Question about LG Televison & Video
I Have an LG home theater system eject lock
I Have an LG home theater system and my son was pushing buttons and now the disc will not eject it says eject lock the model number is J10D-SA
SOURCE: Panasonic home theater
Okay, that guy is soooo wrong. Do you have your remote? Click setup and click disc and click on ratings and click unlock, just click #8, you may have to do this twice but it will unlock... no taking this apart... good luck :)
Posted on Jan 01, 2008
  • 13 Answers
SOURCE: does not play dvd disc or music disc
I had this same problem with my Apex AD-500W DVD Player. I decided since everyone said the player basically needed to be replaced it wouldn't hurt to go through the buttons on the remote just to try and figure it out......I DID!!!! I turned on my DVD Player, inserted a disc, turned on my tv and then hit the SYSTEM Button right below the power button until the screen said MULTI and the machine started working perfectly. There are 3 settings in that button, PAL which made my screen go crazy, NTSC ( i have no clue) and MULTI(this one made it work)! Hope it also works for all of you!!!
Posted on May 16, 2008
tech48
  • 624 Answers
SOURCE: PANASONIC HOMETHEATER SYSTEM TO PLASMA TV
Some where on the back, bottom or sides of your plasma tv you will find input jacks for the audio and video. You must know what type of inputs you want to use.
Most have have 4 types
HDMI (audio and video signal combined)
Component (red, blue, green RCA jacks for video only)
Composite (yellow RCA jack for video only)
S-video ( larger round black jack with video only)
The Panasonic should have all of those also. I am certain it has HDMI and Component.
Connect the HDMI cable into the output HDMI jack from the Panasonic into the HDMI input jack on the TV.
Then using your remote for the TV make sure you select the HDMI input for viewing.
If you use any of the other video outputs on the Panasonic just connect it to the same type of input jack on the TV. Once again check the owners manual for more detailed instruction if you need them.
You must always be sure to have the proper input selected on the TV to be able to view it.
You can also respond back with more questions if you have any.
I am happy to help.
Dave
Posted on Jun 27, 2008
  • 35 Answers
SOURCE: toshiba reads no disc
Dust infiltration is a likely culprit. Unplug the unit, open the case. Take a cotton swab and wet it with a small amount of glass cleaner. Gently wipe the laser lens several times without applying pressure, then use the other end to finish cleaning it off and to dry it. Often, so much dust gets inside these units and coats the objective lens it can't see the disc anymore. Give it a try, might work after this operation. I've fixed many CD & DVD players this way. If that doesn't work, take a can of compressed air and blow out dust from inside the laser by pointing the nozzle to the open space between the lens and the lens cover. Hold the can at least three inches away so as not to damage the internal workings of the laser assembly. Several short/sharp bursts of air might dislodge dust that has accumulated inside the laser housing.
Posted on Mar 05, 2009
  • 39 Answers
SOURCE: My 2 year old son has some how managed to lock our
Usually if they have a "child lock" function it is activated/deactivated by pressing and holding a button for a couple of seconds.
I would try this pressing single buttons at first, then try combos if no good.
Posted on Jun 14, 2009
My LG ht303su dvd player won't eject and it says it's locked
my LG ht303su DVD player won\'t eject and it says it\'s locked
Jan 15, 2011 | LG HT303SU Theater System
Display reads OPEN LOCK when I try to open dvd tray.
Samsung Home Theater Systems have a Dealer Lock or Tray Lock Function that prevents the disc tray from being opened.
There are four procedures for turning off the Dealer Lock function. Try one, then the other, to see which works on your system.
Unlocking Procedure 1 To turn off the Dealer Lock function, follow these steps:
  1. Turn on your Home Theater System.
  2. Press the Stop button on the front panel and the Power button on the remote control simultaneously for four seconds.
Note: Repeating the two steps above turns the dealer lock on again.
Unlocking Procedure 2 To turn off the Dealer Lock function, follow these steps
  2. Press and hold the Function button on the front panel for 3 seconds. The display shows the word Unlock.
Unlocking Procedure 3 To turn off the Dealer Lock function, follow these steps
  2. Press and hold the Open/Close button on the DVD player on the front panel for more than 4 seconds.
Note: Repeating the two steps above turns Dealer Lock on again.
Unlocking Procedure 4 To turn off the Dealer Lock function, follow these steps
  1. Using the HTS remote press the Menu button + 712, and the HTS will display CAN OPEN.
The Dealer Lock feature is mainly used by retailers to ensure that the display discs are not removed. However, parents of young children may find this feature very useful as well.
Jun 26, 2009 | Samsung HT-DS610 System
My 2 year old son has some how managed to lock our Panasonic SA-PT560 DVD Home Theater. When we try to eject the disc it states ' LOCKED '. Please can you help? Simon
Jun 14, 2009 | Audio Players & Recorders
Eject lock
Get a paper clip and unbend it so you have a straight wire. Then look closely at the dvd tray and next to the eject button you will see a tiny hole. Push the paperclip wire into the hole and manually release the dvd tray.
Feb 09, 2009 | LG LFD790 System
Can't eject dvd's.It says"LOCKED'How do you unlock to eject dvds
To unlock the JVC TH-C5 disc tray is by having the system off and at the same time hold the stop button and eject button until it says, "Unlocked".
Jan 10, 2009 | JVC THC5 Home Theater System with 5-Disc...
Eject lock
try holding down the stop botton down for about 10-15 secs or less it should turn off
Jun 26, 2008 | LG LFD790 System
take it apart via the screws on the side and back and then there is a white lever you can pull to unlock it. make sure you are wearing shoes because you dont wanna short the system
Sep 09, 2007 | Panasonic sa-ht930 Home Theater Audio...
How do i unlock my jvc th-m505 dvd digital theater system?
Hold the STOP button and push the EJECT button.
May 15, 2007 | JVC TH-M505 System
Televison & Video Logo
505 people viewed this question
Computer Repairing
Computer Repairing
