
The @ B BCZK the coolant level is too low.
B @ the HANS, the hydraulic oil from overheating.
CA111, the engine controller internal fault.
CA115, the engine speed sensor and backup speed sensor failure.
CA122, the intake air pressure sensor feedback voltage is too high failure.
CA123, the intake air pressure sensor feedback voltage is too low failure.
CA131, the throttle plate sensor feedback voltage failure.
CA132 throttle plate sensor feedback voltage and low failure.
CA144, high coolant temperature sensor feedback voltage fault 145, the coolant temperature sensor feedback voltage is too low failure;
CA153, intake air temperature sensor feedback voltage is too high failure;
CA154, intake air temperature sensor feedback voltage is too low failure;
CA155, the intake air temperature is too high (over limit);
CA187, sensor power supply voltage is too high failure;
More Fault Codes HERE http://truckmanual.weebly.com/komatsu-fault-codes.html
on Dec 20, 2016 | Cars & Trucks
Code 72 antilock brake light on. engine does not run correctly
72 Transmission code - Vehicle Speed Sensor (VSS) signal loss (4L60-E)
This code is the result of a failed VSS module. This device is the principle speed rate indicator that relays information to the speedometer and other monitoring or corresponding devices, as well. It may need to be adjusted or replaced. Have this device inspected for faults, immediately.
Concerning your Anti-lock brake light:
This could be a totally unrelated issue concerning the state of the anti-lock braking assembly. I would suggest to have this area inspected for faults, as well. Most anti-locking mechanism are linked to the VSS to monitor speed when hard braking is administered. This information is used to calculate the rate of speed and the amount or resistance needed to stop the vehicle safely, without skidding.
Nov 28, 2010 | 1994 GMC Sonoma
My BMW 650i convertible top alarms and says "The convertible top is unlock! Reduce Speed!" but the top is locked. As a result all the windows and trunk are locked open because if you touch the button to...
Hi Reba. There are a few sensors that can fail or need to be adjusted. A BMW repair shop should be able to diagnose the convertible top and get a fault indicating which sensor is acting up. The most common sensor failure is the rotation angle sensor on the driver side near the left rear corner at the convertible top hinge.
Sep 10, 2017 | 2007 BMW 650i Convertible
Electric kitchen aid double oven gives eo message
there should be more of a code like fo/eo or f2/eo or f3/eo or f5 /0o .. if you have # 1 = analog t digital l failure / replace control..= #2 shorted key pad / = replace control /? # 3 oven tempt sensor = repl oven sensor or fuse .// # 5 ck door /latch sw = replace component .. hope this helped . mm ( re/ck codes and see if one of thes matches your problem .. mm pls leave feed back ..
Dec 12, 2009 | Washing Machines
Kenmore Model 665 95781000 Stove Displays a EO-F3 code and the oven does not work WHat part work be defective to give me this fault code EO-F3?
Sep 25, 2009 | Ovens
Canon pc-6re error code EO 10
E010 Clock pulses fail to be generated or the PLL lock fails to be released due to a fault in the main motor, etc. Related drum drive unit and main drive unit
There is a problem with the motor of the drum or the main motor itself.
Nov 08, 2008 | Canon IMAGERUNNER 6570 Copier
EO F2 code
hi, this appears to be a fault caused by a short in your keypad - electronic range control (ERC)
this needs to be replaced unfortunatly.
To assist you finding the proper part your model numbel means that the oven is manufactured by Whirlpool for Sears/kenmore.
Oct 24, 2008 | Kitchen Ranges
Errror code
HI. thanks for the question. the fault code EO F2. means the touch pad key board is the problem. to repair new parts listed . thanks the appliance doc
Sep 16, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
WHIRLPOOL RF385PXG
Feb 09, 2008 | Whirlpool RF380LXPS Electric Kitchen Range
Exercise & Fitness Logo
125 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
