Question about Samsung CLP-315W Laser Color Printer
Board gets stuck halfway!
I try to print on a specialty board and it keeps on getting stuck.
    Sergeant:
  • Samsung Expert
  • 406 Answers
This defect is due to exit sensor in the printer. You need to approach Authorised service center they will change it for you.
Thanks
Posted on Jul 14, 2009
Why is my screen frozen on my Konica Minolta Printer? and it won't print.
The model number would help. Is it stuck on the Konica Minolta logo screen? Have you tried turning the main power off and on? Even unplugging the machine from the wall outlet while it is off?
If its getting stuck on the KM logo then it could possibly need firmware reinstalled or you could have a bad NVRAM board. Either way, a trained technician will have to do it. The board is only available from a dealership.
Nov 13, 2014 | Konica Minolta Office Equipment & Supplies
The breaker keeps tripping halffway through my workout on my proform 730 cs. why?
see my personall TIPS for to see the schematic.
2) Try to run the software calibration for diagnose and troubleshooting and fix it.
3) The c. breaker can indicate the motor, trafo, capacitor, or board is hot and trip the breaker.
sincerely. God bless you
Apr 28, 2012 | Proform 730 Folding Treadmill Model...
It is a printer, fax, scanner, and copier and right now it is stuck on the fax setting. I can't get it to switch to print anything??
Remove off power and keep aside. If there seems to be a conflict with the PC then reinstall the printer sofftware.
Connect the printer back after few hours to ensure if this has reset.
If not if there is no action with the customere control there seems to be possible errrors in the microprocessor controller board.
Try to remove and tighten all connections... or a possible board error.
Hope this helps
Sep 06, 2010 | HP Officejet 4315v All-In-One InkJet...
Bosch SHU 3032 dishwasher gets stuck halfway through the wash cycle and just continues to wash until you manually advance it. I turned in on before bed one night and it was still running the next morning....
It obviously sounds like a timer issue here, and as it's embedded in a big chip on the control board, I would think a new control board is needed.
The exception to this is if it is not heating at all, in which case it won't advance if the water is not hot enough. Try it again and see if it gets warm.
If not - replace the heating element.
Most machines just stop to heat up the water, but to cut down cycle time they may recirculate the wash-water first to speed things up.
May 04, 2010 | Bosch 24 in. SHU30 Built-in Dishwasher
Printing Problem
To clear all pending job
In run window type services.msc and the go to print spooler option just stop and restart the service. And switch off and switch on the printer.
Jan 28, 2010 | Lexmark X73 All-In-One InkJet Printer
PSR-2100 need to find replacement circuit board.
I don't have a parts source for these other than Yamaha. Call them up to get the part number for the board. The sound is usually sent through the headphone jack which acts as a switch when you use headphones. Replacing that board should resolve your problem. If the board is no longer available, it is possible to repair the existing one, but this is a specialty task and not one I would recommend a novice attempt.
Please keep us posted on your progress,
Dan
Jul 24, 2009 | Yamaha Music
Printing not complete
Is it new? If so, please check that there is no packing material stuck anywhere in the machine or tape that they have put on moving parts to keep them from moving in transit.
Jun 21, 2009 | Lexmark X2650 All-In-One InkJet Printer
Paper gets stuck, eject indicator keeps blinking with out any effect on pressing it
its the problem in the main board of the printer that has shorted out the new colour and black cartridge in your printer which you installed.or may be one out of them.it happens some time.so you will have replace the cartridges 1 by 1 with new cartridge and check out.if still the problem then replace the board.that costs $12 plus shipping. mostly the cartridges have shorted out and replacing the cartridges will solve.
May 08, 2009 | HP DeskJet 610c InkJet Printer
The earplug/headset input on my Garmin Nuvi 660 is broken.
Interesting problem but I have repaired this problem before. This is not going to be something you can fix yourself.....believe me... I have 30 years of experience in Electronics.
The headphone jack either has to be resoldered or replaced. When its loose, in most cases the pins of the jack are broken and/or the printed circuit board tracks have been torn off the board. The jack is a surface mount part.
A new jack must be installed but there is no way to solder in a new jack because the printed circuit board tracks are gone. The new jack must be installed with epoxy to the board and new wires have to be soldered from the printed circuit board to the jack.
There's around 2 hrs worth of work involved in this repair.
- Jim
SHARCNET-USA
Dec 02, 2008 | Garmin Nuvi 660 GPS Receiver
Mac OS X Update Problem
Hi MerryAnn
To answer this one I'd need a bit more info. What mac are you installing it on? What version are you upgrading from? and how much memory (ram) do you have on board?
I assume you are not doing a 'erase and install' as the mac would not function any more if it got stuck halfway.
If all the other questions are OK with the OS version you are trying to install. Where possible you should do a clean install. Just make sure you back all your data up first.
Sep 01, 2008 | Apple Mac OS X 10.4
Samsung CLP-315W Laser Color Printer Logo
78 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
