Question about GE WBSR3140DW Top Load Washer
GE Top Load Washer 10 yrs. old, used for 3 years, stored after that
Since taking the washer out of storage, washer goes through wash cycle, gets to spin cycle, motor seems to labor and trips breaker. HELP!!!!!
  • 32 Answers
Re: GE Top Load Washer 10 yrs. old, used for 3 years,...
The water must drain out of the tank b4 it can spin make sure the pump is working ok
Posted on Dec 21, 2007
0 characters
3 Points
I am looking to buy a used Frigidaire GLWS1233AS2 Top Load Washer and GLER331AS2 . They are supposed to be 3 years old. Are they good machines or do they have lots of problems?
Mine is 10 yrs old and I am just now having a problem. Clothes are too damp after last spin cycle. Hopefully, I'll get an answer here soon. Another problem I noticed a few months after I got it, with this model, is the fabric softener dispenser on top of the agitator. You have to remove it every single time and clean it. I added a little water to it before adding fabric softener and thought that would help to stretch the cleaning to maybe once or twice a week. Don't do it! I started to smell mildew and found out why. The agitator shaft that this dispenser sits on was caked with old fabric softener. I just use the blue Downey ball now. The fabric dispenser stinks but I have had 10 yrs of good washing.
Feb 14, 2013 | Frigidaire GLWS1233A Top Load Washer
GE Profile WPRE6100G Top Load Washer My washer is 2 yrs old and has started to make a loud metalic banging noise during the wash cycle. It does not during the spin cycle. Doesn't seem to matter whether...
The "Metallic banging/clicking" sound you hear is the Shifter mechanism engaging or disengaging.
The drive system will engage at the start of the Agitate Cycle and disengage when the Agitate Cycle is complete. This occurs multiple times during the wash. GE claims this is a normal sound and should not be concerned about it. Check page 10 of your Operating Manual, if you do not have a manual, click on this link to download one
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 03, 2010 | GE Profile WPRE6100G Top Load Washer
GE Top Loader 10 years old. won't drain
Timer is faulty and should be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | GE WBSR3140DW Top Load Washer
Spin cycle stopped on 10 yr old Amana washer
its the brushes on your motor or your pump is blocked or defective
Jun 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Wsxh208fww front load stackable washer, spin cycle won't work
It most likely has a bad door safty switch. This goes out and the cycles will not run.
Jun 15, 2009 | GE WSXH208A Front Load Washer
GE Profile washer will not drain. (DOES SPIN)
take the front off the washer take the two hoses off the pump youll probably find where its stopped up
Apr 24, 2009 | GE Profile WPRE6100G Top Load Washer
How do i remove top or front cover on GE washer
2 clips 1 one each upper corner about 3 ins in use putty knife to release clips pull panel forward at top and lift off
Nov 20, 2008 | GE WWSE5240D Top Load Washer
Washer not working.
Renee, after you hit your wash cycle selection does the washer begin to fill with water and rotate the wash basket? I need to know what does work , it will tell me what does not. capnhook
Oct 01, 2008 | Maytag LSE7806A Top Load Stacked...
GE WDSR2080D5WW Top Load Washer
sounds like the agitator is bad not hard to replace look up on internet agitator replacement for that model
Sep 10, 2008 | GE WDSR2080D Top Load Washer
Washer stops after wash cycle
the timer is bad you could try cleaning the points by taking it apart very hard to do though
Aug 27, 2007 | Kenmore 23822 Top Load Washer
GE WBSR3140DW Top Load Washer Logo
210 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
