Question about JVC Televison & Video
ERROR CODE:E~AC JVC TV .WHAT IS ERROR CODE:E~AC REFERRING TO.IT LOADS TO 68% THEN COMES UP WITH THIS ERROR CODE
Hello, did you this error? I'm getting the same one :(
Posted on Feb 20, 2014
2 Suggested Answers
SOURCE: I have a JVC TV. When you try to turn it on Error
dont know how you clear it but if you wait a couple of minutes til the red light stops flashin the tv will turn on- let me know if you find the solution, i have same prob
Posted on Nov 27, 2011
I have a JVC TV. When you try to turn it on Error Code E-AC is shown. TV will not turn on How do I clear this
Nov 02, 2011 | Televison & Video
I bought a JVC Screen 48inch used now I am locked out of sound on menu sound like treble and bass is dull how can I get code to unlock I need to unlock code to a used Jvc tv so I ca hear sound, sound on...
Hello
To set Lock and unlock proceeding are give here:
Channel guard and V-Chip settings are protected by a four-digit lock code. Your TV comes
pre-set with a lock code of "0000". You may change the code to any four-digit number you
wish. To change the lock code, follow the steps below.
Press the MENU button
Press [UP/Down] button to SET LOCK CODE.
Press [=> / <=] buttons to operate [lock icon appears]
Press ZERO to acess the lock code. The first digit will be highligted.
Press [ => / <=] button to select the number.
Press [Up/Down] button to move the next digit and continue to follow these directions for all the four digits.
Press OK button to finish.
Press the menu button when finished
DO THIS AFTER UNPLUG THE TV FROM AC MAINS WALL SOCKET, AND LEAVE IT FOR ABOUT 30 MINUTES OR SO, REPLUG IT TO ac MAINS, AND DO ALL THE ABOVE SAID PROCEEDINGS. THIS PROCESS WILL ERASE ALL THE V-VHIP CODES, IF SET, AND WILL ALLOW YOU TO SET AN OTHER OF YOUR OWN. The default V-Chip code is [0000]. Ok.
Apr 24, 2011 | JVC Televison & Video
What is a kia rio p1800 error code mean?
the code is for engine torque signal malfunction.its either a short to voltage or ground in between engine computer and transmission computer. or a bad trans computer [tcm] manuel says check for shorts or bad connections at the connectors from ecm to tcm then states if no wire problems found then try a new tcm and if problem goes away then install new tcm.i know those instructions are lame but it comes from the kia service manuel. there are no tsb or recalls listed for that code. so i would recomend take to dealer because they would have a known good tcm to try.plus if you bought the car new then the 10 year 100,000 mile warranty may still be in effect beings how its a powertrain issue so if less than 100,000 miles and you bought it new it wouldnt hurt to ask them if it might be covered
May 29, 2010 | 2002 Kia Rio
The TV won't stay "on"..the red lamp light is blinking.
The red blinks are an error code. Count them and refer to your owner's manual or a repair shop....
Mar 25, 2010 | JVC HD-52G787 52" Projection Television
JVC 36" TV will not power on and has a blinking power light...
Hi and welcome to FixYa,
Almost always, when an electronic device/equipment fails when powered with and by a generator, it is the power supply unit (PSU). The PSU circuitry expects a fairly constant/stable power source (120 or 220). The output of the generator tends to fluctuate especially under varying electrical load. Additionally, the AC frequency (60Hz) of the generator's output also tend to vary which most PSUs don't like. A noteworthy point to consider is that the generator is floating electrically, its output has no reference to earth/ground.
If you are considering a DIY (do-it-yourself), foremost to inspect would be the PSU particularly the regulator transistor and determine if it outputs +5 and ~+135 VDC. Another to check would be the HOT (horizontal output transistor). If when the TV was used powered by a generator, there was considerable vertical rolling, the vertical deflection IC would also be a suspect.
A friendly reminder, exercise caution when repairing TVs. It stores up EHV (extremely high voltage). It would be to your advantage to reference a service manual (JVC AV-36D303) or at the very least a schematic diagram with voltage readings.
Good luck and Thank you for using FixYa.
Jan 05, 2009 | JVC AV-36D303 36" TV
System error 1 light code E 68
error 68 means that the xbox has insufficient power to operate. make sure it is directly plugged into the wall. try removing accessories on your xbox like intercoolers and USB devices.
Aug 24, 2008 | Microsoft Xbox 360 Console
ERROR CODE 68 ON AFFINITY ATF7000EE
check tech sheet located inside washer cabinet at bottom. remove lower kick panel to access.
May 04, 2008 | Frigidaire Affinity ATF7000E Front Load...
Attempting to view videos from Everio to TV (this camcorder is new to me)
You do noy need an AC adapter to view on your TV.
How are you connecting to the TV.
Also try on another TV and see if the problem still exists.
Let me know the outcome and I will see if I can assist more.
Jan 09, 2008 | JVC Everio GZ-MG130 Camcorder
Cant record, cant open the cassette
The error E01 refers to loading motor problem. The camera will have to be taken to a JVC agent for repair.
Sep 19, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Televison & Video Logo
508 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
