Question about Edimax Computers & Internet
Why my pc does not read my edimax hub? - Edimax Computers & Internet
Associate wireless router to my home hub
If your Home Hub is a BT type internet hub, then you can connect the WAN port to the Ethernet port on the Hub.
This means it will go through two routers. One in the Hub and another in the Edimax. The Edimax needs to be configured as a bridge, because you need to keep within the same address range as the BT router. The Edimax DHCP allocation of IP addresses need to be disabled. This is not on the web site.
EDIMAX Technology Official Website Wireless Routers 300Mbps Wireless...
Mar 02, 2015 | Edimax Network Br-6428ns Wireless N 300m...
Unable to connect to edimax ew-7438rpn
If you are talking about accessing the router to reconfigure it, you should read this first as Windows 7 has a problem with the PIN code used.
http://www.edimax.us/html/Faq/PIN%20code%20not%20existed%20on%20the%20router.pdf
Jan 17, 2014 | Edimax Network EW-7438RPN Wireless N 300M...
On my edimax es3116p when 1 pc is connected the other remaining pc cannot connect how to fix
Well the problem is probably due to the fact that you are trying to share a 1mb/s connect. Thats not a lot of bandwidth even for 1 computer. So when you have multiple PCs all fighting for that 1mb/s you will certainly have slow or what appears to be n connection. Now if your second PC is not getting an IP address well then you probably have an issue with DHCP.
May 11, 2012 | Edimax ES 3116P (ES-3116P) Networking...
My edimax hub not working its always saying that network calble is unplug
The network cable maybe faulty, see if it works with another network cable.
Also power off the hub wait 30 secs and power up the hub again.
Sep 03, 2009 | Computers & Internet
Defalt code and password for a edimax br-6204wg
The default settings for your router are : 192.168.2.1 User name :admin and the Password is : 1234
Jun 18, 2009 | Edimax Computers & Internet
Problem with internet when using LAN
You have to set-up proxy setting for the same thing
If both your system is having Win xp then please activate internet connection sharing which is there at the network properties
or you can install 3rd party proxy also
just chek with ping uitlity weather it can ping with each other
Mar 14, 2009 | Edimax ES 3108P (ES-3108P) Networking...
Computers & Internet Logo
51 people viewed this question
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Michael Vincent Cruz
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
