Overheating fan wont engage
  • Anonymous Nov 20, 2008
    i dont no..
  • Anonymous Apr 02, 2009
    1999 toyota camry driver side window goes down but not up
I have that problem and it was a 20 dollar sensor that runs the fan, when it broke you car does not know how hot the engine is and the fan will not shut off. Its called the temperture sensor change that and it should be fine
Posted on Apr 22, 2009
  • 3 Answers
First use a test light and make sure you are getting voltage to the fan with the ignition key on and the ac selector in on position.If no voltage check fuse in fusebox or (in linefuse ), If fuses are good check the fan relay switch. If all are good check for broken wire or bad ground.If you are getting voltage to the fan motor or the test light lights up then chances are you have a bad fan motor.
Posted on Nov 19, 2007
Replaced radiator, filled it with antifreeze
Likely somebody didn't hook up the fan(s) properly when the radiator was replaced.. OR ... hopefully, this wasn't a case where the original problem with the car was the cooling fans not working.... and somebody diagnosed the problem as a clogged radiator????? I had the same problem recently with the fans not working, and the problem was a relay switch that turned on the fans when more cooling was needed.....
Aug 07, 2014 | 2000 Toyota Camry
I have a 1990 Camry Wagon that is overheating. I changed two hoses that were leaking and replaced the fan relay. The two cooling fans will not turn on, also, the blower for the heater/air conditioner is no...
I would next look at the coolant temperature sensor, on which the car's computer depends for a signal to tell it when the engine is too hot. There might also be a suspicion that combustion gases are getting into the coolant, via a leaky head gasket. There is a test for that the mechanic can do.
Oct 30, 2013 | 1990 Toyota Camry
Fans not working/Overheating
Probably the temperature sending unit...if not that the relays...they should be relatively cheap and easy to replace...
Mar 31, 2017 | 1989 Toyota Camry
Car overheating?
in no particular order...
  • water pump
  • clogged radiator
  • stick thermostat
  • low coolant
  • inop cooling fans (stop/go driving)
  • clogged cooling system
  • bad coolant
May 24, 2010 | 1999 Toyota Camry
Where is located cooling fan switch toyota camry v6 2.5 1990
It is most likely threaded into the radiator on one of the sides.
Jan 08, 2010 | 1991 Toyota Camry
The engine is overheating at a stop but then goes down when I hit the gas. I have no Heat in the car. The radiator is full of coolant.
You may have one of several issues. Overheating at a stop indicates an inoperative radiator cooling fan, The no heat issue is more than likely being caused by an air pocket left in the cooling system from the overheating. I would suggst verifyuing the operation of the cooling fans, and then check for any air pockets in the cooling system.
Dec 22, 2009 | 1996 Toyota Camry
Car is overheating, Fans wont turn on
First are you sure the fans are good. Unplug the fans and hook directly to the battery and see if they turn. One fan is for the engine and should come on when the car gets hot. The other generally comes on when the a/c system is on. If both fans work hooked directly to the battery they are good go to the cooling fan switch or temperature switch (same thing different name) and make sure it is good. This tells the fan to kick on when the car gets hot. The other one kicks on when a switch on the a/c system tells it to kick on. Check and make sure you are getting power to the fans. Get a test light and ground it to a good ground on the car and probe the plugins going to the fans and insure there is power coming to them when the car is running. If no power fuse is bad or the sending unit is bad.
Oct 06, 2009 | 1999 Toyota Camry
Why Is the Cooling Fan not working?
Check the Following:
1. Thermostat
2. Water Level in reservoir
4. Water Pump
Apr 21, 2009 | Compaq Presario 1626 Cooling Fan Case...
Flush your regulator, and replace your fan cooling system.
Mar 18, 2009 | 1994 Toyota Camry
Computers & Internet Logo
604 people viewed this question
David Payne
David Payne
