Question about Tamron AF70-300mm f/4-5.6 Di LD Lens
Err 99 with canon 350d
Why this problem
    Brigadier General:
  • 7,191 Answers
This error may be displayed if you use a non-Canon lens and the camera or the lens does not operate properly. Remove the battery and re-install it. If the problem persists, get your camera / lens checked by a qualified technician.
Hope this works. Thanks.
Posted on Jul 14, 2009
Canon 350D error 99
Err 99 could mean several different things, such as... Memory Card
Lens
Lens contacts....
A few things you can try.
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card may be bad.
Try another lens if you can
Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens)
I have heard Canon recommend upgrading the camera's firmware (go to Canon's website todownload
the latest firmware and follow Canon's instructions for the upgrade).
I saved the worst for last, Err 99 could be related to the shutter failing which would mean a trip to Canon for repair.
Good Luck
Jun 15, 2011 | Canon Rebel XT / EOS 350D Digital Camera
How to solve the err 99 dialog on my canon EOS 400D?
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thank you!
Apr 13, 2011 | Canon Rebel XT / EOS 350D Digital Camera
Hi sometimes it takes a picture with no problem but sometimes I get err 99 or err 01. Any ideas?
Hi! Welcome to Fixya
Thank you for choosing Fixya!
Feb 08, 2011 | Canon Rebel XT / EOS 350D Digital Camera
After a few shot,my camera show "Err 99"
There's a very comprehensive essay about the various possible causes of Error 99 here (follow link).
Jan 21, 2011 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS Xt displays Err 99 how do I fix it.
change the lens or try cleaning the connector tabs with a eraser.
Jun 26, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Err 99 in canon 350D
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Apr 06, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Err 99 & err cF in my canon 350d camera
had the same problem before
found this guide online
4. Insert a fully charged battery, and turn on the camera.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
If the “ERR 99′ message only appears when one particular lens is
If you see the “ERR 99′ with a different Canon lens attached, then the
camera should be serviced.
Jan 28, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Err 99 on canon rebel xt 350 d
The Err 99 problem occurs due to dirty contacts between the body and the lens. I recommend cleaning the contacts. You can then turn Off the camera and then remove and reinstall the batteries to reset the camera to get the problem fixed.
Jan 15, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel Xt EOS Err 99
Error 99 is a "catch all" error that has several causes. It could be that your battery is not fully charged, especially if it is a generic, non-Canon battery. Charge for at least over night even if the charger says it's full. If that's not the cause, switches inside the camera will have to be cleaned by a repair shop.
Nov 24, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Error 99 or 90
err 99 is moisture or dew inside the camera.
Aug 14, 2008 | Bower SFD35C for Canon TTL Flash
Tamron AF70-300mm f/4-5.6 Di LD Lens Logo
122 people viewed this question
Top Tamron Cameras Experts
Steve
Jerry Greenberg
Jerry Greenberg
Are you a Tamron Camera Expert? Answer questions, earn points and help others
