Question about SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive
My flash is not working on any computer
It is giving a light but not working at all
How do i fix it then?
Posted on Jul 24, 2009
    Problem Solver:
  • 9 Answers
The micro controller ic is damaged.
Posted on Jul 14, 2009
Flashing light codes
that be in the FSM, (Factory service manual)
alldata.com
or any Isuzu forum.
this forum xxxxx here, has no STRUCTURE so... only endless searches never work in fixya.
now google, did you even try to google this.=?
its the 1st hit (ISUZU flash codes nets)
http://www.troublecodes.net/isuzu/
Jul 25, 2014 | 1992 Isuzu Trooper
Single blue light flash then nothing
your computer power supply or motherboard is dead. I'd bring it in to a computer store for repairs/parts replacement. (if it's not under warranty, of course).
Jan 22, 2014 | Dell Vostro 420 Desktop Computer
Daikin FTY45EV1A split system wont turn on, has flashing timer light on. I turn the unit on and off by the remote, still doesn't work. What does the flashing timer light mean?
The only thing I can find on "Daikin FTY45EV1A" is on Russian, and I don't read that language. If you have a manual for that system then find the section on error codes and see if that flashing light gives you a pattern. Usually they flash in two sections giving you a two digit code. I.E. 1 flash pause then 3 more flashes would be a 13 code. Read your manual and see if it gives any help.
Jun 14, 2011 | Heating & Cooling
My check engine light comes on and stays for a while than goes off I thought that I smelled rubber today, what could it be
have your obd II CODES READ this will give you more of an idea what is going on with it. most auto parts stores read these codes. If you are smelling rubber check your serpitine belt for where and if it looks good take the belt loose and check the rest of the components that the serptine belt runs on altinator, water pump,powersteering pump, pully tensioner, other pullys ext.
Mar 21, 2011 | Chevrolet Aveo Cars & Trucks
Engi lite flashes 16 times thought this service
depending on the year of this car, a flashing check engine light means a misfire, this may be due to a bad spark plug or the wires to plugs, you can go to any autopart store and they will scan the computer and give you an idea of the problem and give you the codes, what happens is the computer sees a problem and it turns the light on to warn you of the problem , it then stores a code, this code will tell you what part of the system is failing or failed. if you can give me the year ,make and model with the codes the autopart store gives you i can help you further, hope this is helpful. good luck.
Dec 14, 2010 | GMC C1500 Cars & Trucks
O/d light flashing on 1995 Ford explorer. Started
You should have the computer self tested by someone with a scan tool. The flashing overdrive light indicates a concern with the transmission. Self testing the computer should produce a fault code and give you some idea of what is wrong.
Apr 02, 2010 | 1995 Ford Explorer
Battery indicator flashing red when running on battery or on main supply and battery is 75% charged
When your battery indicator is flashing Red, it usually means that the charger is defective.
Dell also had a recall on some of its batteries. To see if you qualify for a free replacement click here: http://www.dellbatteryprogram.com/
If you want to reset your battery utility follow these steps:
1. Let the battery run completely dead. (Make sure all your work is saved)
2. Fully charge battery (You may still have flashing lights but if you turn your computer on and enter BIOS you can see the charge level)
3. Once again run battery dead.
4. Remove battery and wait 5-10 minutes.
5. Replace battery and use in normal operation.
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thanks!
Feb 03, 2010 | Dell Latitude D600 Notebook
1721 Inspiron shows flashing amber, three times, then blue.
The cells in the battery are starting to go bad which is why the light is blinking the way it is.
Once you get a new battery put in there the light will stay blue instead of flashing amber.
Jul 04, 2009 | Dell Latitude D600 Notebook
Flash drive not working
An option that you could do is to plug the flash drive in the back of the computer. The reason is because flash drives derive power from the USB port itself unlike other usb devices that you are using may have their own power or because the USB port in front does not give as much power as the one from the back.
Jan 10, 2009 | Computers & Internet
SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive Logo
233 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
