Question about HP 510 Notebook
My laptop monitor flickers ramdomly....the grafix
My laptop HP nx9000 monitor flickers ramdomly....the grafix card is fine. as it works well on extrnal monitors.
yesterday it was all black looked like backlight is dead. this morning it worked again..........what could be the problem? is it the loose connection.
how do i check this.
  • 1 more comment
  • kumar_rohiet Jul 14, 2009
    thanks for your reply Geekman. But there is no red/pink flash. the screen display is excellent except for the fact that some horizontal line appers for few sec and gets normal again. this happens at randomly and i cannot control this.
    As mentioned the external moniter works great.
    Yeaterday the laptop screen went blank/black with very few light making windows hardly visible. making me think that the CCFL lamp is faulty and demands replacement. But this morning i was surprised when my machine worked fine again,with good quality of light and flickers making me think that a loose connection is causing a problem.
    how do i check the loose connection to rule-out this possiblity if it is not the real issue.
    Appreciate your reply.
    correcting myself....
    But this morning i was surprised when my machine worked fine again,with good quality of light and NO flickers making me think that a loose connection is causing a problem.
  • HP Master
  • 32,281 Answers
This could be a faulty CCFL lamp.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Posted on Jul 14, 2009
Samsung SyncMaster B1940W Monitor resolution do match with GFX Card.
You could replace the monitor or reduce the resolution of the card or replace the graphics card.
Dec 02, 2017 | Samsung Computers & Internet
Can i install windows 7 in compeque nx 9000 laptop
HP Compaq Business Notebook nx9000 Series Specifications
From the specifications 128mb ram and graphic card ATI Mobility Radeon graphics accelerator with 16- or 32-MB DDR graphics memory, 4x AGP graphics capability i dont think that you can install windows 7 in that model and in case that you finally install the windows 7 you will get something unstable and practical not functional.
Apr 12, 2014 | HP Compaq Business Notebook nx9000
Laptop monitor bad color and flickers continuely, but when attached to external monitor, works fine
I'm going to take an educated guess here, because it sounds like the monitor's interface controller is bad. I forgot the name of the thing, but it's a small circuit board that's normally located at the bottom of the panel frame, between the flat ribbon cables and the round hinge cables.
"Inverter Board"
Mar 19, 2013 | Dell LATITUDE Computers & Internet
Hi i ive got a pc with msi ms7312 motherboard ,unknown what procesor but for sum reason when turned on my monitor wont *** on ,it has on bourd grafix ,iv tried the monitor on the pc im using now and it...
It's an very old Athlon XP processor. But the problem isn't with it, it's with the motherboard itself, the chipset has died.
There is nothing you can do, it's dead for good. Replace it - any Socket A motherboard with DDR memory will do.
Oct 18, 2010 | MSI KM4M-V Motherboard
Dv2740se Screen blank, if I connect to monitor it seems to
I suggest you to reinstall the operating system once, there might be some problem with the operating system so your screen is going blank before the operating system loads.
You can reinstall the operating system by using the re-installation disc.
Any further issue you can contact me.
Regards
-Dileep
May 23, 2010 | HP Pavilion DV2740SE Laptop
Vista driver for hp compaq nx9000
ofcourse not. Please re-intall any of these operating systems: windows xp or windows 2000. Vista is not compactable to this machine.
Mar 09, 2010 | HP Compaq Business Notebook nx9000
Ati radeon grafix card 9550/x1050 monitor signal out of range
Try to check the screen resolution and the screen refresh rate. Try to set it first to 60hz for the screen refresh rate and try to set the screen resolution to 1024 x 768.
Aug 31, 2009 | ATI RADEON HD 2400 PRO Graphic Card
Alienware monitor flickering green
this is most likely, a fault with the tft panel ( cfl Tube Or invertor )
Or a motherboard fault. I,d change screen invertor first Then new Panel.
Also if it has 2 graphics cards, 1 may have a fault.
Thankyou for using Fixya.
Mike @ compurepair.
Jan 21, 2009 | Computers & Internet
Display(VGA) output
does your system have on board grafix? or do you have a grafix card? if its on board grafix try borowing a grafix card off somebody to try in your system or try your grafix card in another system
Aug 03, 2008 | Dell OptiPlex GX110 PC Desktop
HP 510 Notebook Logo
1,747 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
