Question about LG LS092CE Split System Air Conditioner
Split ac not cooling the room.ac temparature remains at 27 degree after ac runs for about 4 hours.please solve this
    President:
  • 1,223 Answers
Gas has leaked from inner or outer unit kindly get it checked by service men they will find the leak and charge the gas again normally after some time it gets rusty inside as water is involved and got leak
no problem get it repaired not expensive
pls rate me well !
Regards
Posted on Jul 14, 2009
Can u please explain how much psi freon is required for 1 ton ac,how to recharge it with the help of vaccum pumps
Posted on Jun 01, 2013
Why cools the ac only 1 hour full power and never reaches the set-point temperature ?
check that all the doors and windows are closed as ac units do not work well when trying to cool the world
is the ac unit too small for the room size
I suspect that because it is working the problem is outside the ac control
is the inside fan working and blowing out cold air
May 22, 2016 | Heating & Cooling
How much more efficent is this than my 40 yr old janitrol 125000 btu beast
not knowing what you are replacing it with, it is hard to give a reasonable answer ( old sealed units against split system converter ac units )
However if you work along these lines, you will come to a logical decision
First off the old machines had the compressor operation tied to the thermostat setting so the compressor ran full blast until the room cooled to the set temperature. Then it stopped and remain stopped until the room heated up. At this point the compressor restarted and that is the point the the most power is consumed
again it runs full blast until the room again cools and switches off
So you can see that you have a varying room temperature and high energy consumption on start up
Now compare that to inverter units
The compressor is running all the time ( no high energy start ups every 10 minutes or so) but the compressor becomes less efficient as the room cools down
Still running at full rpms but the controls reduce the compressing action--less power to run the compressor--so there is a reduction in power used
The temperature variation is reduced because as the room warms a bit the compressor pumps a bit more gas and doesn't start at full load as per the old unit
Next , the latest units have better temperature / humidity recognition controls so they can be set at night so a room maintains an ambient temperature /humidity so that as the night gets cooler and the air drier you don't wake up freezing
It will even get to the point where you wonder if the unit is working
Lastly you can run the unit at a much higher setting ( 27 Degrees c instead of 24 or less and have the same comfort level as at 24-25 degrees c)
lastly warranty is for 2 years at best and parts will be available for the next 10 years against parts for your old unit
Mar 21, 2016 | Heating & Cooling
I have recently installed 1Te Voltas 2 star A.C. I need clarification on the following 1) In cool mode, what is system of auto cut. Suppose I put on remove temp 27deg C. Temp of the room goes up to 26 deg...
Dear Mahesh
In Cool Mode
Temp Diff - + - 1 deg C in Room Temp & Set Temp
This is auto cut
In Dry Mode
Comp Runs for 10 mins then get off for 5 mins then again get on for 10 mins this cycle continuues.
Oct 15, 2013 | Whirlpool ACQ158XP Wall/Window Air...
I have a Air Conditioner Model number Haier HW05CB12 and I need to know why isn't it cooling very well.
Kevan - There are a couple of basic things that can cause a AC unit to not cool as well , as it did in the past. And they are simple to troubleshoot and resolve.
1. A dirty of clogged air intake filter.
2. Cooling coils are dirty and need to be cleaned.
3. Higher than normal humidity in your area. This is not that easy to solve, because Mother Nature has control of it. Make sure that all doors and windows or closed tightly. When cooling only one room, the door(s) to it should remain closed. If the unit remains in direct sunlight 6 ot 8 hours per day, it struggles to cool. Adding a window awning above it, helps lower the heat from the sun.
4. The unit is to small to properly cool the area that it's in. 5000 Btu's can adequately cool about 576 Cubic feet ( Length x width x ceiling height = Cubic Feet) or 144 square feet.
The worst case scenario is: The compressor needs recharging with refrigerant gas. This is best done by a professional. As, doing it safely and properly requires specialized equipment.
Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 15, 2011 | Haier Heating & Cooling
Ice fallingfrom split ac
Try turning off the ac unit for about an hour.(Your might have too small of ac unit or just have the ac set too low..Causing the coils to freeze.
May 27, 2010 | LG Art Cool LA121CNP wall/window Air...
Anybody there?
It depends on the room varables, If it has an attic, tile ceiling, what type of walls, where in the building is the room and so on? The biggest problems is all ways the power. Get a free estaimate from an A/C company. Everyone and myself needs to see the room before they give you an recomndation that can truly be applyed to your situation. But to give you some ideas, I would put a 2.5 ton - 3 ton unit just for over kill. Go with a straight cool package unit. If your company tight on cash just get a mini split system with a 30,000 BTU to 36,000 BTU cooling capacity. Cost for something thats going to last 20 years, avg. is $4,500- for the package unit and as low as $3,000 for the mini split.
Oct 17, 2009 | Frigidaire FAA055N7A 5200 BTU Room Air...
Samsung 1.0 ton(split) AC stops working during 36-37 degree C.
i believe you have a high pressure switch on your condenser that is going bad .it is a switch that has two red wires connected to it inside your outside unit
Feb 11, 2009 | Samsung Heating & Cooling
Non-cooling
- Calibrate your electronic thermostat if it is accurate. If not then replacement is needed.
- Check the location of your electronic thermostat, it may be installed in the room where its too cold.
Feb 29, 2008 | Carrier 36KCARMS Air Conditioner
Not cooling
1. check doors,windows,of room
2.if there is leakage freash air came in.so temparature can not maintend
Jan 30, 2008 | Haier HPAC99ER Air Conditioner
LG LS092CE Split System Air Conditioner Logo
789 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
