Question about Savin 2575 Black and White Copier
Savin printer showing E 54.What does this mean?
If it's actually a Savin 2575, then you're missing a digit in the error message; However, any Savin machine that gas an error of '54x' relates to a fuser problem, and it can only be reset in service mode after the problem is fixed.
Posted on Jul 17, 2009
2 Suggested Answers
  • 1297 Answers
SOURCE: I have a savin 9113Z that is flashing a 54 error c...
Chekc or replace the fuser unit thermoswitch and thermistors.
Posted on May 22, 2010
I have a savin 9060 and it is telling me I have an error 92 can u help me??
What do error codes 91 and 92 in the error log mean?
91: The job was reset by the device.
92: The job was manually reset by a user.
Dec 18, 2014 | Savin 9060 Copier With Feed, Finisher,...
Error code sc396
Drum motor bind. mechanical bind or defective motor. Hard to tell without a model #
Mar 05, 2012 | Savin Office Equipment & Supplies
Sc396
Drum motor bound or defective
Mar 05, 2012 | Savin 8035e Copier
Savin c2824 wont print pdf files
If its showing drivers for a different machine then the first step should always be to completely remove and reinstall the drivers for the correct unit.
Mar 02, 2012 | Savin Office Equipment & Supplies
My Savin SDC 103 has an SC-172 call service error. The copier was given to me, it only has 7800 copies on it. The error showed up after they moved it.
That code is related to the scanner unit.
Probably after they move the machine the lamp went out of position.
I advise you to see the all scanner; Lamp, Mirrors, White plate...
May 23, 2011 | Savin Office Equipment & Supplies
I have a savin 9113Z that is flashing a 54 error code.what is wrong?
May 16, 2010 | Office Equipment & Supplies
I have a Savin 9113Z copier that is giving me a error code of 54. Any advice
Hello sir; You do need to reset this error code, procedure as follow;
press 71,hold down "clear/stop"key, until you see the "." in the upper left cornor of the display, then release, after that you press "clear/stop" key again then press lighter key, the 5 will now flash on the display, now enter 97 press start, turn machine off and back on , machine should be running.
Jan 04, 2010 | Savin Office Equipment & Supplies
Gestetner DSC332 SC393-02
Hello klwhite,
The answer to your question:
Savin.......3224/3828/2820
Ricoh......2232c/2238c/2228c
The error code means that there is a problem with the yellow dev unit. The manual says that "during warm up" the TD sensor saw .78 volts or less when it performed process control. We both know that this device may perform process control at times other than warm up. Sounds like the yellow dev unit is the problem as the sc393 means td sensor and the 02 means yellow developer unit. I truly hope I have helped you. Take care.........spinal......
Apr 25, 2008 | Gestetner DSc332 Copier
Savin Printer
There are initialization cards with printers. They look like credit cards or odd shaped key cards.
They need to be inserted into a slot reader on the machine to activate or reactivate them.
It should have come with the printer.
Feb 19, 2008 | Office Equipment & Supplies
Savin 2575 Black and White Copier Logo
245 people viewed this question
Top Savin Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
Don  Farrell
Don Farrell
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
