Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do i replace the lift shaft assembly on my craftsman lawn tractor? model number 917.272442.
    Scholar:
  • 138 Answers
There is not enough space here to describe the replacement procedure. some helpful tips though - order the part you are replacing [ordering from sears tell them: division 71, source 917, part no. 159471] before you tear into it. sitting around for 3 or 4 weeks, you'll probably forget where things attach. also, find the exploded parts diagram in your owner's manual and look it over carefully to see what you're getting yourself into. sometimes, it's worth a few bucks to let a competent shop do the work
Posted on Aug 17, 2009
Craftsman Lawn tractor 20 hp twin clynder briggs with a 42 inch deck I need a model number the plate is unreadable
Maybe this will help.The mower deck part # 165892. Mower Deck Assembly 42" I not sure of the model # . I also don't know your tractor's model # either. This part # for the 42" mower deck,is installed on a 18.5 HP Craftsman Lawn Tractor. I believe there isn't any difference between a model !8.5 HP and a model 20.0 HP, tractor when it comes to a mower deck. B.Locke
Sep 14, 2015 | Craftsman Garden
How o you change the lift assembly on a craftsman ZTS 7500 mower ?
Should be relatively simple. There are 4-5 cotter pins that connect the mowing deck to the bottom of the mower. Pull the pins, push the metal rods out, and remove the deck!
Jun 17, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Remove mower spindle star is stripped blade moves
If star is actually stripped, you will have to replace the whole spindle assembly and blade. I would not change just the shaft if I was you as its almost as expensive as the whole assembly.
Jun 07, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have craftsman 19.5hp lawn tractor,
156546 is coming up as steering shaft, knob or key.
160395 coming up as support shaft or capacitor.
your model 944.608461 is not coming up for me.
Jun 03, 2014 | Craftsman Garden
How to install Mower blade drive belt on 19.5 HP Craftsman 42" Lawn Tractor-Model # 917.270810, without removing mower from tractor.
Hi donsig245,
What I do is to drop the mower assembly to the ground, then I have enough room to install the drive belt without having to remove the mower assembly. You could put the tractor on blocks to lift it up higher so the mower might go a little lower, but it is the same procedure to install the belt. That is the only way I know to install the belt without removing the mower assembly. I know this is not what you wanted to hear, maybe somebody might have another idea that would help you. Regards and good luck.
Mar 12, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
The bolt holding the blades is broken off
Your st bet is to replace the entire spindle assembly.
It's not as cheap as drilling out the old bolt and using an "easyout" tool to remove it, but the outcome is certain.
Better yet do a web search on "137645, 137646 Shaft Kit For 130794 Mandrel, AYP" and you can find the shaft only with bearings.
On Amazon:
Sep 06, 2010 | Craftsman 21 Hp 42" Lawn Tractor Riding...
Craftsman riding lawn mower steering shaft fell. Mower will not steer. I just started mowing, and the mower quit steering. Looked underneath, and it appears the shaft came loose that is used to steer. Any...
Look under the seat of your tractor and note the complete Model number.
(usually begins with 917. _ _ _ _ _ _ )
Next, go to THIS PAGE and use the Model Number to find an exploded view of the steering components and how they assemble.
Hope this helps,
Dolf-
Oct 15, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
What year model is lawn tractor (mower), advice or solution
Hi there Avu
It's quite east to see when was your tractor was made, follow these simple steps and you'll know how to see what model it is
  1. Lift the tractor / mower seat (pull it up)
  2. You will see there's a small metal label with the serial and model number of the tractor / mower
  3. Check the serial number of the tractor / mower
  4. the first six digits of the number are you the model month day and year (i.e 090999XXXXXXX this tractor was made in September nine in 1999
Hope this helps
Attached is an image of the tractor seat and the metal plate
Sep 21, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Need image, assembled craftsman model 917.276813 lawn mower deck
Go to www.sears.com and on the tool bar click on parts direct. On the opening page click on model # and enter your model number. Then on the page that opens there will be a list of components. Click on the deck and it will give you an image of the deck with part numbers.
Hope this helps. Let me know.
Thanks
roundo4
Aug 26, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
640 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
