I just droped my cellphone on the ground tonyt and nw it wont turn on. i checked the sim and it was in properly then i tried charjin iht tu see if it was flat buh it wont turn on or charj or nefyng???? if yuh can help please du!!
This may be because of your damaged SIM. Try the following: 1. Check whether your SIM is rejected by just putting the same SIM in another phone. Also, check if your SIM is a valid GSM compatible SIM. 2. Check if that your phones SIM slot is fully operational. 3. Check if you have correctly inserted the SIM.
Hope this may help you. Happy New Year to you too.
Hi, have you tried using different Sim Card to check if the issue is related to Sim Card.? These issues happen due to Sim Card chip has damaged inside. If the same error displayed even after using working Sim Card, try to insert properly or the Phone's Sim Card Slot pins have not conducting properly to the Sim Card, in this case Service might be required to the Cellphone.
You can try a different sim to check if the problem is within the phone. If any case the cellphone recognize the new simcard it only means that the 1st simcard that youve use is faulty.If the cellphone still wont recognize the new sim card then it only means that the problem is within the phone. You can check if the phone still have a warranty for repair free of cost or bring it to a cellphone technician to fix it
Remember insert a SIM Card that is supported by your mobile phone it may be locked to a certain provider
turn off your phone, get the sim card and reinsert again, and then restart your phone, if not work try to test it with other simcard, check also the simcard holder if something is blocking it, clean it if its dirty, if it not work have it for a cellphone repair
Its possible that the sim card on your phone is not properly placed or the sim card that you own has some problems already.
Try to reinsert your sim card, this time make sure that it is properly placed. If the same happens, try to use a different sim card on your phone. If there are no problems, that means your sim card might be busted already. If the same happens with another sim card, then it is possible that the slot for the sim on your phone is defective or dirty. You may need to have it checked. :)
Hi Layna. You did the right thing by letting it dry out. The board (brain) of the phone should be ok. Just bring it to your local cellular service repair center and they should be able to fix it. It wont be covered under warranty because liquid damage never is. The problem with you phone is th "button flex" which should run you about $60 US to repair, no more than that. If you have no local repair center for cellphones in your area, check my profile and im sure we can help you.
