Question about Prima CV2011 TV
Q2770 problem The front panel doesn`t work niether does the remote but the TV turns on channel 3 nothing else . Any idea ?
  • Anonymous Feb 13, 2008
    wont turn on with remote or manual buttons
  • gunrunner999 Dec 24, 2008
    My tv has the same problem.  I don't have the manual.  A red lock appears in the top left hand corner and nothing works.  Anyone know how to fix this?
  • 749 Answers
Search on its manual if if has a LOCK feature! if it is lock then it would be fixed on a single channel. Lock feature was designed to prevent children from playing with your TV channels and volume and everything on the remote!
Posted on Nov 17, 2007
Sanyo vwm390 vcr
That might be the TV output channel. I found these instructions in a Sanyo manual:
How to set the DVD+VCR's RF output channel 1. Set the TV to the VCR channel (3 or 4) depending upon the selected channel. 2. When the DVD+VCR is turned off, press and hold CHANNEL (V/v) on the front panel for more than five seconds. It will turn itself on and "RF03" or "RF04" appears in the dis-play window. 3. Press CHANNEL (V/v) on the front panel or CH/TRK(v/V) on the remote control to change the RF output channel (CH 03 or CH 04). 4. Turn off the DVD+VCR.
It might solve the problem!
Jan 01, 2014 | Televison & Video
I have a 24 inch sanyo flat screen tv it is stuck on video and when I try to change the channel nothing happens I do not have the remote controller for this tv or any universal controller in general w
tried with unplugging and re plugging the tv doesn't work?. if not, tried to push any button like the channel up/down button and tv/video button at the front panel.
Oct 15, 2012 | Computers & Internet
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
Sep 23, 2012 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
Can't get "no signal" off
Hey cthaemar, it sounds like it may have been switched off the correct channel. If it is hooked up with a Coaxial cable it will be on channel 3 or 4, and if it is hooked up with an AV cable then it would be on one of the inputs.
If it's channel 3 or 4 try pressing the gray TV button on the remote and changing the channel. If that doesn't work you may need to use the TV's remote or the TV itself.
If it's on an input press the same gray TV button and then try pressing Input. With this you can also try the TV remote or the TV itself to change those if our remote doesn't change it.
Let me know if you have any other questions or concerns!
Tommy Faust
DISH Network
Jul 12, 2011 | DISH Network 322 DTV Receiver
1 Answer have to hit the power button multiple times to turn off tv 2.when watching a channel the tv starts scrolling through the channel set up. It eventually stops but then you can't use the remote and have...
Sounds like a tact switch problem at the front of the set. The switches are just behind the front panel buttons. Don't replace just one. Replace them all. They are not expensive and will avoid trouble later. If one switch is getting stuck internally, nothing else will work including the remote.
Oct 15, 2009 | RCA Televison & Video
Toshiba 35a44 problem
check the following power supply components
power transistor of the supply
zener diodes
rectifier diodes
Oct 15, 2008 | Toshiba 35A44 35" TV
Front panel button turn tv on and off
If both the remote and the front panel buttons do not work, I would be thinking that it is a problem with the TV's main uPC area. This type of fault can be involved, and would require factory level service where the fault can be properly analysed.
I can tell you in advance, that this type of fault can be expensive to service.
Jerry G.
Jul 30, 2008 | RCA TruFlat 27F520T 27" TV
Lost Remote
First you want to go press the menu button on the front of the tv. Second, choose channel set. Third, choose add/delete and manually preset each channel. You can try just adding channel 3 if you have cable. This will turn the tv back on and out of game mode...
Feb 04, 2008 | Durabrand DWT1905 TV
FPA lock settings, No remote, can not power on TV
If you forget your password you can reset it. Make sure the TV is off. Simultaneously press and hold VOL< on the TV?s front panel and CLEAR on the remote for approximately 5 seconds. Enter a new password next time you access the PARENTAL CONTROL menu. Front Panel Lock 1. From the PARENTAL CONTROL menu, press the up or down arrow to highlight Lock Fr. Panel. 2. Press the right or left arrow to turn on (box has check mark) or off (box doesn?t have check mark) front panel lock. Of course if you don't have a remote that can bring up the menu I don't know how this can be done.
Sep 12, 2007 | RCA 27F650T 27" TV
Problem with televison...please help
Replace IHVT aka flyback #257805 or Asti 2078.
Mar 29, 2007 | RCA F32650 32" TV
Prima CV2011 TV Logo
180 people viewed this question
Top Prima Televison & Video Experts
romy sibug
romy sibug
Jerry Greenberg
Jerry Greenberg
Are you a Prima Televison and Video Expert? Answer questions, earn points and help others
