Question about Electronics - Others
Amstrad SM102 turntable and tape deck motors not running
otacon
  • 1944 Answers
SOURCE: Tape deck running slow
Does this happen with all tapes?
Posted on Jan 18, 2008
  • 979 Answers
SOURCE: Kenwood UD700 home stereo. No
Be sure that the "tape mon" in not selected...accordianman
Posted on Jul 29, 2008
dunnbiker
  • 8546 Answers
SOURCE: Can't get a signal from my Turntables to record on my tape deck. I'm running turntables through RX 206 Amplifier and don't understand the RCA ins and outs.
Connect them to a receiver with a phono preamp.
Posted on Apr 12, 2009
  • 10 Answers
SOURCE: Need to record from turntables to cassette deck.
Bypass the reciever. Just mixer to tape deck. You will get a better recording anyways!
Posted on Apr 17, 2009
SOURCE: slow tape speed on reel to reel tape deck
My TC-230 has the same problems and it is mechanical. Actually, its real hard to say what your problem is, but it is most likely the pinch roller is to tight on the piece that is connected to the motor. This extra tension is from a spring inside the machine and, when in storage for a long time with the machine set to stop, extra pressure builds up on this spring. Try leaving it unplugged on fast forward/play overnight. that might help.
Posted on Jan 31, 2010
I have got PL117-D Turntable and CT 2OO Tapedeck.Both needs new belt.Where is it possible to get there?Can you help me?Thank you.
Hi u can buy a turntable belt of E/BAY £5.99 recycling-electonics,..,.Radio shack TANDY used to sell an assortment Pack of belts for tape decks etc also u can try (UK Vintage Radio) for the tape deck belts.,..Good luck
Jan 02, 2017 | Audio Players & Recorders
Why is this turntable running slow?
It depends which type of turntable it is. If a belt one then change the belt, make certain you make a note of how the belt fits before removing it.
Direct drive turntables are more difficult. As it could be any number of faulty parts that cause it.
A build up of grease or dirt in any type of deck can slow the speed down.
A faulty motor on both types of deck will also cause it.
Sep 07, 2015 | Audio Players & Recorders
CR2413A cassette tape deck will not play. function is set to phono
If the function selector is set to PHONO, it should be set to the position for [laying tapes.
Dec 06, 2014 | Crosley CR2413A Turntable
Trying to hook up older technics stereo dont know
Turntable leads go to Phono.
Turntable ground lead (thin black wire) goes to screw terminal next to 'Phono'
CD phono cables go (unsurprisingly) to the CD
Cassette deck "Play Out" cables go to 'Tape Playback' sockets.
Cassette deck "Rec In" cables go to 'Tape Rec Out' sockets.
EQ Line Out cables go to amp's VCR/EQ Playback
EQ Line In cables go to amp's VCR/EQ Record Out
Aug 30, 2014 | Audio Players & Recorders
Platter stops when i scratch and goes backwards sometimes.....had mind of it's own
Not really (and really not possible)
It's likely a belt drive deck and scratching with the motor still running on this sort can't really be done.
It's a fairly quick way to burn out the motor and wear out the drive belt.
If the deck is provided with manual overide for Motor Off or a Speed Neutral control that disengages the motor from the platen.
If a gear or direct drive deck there should be a disengage clutch control or a Speed Neutral setting.
Sep 16, 2011 | Numark TT200 Turntable
Apr 13, 2009 | JVC Audio Players & Recorders
HOW TOTRANSFER FROM CASSETE DECK VIA ION USB TURNTABLE
I'm thinking this is 100% impossible. There is absolutely no way you can get a cassette tape to play on a turntable.
Apr 07, 2009 | ION Audio Vinyl Recording Turntable
On jvc tdw11
the line out of a tape deck is about 1 volt peak, the output of a turntable is about 3-5mV on average.
Not sure what issue you are having but the turntable cannot be directly plugged into the cassette deck for recording LP to cassette. it would have to go through the receiver.
Dec 18, 2008 | JVC TD-W118 Single Cassette Deck
Electronics - Others Logo
118 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
