Question about Car Video Monitors
Time on car radio display
On 2003 BMW 330xi, how do I change the time on the radio display?
  • 298 Answers
Re: Time on car radio display
With the ignition key in position 1 or
higher, you can use the button in the
turn signal lever to request information
from the computer. Each time you
press the button briefly toward the
steering column, a new function is
called up in the display.
The displays appear in the following
Time of day, outside temperature, average
fuel consumption, cruising range,
average vehicle speed.
higher, the last active setting is displayed.
press the button you mentioned when the
time of day displays and turn to right to set
ahead left to set back
Posted on Nov 18, 2007
0 characters
3 Points
Can I change the display of my Toyota Axio to English language??? Pls. help.
Usted puede ajustar el tiempo a lo que es el momento correcto para su zona horaria. S?lo encienda el coche y la radio y encontrar el bot?n peque?o en la cara de radio para la hora y los minutos. Por lo general, la etiqueta H y Joe M.
Gracias por elegir Fixya!
Feb 16, 2011 | Car Video Monitors
BMW 325i computer ENGINE OIL light is on
bmw 320 petrol 400 miles 1 ltr engine oil finih
Oct 17, 2009 | Car Video Monitors
Hello, I wish somehow I do not "bother" but I have already approached other than the producer himself, as various vendors and suppliers but nobody knows me or just advice. These are my damaged DVD 2 DIN radio with with 7 "LCD touch-screen displays tipping, which I unfortunately" been damaged "in a car accident. Autorá*** is almost functionally while, but it does not control the touch, cracked the top covering e - touch surface, but can be seen and is otherwise good equipment - everything can be operated by remote control, and therefore only the GPS function, which is equipped with a radio that is thus ineligible to work. This is the type SMR 265, produced in Guangdong, China. LCD display is proven product fa Samsung marked CY / CVBS / AV: 320x240. dealer in Bohemia, of course, rejected "garančku" for mechanical failure - even though I assured him that I am aware of loss guarantees, I just wanted to "get a replacement LCD display. So Gentlemen - if you allow appeals to you and - you know at least advise me how I would be arriving to the replacement displays? In one of the responses to the Chinese trader I have received a reply that the smallest quantity they are willing to send 500 copies, sure you like what is ...... but (hey). I only strange, it is still very neozvali from Samsung - probably have spoiled mail addresses. If you can find some that time, although I know it again so much you have -- and if you can - talk to me, eventually., help with the repair - I thank you in advance - the greeting Schudich Miro, Slovakia
Sep 21, 2009 | XO Vision GX733 7.3 in. Car Monitor
Can i make the display split-screen full again ?
dbdbf85.gifyou should see a symbol similar to this in your I-drive it moves the nav. screen to the side of the display.Usually if you press it, it will toggle between different displays. If you look into your owners manual there should be one book that is completely dedicated to the navigation system. good luck
May 02, 2009 | Car Video Monitors
I have a 1997 bmw 328i Convertible 3 beeps coming from dash board
check your clock next time you hear the beeps...chances are it is at the top of the hour!
Apr 25, 2009 | Car Video Monitors
On/off button
Copy and paste this link in to your web browsers search bar.
Mar 22, 2009 | Car Video Monitors
BMW TV pixel loss
there is no repairs to this problem and you will have to replace the unit
Mar 09, 2009 | XO Vision GX733 7.3 in. Car Monitor
1998 bmw security code on the radio i need the password
Apr 06, 2008 | Car Video Monitors
Daihatsu Sirion 2003 - change time on clock
Hi i have a problem with replacing my serpentine belt on my 2003 daihatsu sirion can you please send me a diagram
Dec 10, 2007 | Car Video Monitors
Car Video Monitors Logo
175 people viewed this question
Top Car Video Monitors Experts
xxxxxx xxx
Custom Exchange
Custom Exchange
Are you a Car Video Monitor Expert? Answer questions, earn points and help others
