Question about Nesa Vision NRM-5800 5.8 in. Car Monitor
I got a couple of nessa vision headrest monitors they are missing the brain box that converts the input to rca how can i find that box
Headrest monitor says no video. I have 10 inch power connect headrest monitor/DVD player. One plays DVD and the other is a monitor. The DVD player headrest plays movies but the monitor screen is blue and...
Those cables can go bad easily. If you have a meter and know how to use it, try to test continuity on each pin. If that isnt the answer, then either the input of second monitor is faulty, or output of main screen.
Jan 05, 2015 | Car Audio & Video
How could I connect a Daewoo 42sm TV?, I can't afford cable so I use a converter box(analog to digital w/rabbit antenna)on my other TV and I was given this Daewoo TV and would like to watch it;please
If your converter box only has RF outpit connectors "F" type screw on it looks like this my be more of a monitor then tv.I took a quick look at the manual and didn't see any RF inputs so it appears it doesn't have tuners built in Looks like you'll need a box that has RCA output connectors.or others that will match what the monitor has on it for input types
Mar 06, 2014 | Televison & Video
I got dual (forj) headrests the sound works on the one that has the dvd in it but not the one that does not, the rca jacks are hooked up to it, it has speakers in it, does it even have sound?
The monitor only headrest does not have audio handling circuitry in it. the wire harness for that side is the one with the red and black wire, and the two video inputs, not the harness with the red and black wire and the three RCA jacks. It will function on the wrong harness, but it is not the correct one.
The DVD headrest has two harnesses. One of them is for power and output, the other is for input only from another source. The harness with the red and black wire has the three RCA outputs... the video lead goes to the other headrest, and the audio can be fed to an aux input on a stereo or amplifier. The input harness is designed to be Video 2 input from either a gaming system (a Game Cube is a nice option), or another DVD or video source (hand held video device such as iPod or Smart Phone like a HTC Touch Pro 2).
Dec 12, 2009 | Dual Car Audio & Video
Iv hade these forj dvd monitors installed but i can only get sound on the radio
As for why you have NO sound, press the FMTX button repeatedly till the screen displays no FM transmitting frequency. Then you should be able to turn up the volume on the DVD player headrest only.
Nov 17, 2009 | MT&V Dual 7" Headrest Monitors & DVD...
Walmart dual headrest dvd player has no sound on passenger side
Oct 09, 2009 | MT&V Dual 7" Headrest Monitors & DVD...
I just bought the dual headrest from walmart and can not get the sound to work the passenger side. can anyone help me with this?or possibly tell me how to get the sound through the stereo.
To get sound out of the stereo, either run the audio output from the headrest to the aux input on your stereo, or cycle the FM transmit options using the FMTX button on the DVD player unit to a station you can tune to on your car's FM radio.
Apr 26, 2009 | MT&V Dual 7" Headrest Monitors & DVD...
How to convert a computer monitor to video television
You need a converter box, there might be some input lag but it should be ok if you are just watching tv.
it's a RCA to VGA converter, it's a thing you buy.
Oct 11, 2008 | AcerView 54EL 15" CRT Monitor
Connecting headrest monitors to Kenwood DDX-6019
Youll have to run sets of cables from your head unit to the seats, youll prob only need video, power, and ground if the sound will come from your speakers. For the same display on either monitor run to first position then link the 2 monitors.
May 10, 2008 | Sony XVM-R70 7 in. Car Monitor
Nesa Vision NRM-5800 5.8 in. Car Monitor Logo
67 people viewed this question
Top Nesa Vision Car Audio & Video Experts
jdtech
ray gallant
Are you a Nesa Vision Car Audio and Video Expert? Answer questions, earn points and help others
