What does the code Er FF mean? Please help... thank you!
SOURCE: error code er ff on my kenmore elite bottomfreezer model 795.7756
I fixed it. ER FF is "Error Freezer Fan." Once the evaporator fan stops turning for more than 115 seconds, this error message will be displayed. This fridge is poorly designed and is not designed with air gaps or enough air gaps to allow air behind the back panel of the freezer where the fans and condenser coils are located thus causing ice to build up around the fan and it's ability to spin. The evaporator fan helps cirulate the cold air generated by the condenser coils.
The fix is (1) defrost your refrigerator which means you'll loose all your food if you don't have another unit to keep the food in until it's done defrosting or (2) to dismantle the entire freezer by removing all the trays and railing so that you can pull the back panel far enough to get the front end of a hair dryer over the top lip of the panel to melt the ice. My unit had ice build at the top right and left corners behind the panel. I opted for the latter and didn't have to throw any food away.
This is going to be an annual chore if I want to keep this refrigerator. We should all ban together and call for a recall.
SOURCE: kenmore elite trio refridgerator with an error
ER FF is "Error Freezer Fan." Once the evaporator fan stops turning for more than 115 seconds, this error message will be displayed. This fridge is poorly designed and is not designed with air gaps or enough air gaps to allow air behind the back panel of the freezer where the fans and condenser coils are located thus causing ice to build up around the fan and it's ability to spin. The evaporator fan helps circulate the cold air generated by the condenser coils.
Good luck
SOURCE: what does ER FF mean on my Kenmore Elite bottom
Hi
Thanks
for using FixYa. Error ff is freezer fan fault. This usually happens when
either the rear board has gone bad or the freezer fan itself is bad and needs
to be replaced. To check what is causing the error you can start with checking
the fan which is located behind the back wall inside the freezer. Also check
the rear board as it might not be putting the fridge into defrost long enough
and is causing the ice to build up in the freezer and thus stopping the freezer
fan from turning and so causing ff error. Leave the fridge unplugged for 24hrs
which will melt all the ice then plug it back if still the issue is not
resolved and you hear the fan running then it is the rear board that needs to
be replaced. Please do rate the solution if the issue is resolved or else
revert for further assistance.
Thanks
Rylee
SOURCE: my trouble codes are Er FF on my kenmore elite
This is an error code that pertains to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed.
These checks require a meter and can be difficult to make, even for a technician.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Er FF code
I have the same problem. I believe it is the evaporator fan but havn't fixed it yet. You can save some food by unpluging you piece of junk for a while then pluging it back in. It will go out again soon but that will buy you some time.
