Question about OfficeMax Office Equipment & Supplies
Wont shut off in auto after cleaning sensor area
This has done it to me a few times, and I bet if you look really hard there is a sliver of paper that is blocking an optical coupler or has worked itself into a microswitch, or has wedged it in the wrong position. Somehow some safety feature is "protecting" you, but in the wrong way. Whenever there is a screwup go right back to the very last place you were working, and it is usually right there.
Posted on Jul 16, 2009
My 2001 Cadillc Deville Shuts off while driving but starts up again with no problm. then after few miles it shuts off again then i just turn it back on
It could be alot of things. A bad module in the distributor, a coil going, a MAP sensor or IAC sensor. Could be a bad distributor cap. Can tell without actually being there. Do you get a service engine soon light when it is running?
Jan 19, 2013 | 2002 Cadillac Deville
Konicaminolta bizhub 600 machine dropping the toner. what is the solutions?
first toner must must and must be genuine, other wise it wont work in any conditions,
2nd toner density sensors and gamma sensor should be cleaned and all auto setting must be run .
third some time toner drops down the others side of the drum due to recycle clutch did't not work properly and all cleaned toner drops down after filled in recycle area,
Jan 11, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
Was running a load of towels on auto sensor timer. Heard a pop and the dryer shut off. Sensor light was lit on wet. The dryer will not start under any settings. Sensor lights will flash on sometime,...
If you heard a pop then your belt probably fell off. There is a belt safety switch that wont allow the dryer to turn on if the belt is not attached
Jul 14, 2011 | Kenmore Dryers
Machine runs until manually shutting down, or until auto-shut down. In either case machine will not start back up for sveral minutes. Can I replace, disable, or remove the auto shut down feature. It's...
Hi and welcome to FixYa, I am Kelly.
I note that your question was 3 months ago. I answered a current post today that had your exact same symptoms. Your post was revealed after I answered the current post. Had I seen your post 90 days ago I would have responded with the same answer as follows:
There is a low oil level sensor on the opposite side of the engine as the oil fill / dipstick. The next time that your presure washer acts up disconnect ONE wire to the oil level sensor. On pressure washers mose engines have the oil level sensor removed for just this reason. You tip the engine to move the power washer and you can not start it or.. if you move it with the unit running the oil level sensor kills the ignition. Just make sure that anytime you are going to use it that you ensure the oil level is properly serviced. (Each use)
There is yet another possibility. Debris in the bottom of the fuel bowl will draft directly into the lower fuel jet (Located inthe bowl nut area) with a tip of the unit and clog the fuel nozzle. You can prove you have a fuel problem simply by adding gas to the carb throat with the air filter removed. If you get a brief start... you have a fuel not a spark problem. Turn off the fuel selector... remove the fuel float bowl nut and drop the float bowl. Use carb cleaner in the threaded area to clean out the orifice in the body of the carb and then remove the debris from the float bowl. CLEAN the bowl nut also.
Use a spray can lid for the next step under the float bowl area.
BRIEFLY
Open the fuel selector and gently lift the float to level. Fuel must shut off when near level and re-start fuel flow as you lower the float. The spray paint can lid should fill up in 8 seconds or less. If you have poor fuel flow start looking at the bottom of the gas tank or an inline fuel filter as the problem. Some fuel selectors have tiny bowls under the fuel selector lever. Make sure to clean this out also if you have one.
Turn off the fuel selector. Reinstall the float bowl making sure the rubber bowl gasket is fitted properly. Fuel selector ON... leak test. Then test start the unit and see if your symptom is gone.
One more possibility. Your engine has and E-Z start valve that is supposed to be a compression relief. If this is sitcking / partially open ect.. it can make it hard to start your engine.
I really think you have a low oil level sensor issue that is grounding out the spark because it cycles to ground when you move the unit and is not... sensing the oil level properly after you move the unit. I clean oil level sensors with carb cleaner. You can wake up about 75% of them just by cleaning them off internally through the 2 side holes cleaning up to the contact area on the top of the sensor.
Thanks for choosing FixYa,
Kelly
Jan 23, 2011 | Dewalt DPD3100 Gas Pressure Washer
2000 jimmy wont start. replaced flow mass senser cuz when we tapped it it idled better. turns over but wont start. fuel pump putting out 60psi. has fuel in the tank. check engine lite is on.
have truck scanned most auto stores such as auto zone / advanced do this service for free check ur local area the code will give u what the problem is so u can repair ur vehicle tapping the sensor and working better shows more of a connection problem than the sensor it self usually the mass sensor can be cleaned
May 05, 2010 | 2000 GMC Jimmy
Engine management light on permanently . both sensors removed and cleaned . light remains off for about 2 mins , but comes on again . cat has been found to be okay . help
have scanned most auto stores such as auto zone/advanced auto scan for free check ur local area the code will pinpoint ur problem if [im assuming the sensors are the o2 sensors] one is bad cleaning wont fix problem would need to be replaced or if its a circuit problem connection or wiring would need repair
Apr 08, 2010 | 2003 Honda Civic
My abs light just started coming on last week on my 2003 Mazda Tribute. When I start it up, it'll come on and then off like it's supposed to do. After I've driven for about ten - fifteen minutes, it'll...
the sensors are mounted at each wheel. wheel removal is probably not necessary. get under the car and look where the axle meets the wheel. you should see a steel ring mounted around the axle with teeth on it like a gear. mounted in that area is the speed sensor. there will be a wire attached to it. with sensor cleaner, spray each sensor and clean with a small brush. spray again.
Mar 07, 2010 | 2003 Mazda Tribute
Scanner will not auto feed!!!
the sensor of auto feed is not working properly kindly clean the sensor area
Dec 14, 2009 | Microtek SCANMAKER 5900 Flatbed Scanner
Dryer wont shut off
then you may need to replace moisture sensor bar located inside the drum area usually on the front or rear of the drum area they are two silver bars
Sep 23, 2009 | Dryers
Convergence
Sensor not reading problem is due there is some obstruct between sensor and projected light beam. Check any disturbance are there and clean the sensors. Cleaning work is done by the technical persons only since it is sensitive area. Try another method also by changing the TV aspect ratio is 16:9 and then select auto convergence method. This is the one chance is there before you call the technical person
Sep 05, 2007 | RCA P61310 TV
104 people viewed this question
Top OfficeMax Office Equipment & Supplies Experts
Colin Stickland
Colin Stickland
Steve
ka4iup
ka4iup
Are you an OfficeMax Office Equipment and Supply Expert? Answer questions, earn points and help others
