Question about NetGear WGR614 Router
Wireless light not on ....
I have done the whole thing with unplugging router and modem and reset both of them but I still have the Wireless light not on but "I" symbol flashing.
I can not connect at all and when I ran "IPCONFIG/ALL " I got the statement saying "media disconnected"
what do I do ... I need help please
thank you
  • 854 Answers
Try using another PC and hardwire it to the router
follow this instruction
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Jul 14, 2009
  • 1,272 Answers
Perform the steps below to reset the router:
At the back of the router you will find a small tiny hole (which has a small button inside it). Press the button with the help of a paper clip. and hold it down for 30 seconds. After 30 seconds, please release the button and power off the device for 5 seconds.
now connect a computer to the router and perform the steps below:
1. Connect a ethernet cable from the Modem to the WAN port of the router(isolated port).
2. Connect the computer to the router using any one of the 4 available ports. Please make sure that THERE IS NO DIRECT CONNECTION BETWEEN THE MODEM AND THE COMPUTERS (either using Ethernet cable or USB cable).
3. Open the browser(Internet Explorer or Mozilla Firefox).
4. Access the router settings with the address: www.routerlogin.com/basicsetting.htm
5. Whenever prompted for username and password please enter User Name as 'admin' and Password as 'password'.
6. Click 'setup wizard'(at the top of list) from left menu.
7. Select yes and Click next.
8. In case you get the message: 'You already have a valid internet connection do you still want to continue', click 'YES'.
9. It should give you either a "Dynamic IP Detected" or "PPPoE detected".
10. If you get "Dynamic IP Detected" click on 'Next'. On the next page select 'Use Computer MAC Address' under Router MAC Address' and click 'Apply'.
11. If you get "PPPoE detected" click on 'Next'. Enter the login name and password provided by the ISP. Click Apply.
12. From the left menu go to 'Router Status' and check if you get the internet port ip address.
13. Click on 'Logout' (at the bottom of the list) from left menu.
14. Open up another browser window and try to access internet.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
As instructed i master reset my wireless router, due to the fact that i forgot my password. My internet connection wont work at all, now that i have "master reset" my linksys Wrt100 router.
When you do a Master Reset on a wireless router it sets the hardware back to factory settings.
To get this working again you will need to run the setup wizard CD to reconfigure the device.
You can find all the setup programs and documentation on how to configure at the following location:
http://www.linksysbycisco.com/APAC/en/support/WRT110/download
Good luck.
Jan 24, 2011 | Linksys WRT110 Wireless Router
Tip
Wireless Network Reset - Belkin
If you are unable to connect your laptop wireless to your <b>Belkin</b> wireless access point/router, the <b>easiest</b> and<b> fastest</b> way to get going is to reset your router to the factory defaults. This will make your router work like the day you bought it.<br /><br /><br /><br /><b>Reset your router:</b><b><br /></b><br /> <ul> <li><b>Unplug</b> your <i>DSL/Cable</i> <b>modem</b> from power (not your access point/router) Leave this unplugged for now</li></ul><br /><br />Next <ul> <li>On the rear of your<b> Belkin router </b>you will find a small RESET button</li> <li>With the power still on the router,<b> Press</b> and<b> hold</b> (with a pin/pen tip) the <b>RESET</b> button for 10 seconds.</li> <li><b>Release</b> the RESET button a wait 15 seconds for the router to reboot</li></ul><br /><br />almost done.... <ul> <li><b>Unplug</b> your <b>Belkin</b> router from power</li> <li><b>Plug</b> your DSL/Cable <b>modem</b> back in to <b>power</b></li> <li><b>Wait </b>1 minute for the modem to boot up</li> <li>Be sure the ethernet (cat5) cable from your <i>modem</i> is securely plugged into the <b>WAN port</b> on the back of your Linksys <i>router.</i> This is usually labeled <i>WAN</i> or<i> Internet</i> above the jack</li> <li><b>Plug</b> your Belkin <b>router</b> back into power.</li></ul><br /><br />You will now be able to connect to the internet with your wireless device. I would advise that you follow the next steps in securing your wireless network.<br /><br /><b><br /></b><i><b><br /></b></i><i><br /></i>Magoo
on Mar 13, 2011 | Computers & Internet
Tip
Wireless Network Password - Linksys
If you are unable to connect your laptop wireless to your Linksys wireless access point/router, the easiest and fastest way to get going is to reset your router to the factory defaults. This will make your router work like the day you bought it.
There are 2 steps involved Reset your router, Setup/Secure a new router
Reset your router:
First
  • Unplug your DSL/Cable modem from power (not your access point/router) Leave this unplugged for now
Second
  • On the rear of your Linksys router you will find a small RESET button
  • With the power still on the router, Press and hold (with a pin/pen tip) the RESET button for 30 seconds.
  • Release the RESET button a wait 15 seconds for the router to reboot
almost done....
  • Unplug your Linksys router from power
  • Plug your DSL/Cable modem back in to power
  • Wait 1 minute for the modem to boot up
  • Be sure the ethernet (cat5) cable from your modem is securely plugged into the WAN port on the back of your Linksys router. This is usually labeled WAN or Internet above the jack
  • Plug your Linksys router back into power.
Log into your router
  • Type 192.168.1.1 into your web browser and hit enter
  • In the login fields (case sensitive):
  • Username: leave_this_blank
  • Password: admin
  • Click OK
Once in the web interface for your router
  • Click Wireless tab - Basic Wireless Settings
  • Find the Wireless Network Name (SSID) field
  • change this to your new network name (this is the name you will see when you connect through your wireless device)
  • Find the Wireless Channel field
  • Change this from 6 (default) to 1 or 11
Magoo
on Mar 12, 2011 | Linksys Wireless-G WRT54G Router
Have 2 computers connected to Netgear WGT624NA router via ethernet connectors and have operated well for over a year. Now have gotten DSL and have run phone line to modem and via ethernet cable have...
Have you tried to reset router. It has to be done in order.
1. unplug router
2. unplug modem
3. shut down computer and restart after waiting 1 min
4. after restarting computer plug power back into modem and wait for all the lights to start blinking
5. after the modem is working plug power back to router and plug in the computer with ethernet cable and make sure you have internet,
6. try to link up with wireless,
If this does not work you will have to setup the router for wireless if it is att wireless you will have to call them to give you the password to set it up.
Jan 10, 2011 | NetGear WGT624 Wireless Router
Router has stopped responding
I am really not sure as to why this happened, but however you may want to try a doing a hard reset (press the reset button on the back of router - you may use a paperclip for the same) with the power on. ensure that the reset is done for a minimum of 30 secs. once its done turn of the power for couple of seconds and then coonnect the modem to the router as it was earlier done and then do a power cycle of both the modem and the router. This should bring back life into the router. I suggest you to try this as there is no harm to any of the devices and is worth trying.
May 13, 2010 | Belkin (F5D7230-4) Router (587009)
Problem with Acer Emachine and internet onnections!
Sometimes, the order in which u do things makes all the diffference.
1. shut down all machines
2. unplug modem and router
3. plug in just modem and wait for lights
4. plug in router and wait for all lights
5. restart computers
* if your still having an issue and your connection says local connection only then you need to reset the modem and router and then follow the above steps again.
Mar 06, 2010 | Acer Aspire 5100 Notebook
The ''wireless'' light on my wireless router is flashing amber
Contact Belkin for Care at 1-800-585-2494 Toll Free,,
Jan 09, 2010 | Belkin F5D8236-4 Router
Anything i try to watch on YOUTUBE stops and starts. I see the whole thing but in ten seconds bytes.
The video is buffering which is normal. A lot of buffering can mean an internet connection that is not quite fast enough. If you can do things that help with the performance of your internet connection, you can reduce the buffering attempts.
If you are dial-up, not much you are going to be able to do. Dial-up is not fast enough to support video.
If you are using high speed internet (DSL, cable, satellite), you can do things like restart the modem (unplug, wait 15 seconds, plug back in). If you have a router to connect mulitple PCs to your modem, you can restart the router (unplug, wait, plug in). Resetting router is especially useful if you stay connected all the time.
If you are connecting wireless to your modem/router, check the signal strength. Try to position your computer to get the best strength possible. To help boost signal, you can get hi-gain antennae for your modem/router. These will help boost the strength of the wireless signal as well as extend range.
Oct 11, 2009 | YouTube Videos
Wireless adapter not recognizing IP address
Try pressing and holding the reset button in for 15 seconds and unplugging the power cable and plugging it back in. That should reset the router to factory settings. It can also be done through the router's web interface.
Nov 02, 2007 | Linksys Wireless-G WAP54G 802.11g/b...
NetGear WGR614 Router Logo
132 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
